bajaleo  Samba Member
Joined: March 21, 2009 Posts: 216 Location: San Juan Capistrano, CA
Posted: Fri Jan 08, 2021 7:17 pm Post subject: Clutch Line floor pass through |
While doing the brake booster upgrade, I had the opportunity to look straight down through the pedal box where the hydraulic tubing for the clutch goes through the floor.
There's quite a large opening to atmosphere. Is there supposed to be a grommet or some other gasket there? What have others done here, or am I making a big deal of nothing?
_________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10460 Location: Orbiting San Diego
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12175 Location: Port Manteau
Posted: Sat Jan 09, 2021 9:36 am Post subject: Re: Clutch Line floor pass through |
Speaking of the clutch line, can it be removed intact from a van for installation on another? I'm trading my manual bits for auto stuff with a member here, and don't know whether I should bother trying to remove mine, or just buy him a generic line from NAPA. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7300 Location: Honolulu,Hawaii and France
Posted: Sat Jan 09, 2021 1:56 pm Post subject: Re: Clutch Line floor pass through |
| Zeitgeist 13 wrote: |
| Speaking of the clutch line, can it be removed intact from a van for installation on another? I'm trading my manual bits for auto stuff with a member here, and don't know whether I should bother trying to remove mine, or just buy him a generic line from NAPA. |
Yes it can, I had to do it for a Syncro conversion.
There's a coupler next to the radiator  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sat Jan 09, 2021 3:07 pm Post subject: Re: Clutch Line floor pass through |
Thanks dude, you're the best! _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10123 Location: Where?
Posted: Sat Jan 09, 2021 5:01 pm Post subject: Re: Clutch Line floor pass through |
To the OP, I'd just squirt a bit of sealant into the existing grommet and call it good. That would serve the same function as trying to replace the grommet except it would be a lot less work and would likely last longer without issue. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 805 Location: Out exploring
Posted: Sat Jan 09, 2021 7:51 pm Post subject: Re: Clutch Line floor pass through |
| ?Waldo? wrote: |
| To the OP, I'd just squirt a bit of sealant into the existing grommet and call it good. That would serve the same function as trying to replace the grommet except it would be a lot less work and would likely last longer without issue. |
this is what I did _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel |
Posted: Sun Jan 10, 2021 12:41 pm Post subject: Re: Clutch Line floor pass through |
Thanks, Mark. That's what I was looking for.
Posted: Sun Jan 10, 2021 12:47 pm Post subject: Re: Clutch Line floor pass through |
Waldo, that's a great suggestion. Unfortunately I don't have an existing grommet to add sealant to.
Mark provided a link to the replacement part above.
| ?Waldo? wrote: |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5895 Location: Bemidji, MN
Posted: Mon Jan 11, 2021 9:07 am Post subject: Re: Clutch Line floor pass through |
| bajaleo wrote: |
| ?Waldo? wrote: |
i think ?Waldo? was saying to squirt sealant into the annulus the line passes thru... once it cures it keeps the line from chaffing on the pass thru edges and seals water out. if it was just a hole in the sheet metal, you'd have to install a grommet but that deep pass thru is a perfect application for sealant.
or you can get the right part, split one side, install over the line and super glue the split back together, then tamp in place. _________________ -dan
www.thefixitworkshop.com |
