Clutch Line floor pass through
bajaleo Premium Member
bajaleo is offline
PostPosted: Fri Jan 08, 2021 7:17 pm    Post subject: Clutch Line floor pass through Reply with quote
While doing the brake booster upgrade, I had the opportunity to look straight down through the pedal box where the hydraulic tubing for the clutch goes through the floor.
There's quite a large opening to atmosphere. Is there supposed to be a grommet or some other gasket there? What have others done here, or am I making a big deal of nothing?
Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Jan 08, 2021 8:11 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
Try this.
https://www.buslab.com/product-p/251721495.htm
Mark
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Jan 09, 2021 9:36 am    Post subject: Re: Clutch Line floor pass through Reply with quote
Speaking of the clutch line, can it be removed intact from a van for installation on another? I'm trading my manual bits for auto stuff with a member here, and don't know whether I should bother trying to remove mine, or just buy him a generic line from NAPA.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Jan 09, 2021 1:56 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
Yes it can, I had to do it for a Syncro conversion.
There's a coupler next to the radiator Wink
Zeitgeist 13
PostPosted: Sat Jan 09, 2021 3:07 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
Thanks dude, you're the best!
Casey--
'89 Bluestar ALH
NEAT, no ICE.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Jan 09, 2021 3:12 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
Anytime brother Wink
?Waldo?
?Waldo? is offline
PostPosted: Sat Jan 09, 2021 5:01 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
To the OP, I'd just squirt a bit of sealant into the existing grommet and call it good. That would serve the same function as trying to replace the grommet except it would be a lot less work and would likely last longer without issue.
I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site.
thatbaldwinlife
thatbaldwinlife is offline
PostPosted: Sat Jan 09, 2021 7:51 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
this is what I did
1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel
bajaleo is offline
PostPosted: Sun Jan 10, 2021 12:41 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
Thanks, Mark. That's what I was looking for.
crazyvwvanman wrote:
Try this.
Mark
bajaleo is offline
PostPosted: Sun Jan 10, 2021 12:47 pm    Post subject: Re: Clutch Line floor pass through Reply with quote
Waldo, that's a great suggestion. Unfortunately I don't have an existing grommet to add sealant to.
Mark provided a link to the replacement part above.
DanHoug
DanHoug is offline
PostPosted: Mon Jan 11, 2021 9:07 am    Post subject: Re: Clutch Line floor pass through Reply with quote
i think ?Waldo? was saying to squirt sealant into the annulus the line passes thru... once it cures it keeps the line from chaffing on the pass thru edges and seals water out. if it was just a hole in the sheet metal, you'd have to install a grommet but that deep pass thru is a perfect application for sealant.
or you can get the right part, split one side, install over the line and super glue the split back together, then tamp in place.
-dan
www.thefixitworkshop.com
