Insulation for heater pipes under the rear seat
Sofia74
Sofia74 is offline
PostPosted: Sun Nov 08, 2020 3:30 pm    Post subject: Insulation for heater pipes under the rear seat Reply with quote
Do you think this would work for the insulation over the heater pipes under the rear seat? I suspect it won’t because I am guessing those pipes are perforated for a reason and this wrap is not porous.
But I had it on hand.
And if that’s the case any recommendations for insulation? I am missing a couple pieces. Does it need to be a special material due to the heat?
Thanks.
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Sun Nov 08, 2020 4:08 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Matt, I think you may be right, the holes must be there to let a little ventilation, re the original "horsehair" type wrap. I used heater pipe insulation from HD, fiberglass type material with a foil backing, then secured with metal pipe tape, and secured with zip ties like original. If you still have originals in good condition, I would just re-wrap with those. If the material is bad, you can probably use what you show in your pic as an overwrap.
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
Sofia74
Sofia74 is offline
PostPosted: Sun Nov 08, 2020 4:26 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Good call. I suspect we talked about this previously but didn't remember.
I haven't found all my original insulation but still looking.
Using this as over wrap - also good idea.
Thanks.
Evil_Fiz
Evil_Fiz is offline
PostPosted: Mon Nov 09, 2020 11:14 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
I recall reading somewhere that the perforated section of the heater duct was there to act as a sound muffler. If that is the case, the best option would be to wrap it in foil backed fiberglass mat and zip tie it in place, taking care not to compress the galass mat too much.
The glass mat will also act as an insulator. So even if the perforations are not a mufler, you are still coming out ahead.
Emil
“…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
Marcdeb
Marcdeb is offline
PostPosted: Mon Nov 09, 2020 1:20 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Here's the Thread that discusses this topic.
https://www.thesamba.com/vw/forum/viewtopic.php?p=...ns#5829697
Can anyone post photos of the different materials that are used from the factory? I've seen some brown colored padding like stuff that is tie wrapped on.
I've also seen some plastic sleeves that are popped over the pipes.
And I've also seen some foil covered stuffing like material that is again tie wrapped on. I think my 71 Vert had the foil stuff as it was in a box of parts that came with the car. I thought it was garbage until I saw a picture somewhere of the same material tie wrapped over the perforated pipes.
So what years used what?
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
NoDents
NoDents is offline
PostPosted: Mon Nov 09, 2020 2:05 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
I don't have a picture, but my 71 has what appears to be cotton fiber (threads?) material under a tan colored plastic wrap.
And I do think it was partly used as a "muffler" for engine noise.
No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020
Marcdeb
Marcdeb is offline
PostPosted: Mon Nov 09, 2020 7:18 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Here's a picture I found somewhere of the insulation material being held in place with tie wraps. The next picture is this same material that came in a box of parts with my 71 Vert. It looks similar to carpet pad covered by a brown cloth that looks like burlap on the inside but has more of a plastic look on the outside. I realize now that the car needs 4 of these and I only have 2. The last picture is another style of heater pipe cover that came in that same box.
I don't know what years used which style? I wonder just how hot these pipes can get and if these materials need to be fire resistant?
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
NoDents
NoDents is offline
PostPosted: Mon Nov 09, 2020 7:33 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
The first 2 pictures is what my 71 has.
No Dents
rbsurfguy
I could be wrong, but I think those plastic tube covers are for early models. I have never had these or seen them on my 71.
Jeff
2012 Passat-Sold
Redlabel6
Redlabel6 is offline
PostPosted: Tue Nov 10, 2020 11:28 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
I used this
I used my original nasty ones for templates.
It looks and feels just like the originals, just a whole lot cleaner!
David
1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe
Marcdeb
Marcdeb is offline
PostPosted: Tue Nov 10, 2020 11:35 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Nice, Even your burlap is similar to original.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
sjbartnik
sjbartnik is offline
PostPosted: Tue Nov 10, 2020 9:45 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
The pipes should have some sort of insulation on them. Unless you wanna heat the area under the back seat for some reason Very Happy
Careful with that Reflectix stuff, check the max temp. I think it's around 180 degrees F which may not be sufficient for the heater.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Sofia74
Sofia74 is offline
PostPosted: Sat Nov 14, 2020 1:02 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Are you referring to the photo in the original post? It does have a plastic bubble wrap like inner layer. I don't have the packaging so I can't check temperature rating.
But...I had the same worry about the denim material. I have something similar on hand but was worried about the temperature...
pierrox
pierrox is offline
PostPosted: Fri Jun 13, 2025 4:54 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Reviving an old thread because it's the closest to my question...
After years, my 1971 Karmann is finally getting its rockers replaced. Upon opening, we found that the heater tubes are pretty damaged. Are there replacement parts available? Do Beetles/SuperBugs have the same?
Been searching the usual vendors with no success...
Thanks!
Our bus is on Instagram
instagram.com/biencuitbus
View user's profile Send private message Instagram Classifieds Feedback
Era Vulgaris
Era Vulgaris is offline
PostPosted: Fri Jun 13, 2025 5:25 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Thanks!
Search the classifieds. I've seen those heater ducts for sale in the classifieds in the past, either listed on their own or via cars being parted out. I don't think anyone reproduces them that I know of.
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
pierrox
pierrox is offline
PostPosted: Fri Jun 13, 2025 5:38 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
Unfortunately, being based in France, not sure shipping from the US makes financial sense. If even possible.
I'll have a look though, who knows!
Thanks!
pierrox
pierrox is offline
PostPosted: Fri Jun 13, 2025 6:33 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
VW offers one similar and the description claims it fits the Ghia:
https://www.volkswagen-classic-parts.com/catalog/en_global/part/113255430C
What do you think?
Can't find the left side though
Disc
Disc is online now
PostPosted: Fri Jun 13, 2025 11:07 pm    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
What do you think?
That part does not fit in Ghia!
The glory never gets old, just need new paint.
Nick
pierrox
pierrox is offline
PostPosted: Sat Jun 14, 2025 2:03 am    Post subject: Re: Insulation for heater pipes under the rear seat Reply with quote
This definite answer sounds like you went through the same issue! Wink
