vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15599 Location: Deep in the 405
Posted: Sat Jan 09, 2021 9:49 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Your cheapest solution and what I would do is get 5.5" I-beam rods and use .080" cylinder shims (or you could use a .040" cylinder shim and a silly .040" copper head shim). _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
nsracing Samba Member
Posted: Sun Jan 10, 2021 5:31 am Post subject: Re: Post-Mortem of a 1904: Need some input |
The problem w/ this thread is too many damn cooks and the OP is all confused.
The issue it trying to accommodate a lopsided deck height -seems to me the only issue is #3 @ 0.055" - swap the rods around to the #4 @ 0.058" and see if it improves. If not, then run it like that - the #1/2 side will be looser in deck = I will put the tighter CC head on this side and the looser CC head on the 3/4 side.
YOu are just splitting hairs here. And the lack of machining services into this build makes it moot point. And the case has been decked. YOu cannot even tell if the case was decked even to begin with...as someone already pointed out.
~ 0.066" decks are about what the factory did. It is not that big. If you are fine-tuning a purpose built motor and have all the machinetools nearby to correct whatever dimension you like, sure you can split hairs.
I have done many ASYMETRIC engines when the heads had different deck-to-rocker pads dimensions. If you try to even them exactly, you will end up w/ different lengths pushrods between left and right banks. So the best way i found is to machine the heads so the motor can use same length pushrods.
Another way when the head chambers are different volumes and you have tight and loose decks side to side. Just do a best-fit = loose decks get the tight heads...and tight decks get the loose heads.
YOu get differences in decks when the machine shop just slaps the case halves on the mill and cuts before they look which side is tight or not.
tHe case is usually the culprit when you have uneven decks.
Goodness. |
D/A/N Samba Member
Posted: Sun Jan 10, 2021 1:37 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Looks like I’ve got a lot to think about! While nsracing is correct that I’m definitely a bit confused, I do see an end in sight.
Also I’ve yet to cc the heads that were on this engine but will hopefully get to that later today.
Pruneman99 wrote: |
Easiest way to fix excessive deck is to use a longer rod. Keep your "B" pistons.
What rod is in there now? Stock? |
Yeah, stock rods for now. Which makes me wonder if another “test” might be useful. I still have the A pistons the builder didn’t want to go with because they gave too much positive deck. Would it be useful to mock things back up using that A piston kit? Then, I could see what the positive deck is all around and order shims? Hell....maybe I’ll be lucky and find out that the deck is equally positive all around..... _________________ '70 Riviera. 1904cc w/ 40mm Dellortos, 019 distributor, Steve Tims “super stock” 37x32 heads, Web Cam 218, Vintage Speed SS143 Super Speed exhaust, 1 1/2” heater boxes |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Jan 10, 2021 1:59 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
If you want to use the A pistons, use a shorter 5.325 rod. Small shim, Bob's your uncle. |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 3963 Location: Rapid City, South Dakota
Posted: Sun Jan 10, 2021 5:30 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Mock it up with the A's and then use a .010" thinner shim on the long side.
Done.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
modok Samba Member
Joined: October 30, 2009 Posts: 27658 Location: Colorado Springs
Posted: Sun Jan 10, 2021 5:49 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
With A pisotns .110 wider than stock, which is fine IMO.
With mahle B pistons is .110 narrower than stock,
B pistons and 5.5 rod would be closest to stock width. |
D/A/N Samba Member
Posted: Sun Jan 10, 2021 6:45 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Thanks, modok, Brian, and pruneman. More good stuff to think about.
Also this. When I was putting the cylinders for the B pistons in yesterday I thought I noticed something strange on the cylinder walls. When removing them today, I confirmed something is strange looking to say the least.
What the heck is this mark from? The hone is still there but the metal feels ever so slightly smoother than in the rest of the cylinder.
Rotating the cylinder shows that it’s a little less dark on the other side, but still there.
modok Samba Member
Posted: Sun Jan 10, 2021 6:57 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Light scoring from some dirt that became embedded in the piston skirt.
A little of that is to be expected with these soft pistons, not a big deal, it can be FAR worse. |
D/A/N Samba Member
Posted: Sun Jan 10, 2021 6:59 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
modok wrote: |
Ok, good. Wasn’t hoping for bad news. Also, what you said above about A pistons and being .110 wider than stock, what rod size is that with? _________________ '70 Riviera. 1904cc w/ 40mm Dellortos, 019 distributor, Steve Tims “super stock” 37x32 heads, Web Cam 218, Vintage Speed SS143 Super Speed exhaust, 1 1/2” heater boxes |
modok Samba Member
Posted: Sun Jan 10, 2021 7:08 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
stock (137mm), 5mm more stroke puts the piston that much farther out, .098 now that I think about it.
Not sure why my brain said .110......but close enough |
Posted: Sun Jan 10, 2021 7:20 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
That looks like it had pin buttons in it. Which is strange, because buttons will fall out with most B pistons.
Did it have them? Or maybe when the A pistons were in there? Or Modok could be right, just from the piston skirt. |
Paul Jr Samba Member
Posted: Sun Jan 10, 2021 7:53 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Pruneman99 wrote: |
Can you please explain why buttons would fall out with B pistons?
I can see how they are not compatible with slipper skirt pistons but fail to see how they would just fall out of a B piston but not an A. |
modok Samba Member
Posted: Sun Jan 10, 2021 7:56 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Pruneman99 wrote: |
Good guess, but 74 stroke would not pull the piston pin all the way to the bottom of the cylinder, that takes 84 stroke at least. |
Posted: Sun Jan 10, 2021 8:04 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
modok wrote: |
Pruneman99 wrote: |
That's a good point. |
Posted: Sun Jan 10, 2021 8:07 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Paul Jr wrote: |
Pruneman99 wrote: |
Most A pistons are full round and have long pins. The button gets trapped between the end of the pin, and the cylinder wall.
Most B pistons have short pins. The button doesn't get trapped, so it will fall out. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4130 Location: NW Washington
Posted: Sun Jan 10, 2021 9:45 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
I've been running .062" deck for 8 years and 43,000 miles. It runs just fine.
Put a .010 shim on the one side and finish it.
D/A/N wrote: |
modok wrote: |
the simple thing to do is put .010 shims on one side, or just leave it alone. But I assume you are frustrated with halfassery at this point.
It's a shame to be be re-machining the case AND honing and replacing the rings just for the sake of .010" or .015" but by traditional wisdom that's what should be done.
If the rings are broken in, you should not make the piston run higher in the cylinder than it did before.
On the plus side done right, you will know the case is right, and have better ring seal than new cylinders.
Dial calipers are adequate to check the rod length and pin height, but checking the case is going to require at least some combination of things you probably don't have. I've tried all kinds of ways, does not seem to be an easy way. |
Yeah, the rings are broken in. Mahle 1st and 3rd rings and Total Seal 2nd rings.
I could do a .010 ring on one side which would bring the deck height all around to about .065 and that’s big, no? Per the CB engine calculator, I’d need combustion chambers of 53cc’s.
Though according to that calculator, if I had .050 deck height, I’d need 55cc chambers to get my desired compression ratio of 8.5 which begs the question (for me anyway) of does a larger deck matter all that much if desired CR can be achieved by taking 2 cc’s out of the chamber? |
richardcraineum wrote: |
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah .. |
cbeck wrote: |
His user name in a previous life was dick head. |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
D/A/N Samba Member
Posted: Mon Jan 11, 2021 5:36 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
I get it that I’m splitting hairs and that I could more or less run the engine as is but I’m actually interested in learning more about how all this shit goes together and how to solve the different problems that arise along the way. And I’m working from home right now and have more time and blah blah blah.
I also have a stock motor I’m going to build from the ground up but I started with this one because it’s all together and I thought it’d be easier to solve the problems it presents. That hasn’t quite been the case but I’m grateful for all the help so far. Sorry if it sounds like I’m beating a dead horse. But I never liked horses much anyway so.....
In other news, I slapped the A piston and cylinder on #1 and measured about .122” of positive deck. I’m still going to check the other 3 cylinders just for fun but If I was aiming for, say, a deck height of .045 I’m looking at a stack of about .167” in shims on #1 and isn’t that on top of the .098 wider than stock modok pointed out yesterday? I’m understanding this correctly the total width would be just over 1/4” at .265.
So at what point would the engine be too wide to get all my tin and crap to fit correctly? _________________ '70 Riviera. 1904cc w/ 40mm Dellortos, 019 distributor, Steve Tims “super stock” 37x32 heads, Web Cam 218, Vintage Speed SS143 Super Speed exhaust, 1 1/2” heater boxes |
Rome Samba Member
Joined: June 02, 2004 Posts: 10524 Location: Pearl River, NY
Posted: Mon Jan 11, 2021 6:17 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
When you fitted the A pistons to your cylinders, aren't those cylinders the original ones that have been shortened at the bottom? If so, then you'll certainly have a large positive deck/exposed piston top with the A's. Do you have a single uncut 90.5 mm cylinder to test fit the A piston and determine the deck height? You could use a junked cylinder as long as the total length has not been cut, and still has a near-full perimeter along the case side. Maybe somebody could send you a junked one (e.g., rust pockmarks on inner surface) for the cost of shipping.
Remember too, as pointed out that if you space the cylinders outward using the 0.167" shims or the other suggestions, you are moving the head away from the case. You'll need longer pushrods so that your rockers still operate somewhat correctly. If you want to keep the A pistons and just get new cylinders, aircooled.net sells just the cylinders. Cylinder length is the same for 90.5 A or B sets. |
D/A/N Samba Member
Posted: Mon Jan 11, 2021 7:03 pm Post subject: Re: Post-Mortem of a 1904: Need some input |
Rome wrote: |
The A cylinders were honed but not otherwise machined. It’s the B pistons that were trimmed.
I’m now starting to see the wisdom of either the A’s with a shorter rod or the B’s with a longer one....
I figured I’d need new pushrods and have to mess with rocker geometry and whatnot but I don’t even have an order in for new heads yet. _________________ '70 Riviera. 1904cc w/ 40mm Dellortos, 019 distributor, Steve Tims “super stock” 37x32 heads, Web Cam 218, Vintage Speed SS143 Super Speed exhaust, 1 1/2” heater boxes |
Rome Samba Member
Posted: Tue Jan 12, 2021 5:43 am Post subject: Re: Post-Mortem of a 1904: Need some input |
Quote: |
The A cylinders were honed but not otherwise machined. It’s the B pistons that were trimmed. |
Your comment below is why I wrote that your cylinders have been shortened:
Quote: |
I dug into the build notes and emails from the builder from back in 2013 and found that he had the cylinders trimmed at the end where they seal to the case in order to get rid of positive deck |
If you want to test stock-length uncut cylinders with the intent of building the engine back up with them, then you will have to check the pushrod lengths, rocker geometry, carb linkage width, possibly the muffler/header width. The engine will be wider than when built. I think the easiest way to get the engine running slightly better, without a full disassembly, is to fit those 0.010" shims to the "low" cylinder pair as several others have recommended. But "cc" your heads so you can determine the engine's compression ratio. Then you have the additional option per nsracing, to swap the tighter head (smaller cc volume) to the engine side with the larger deck heights. I remember this scenario was mentioned by Gene Berg in one of his newsletters, or another publication that I read with great interest in my early engine-building days in the late '80's to early '90's. |
