LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5598 Location: 1st Coast
Posted: Sat Jan 09, 2021 3:38 pm Post subject: Help ordering correct hot water heater parts |
I spent all day trying to order the correct thermopile for my AO Smith 4 yr old hot water heater to no avail. My 4 yr old AO Smith hot water heater is model number GCR 30 400 and this video is perfect but now I'm not sure if it's only the thermopile (thermopile is for the newer units using electronics and requiring more current than a theromocoupler) or additional parts. Worst case senerio I order the entire water heater burner which contains everything but more money. I just want to figure what I need and get the correct part number and I'm frustrated. I fix all my own appliances and on a budget. Sold and repaired all plumbing for years so I have some experience. Tips and trick and of course knowledge appreciated.
I'm not happy that a 4 yr old hot water heater needs anything so yes I'm angry but I suppose we all need to eat.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
| Lind wrote: |
| Have you considered simply starting with a nicer bus? I don't know what your skills are, but the race is easier if you can see the finish line. If you are not a runner, don't start off doing a marathon. |
Posted: Sat Jan 09, 2021 6:33 pm Post subject: Re: Help ordering correct hot water heater parts |
Fixed it, I just watched this video and at the end he shows the thermocouple switch and if it pops back in like a breaker that will cause the electronic polite from starting. Yes on mine I was able to press back in like a breaker. Then I was able to get the pilot light to stay on and heat the water. Now I want to know why the thermocouple switch popped out as per this YouTube.
Thanks for listening to me whine. I'm good now.
Maui Roadsters
| Lind wrote: |
cbeck Samba Member
Joined: January 14, 2014 Posts: 2569 Location: high ridge, mo
Posted: Sun Jan 10, 2021 6:29 am Post subject: Re: Help ordering correct hot water heater parts |
Mine has a "filter" that wraps around the bottom to keep out the dust. The thermal would pop out every time my daughter took one of her 30 minute showers. Removed the filter and no more problems. 2 years now.
The thermo coupler is the only part available for mine, short of the entire burner/controler assy. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
raydog Samba Member
Joined: February 09, 2006 Posts: 1207 Location: Cape Cod
Posted: Mon Jan 11, 2021 6:48 am Post subject: Re: Help ordering correct hot water heater parts |
| That resettable switch is a thermo-disc. It trips if the combustion chamber overheats due to lack of air or blocked flue. Check under the water heater for lint plugging up the air intake, blow out with compressed air, make sure you have good draft. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Jan 11, 2021 11:17 am Post subject: Re: Help ordering correct hot water heater parts |
| LAGrunthaner wrote: |
Check out repairclinic.com for parts and videos on appliance repair. I just had to replace the gas valve on my WH Christmas Eve Day and had to pony up for the whole kit at $230 from the local supply house, I did not want to wait a week for the for the $50 temp sensor in the valve. |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2215 Location: Bulli Klinik, Colorado Springs
Posted: Mon Jan 11, 2021 11:29 am Post subject: Re: Help ordering correct hot water heater parts |
Why would you need to heat hot water?
Water heater. _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23991 Location: NYC/Upstate/ROW
Posted: Mon Jan 11, 2021 12:53 pm Post subject: Re: Help ordering correct hot water heater parts |
Room temperature water is quite hot, at least 459 Kelvin. Ergo , itβs a hot water heater
L - you might have one of the unique left hand thread thermocouples which are NLA on that AO Smith. You used to be able to get a workaround with a collar but. With people going to on demand , that option , too , is NLA
Iβve got a few stashed away from the decrepit rental units I used for widows and orphans. First/last and one summer of yacht fuel due on move in. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Sun Jan 17, 2021 4:22 pm Post subject: Re: Help ordering correct hot water heater parts |
You guys are very funny, yes "hot water heater"
Little update. Friday just before running out the door to school I took a shower and for a second I felt the hot water drop in temperature. I didn't think anything of it, I was running short on time.
I got home to no flashing light on the computer, took a peek and saw the pilot light out again. I tested the thermo-cut-off switch for continuity just for fun and pressed it. I started the pilot and got hot water. I finally found the AO Smith phone number and hoped they would answer. I waited on the phone on hold for 1 hr 10 min and then the robot stated I would receive a callback. After another hr I got a great expert to determine what I needed to order. I almost fell off my chair when he said my unit was still under warranty till 2022 with just my serial number. I didn't recall registering so I'm guessing the local shop did it for me as they are a very old local company. He said the thermopile (a pile of thermocouples) is being mailed out immediately with no charge.
BTW he knew these guys in this video and they were the best throughout all my research. I hope the install goes smoothly.
Maui Roadsters
| Lind wrote: |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33146 Location: Hot Arizona
Posted: Sun Jan 17, 2021 4:50 pm Post subject: Re: Help ordering correct hot water heater parts |
| I waited on the phone on hold for 1 hr 10 min and then the robot stated I would receive a callback. After another hr I got a great expert to determine what I needed to order. |
All such cost-savings programs - like having too few employees to handle the number of expected calls ("we are experiencing a very high call volume at this time") are typically blamed on Covid.
Less staffing = lower costs of salaries....if company feels that profits will not drop correspondingly, considered a good business move.
Nice that it was under warranty and they will send out the part free.
I E-mail and get free replacement faucet cartridges for my Pegasus lifetime warranty faucets. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Jennepher  Administrator
Joined: September 10, 2002 Posts: 4829 Location: Arizona
Posted: Tue Jan 19, 2021 11:08 am Post subject: Re: Help ordering correct hot water heater parts |
You would be surprised how hot the pilot light can keep water in the tank over night. The next person in line get the cool water shower. The third person, not so lucky. |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4252 Location: Redwood City, California
Posted: Wed Mar 10, 2021 11:40 pm Post subject: Re: Help ordering correct hot water heater parts |
Why would you heat Hot water?
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Cusser Samba Member
Zundfolge1432  Samba Member
Posted: Thu Mar 11, 2021 8:23 am Post subject: Re: Help ordering correct hot water heater parts |
| 16CVs wrote: |
Stacy |
To make steam to drive a turbine to turn a shaft connected to a propeller on a ship. Thinking back to my youth in the engine room as a member of Uncle Samβs canoe club.  |
Posted: Fri Mar 12, 2021 4:06 am Post subject: Re: Help ordering correct hot water heater parts |
Enquiring minds still want to know if L got a couple of thermo piles or a pile of thermo couples.
Thanks for cleaning up, J. Did you have enough hot water ? _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13551 Location: Tejas!
Posted: Fri Mar 12, 2021 12:49 pm Post subject: Re: Help ordering correct hot water heater parts |
| 4 years sucks. Just replaced one myself and if I have to do it again in 4 years I'll be pissed. The last one was from 2004 |
Posted: Sat Mar 13, 2021 4:57 am Post subject: Re: Help ordering correct hot water heater parts |
Yes Abscate I received a Pilot/Thermopile Assembly under warrantee.
Unfortunately I broke & dislocated my rib slipping on ice and falling down brick stairs over 3 weeks ago. Long slow heal still sleeping on a chair leaving me exhausted and doctors give no method to heal but tell you not to get hurt again as it will puncture my spleen. UGH!
Back to the "hot water tank and the pilot light" I am unable to replace the new Pilot/Thermopile Assembly with my broken rib although I am now able to light the pilot & light grateful for hot water
I may call my installer and have them install but not until I get the vaccine. It's been a long slow heal 2 to 8 more weeks to hopefully heal back to normal.
| Abscate wrote: |
Thanks for cleaning up, J. Did you have enough hot water ? |
Maui Roadsters
| Lind wrote: |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 614 Location: Triad Area NC
Posted: Fri Apr 02, 2021 12:10 pm Post subject: Re: Help ordering correct hot water heater parts |
| Abscate wrote: |
459 Kelvin is 186 Celsius or 367 Fahrenheit.
(Temp in K = 273 + Temp in C)
Where is your room located? You may want to move  |
Posted: Fri Apr 02, 2021 6:10 pm Post subject: Re: Help ordering correct hot water heater parts |
| AirHead1966 wrote: |
| Abscate wrote: |
Iβll look for some better units, itβs getting a bit Rank in here _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Wed Apr 21, 2021 3:25 am Post subject: Re: Help ordering correct hot water heater parts |
Saga continues:
Finally got my second vaccine for covid and had the installer/seller of my A.O.Smith tank install the thermopile to cover my warrantee. I went back to work and 3 hrs later the pilot light was out again. When the technician installed the thermopile he said it didn't look bad and thought maybe it was the TCO (thermo cutoff switch) and have A.O.Smith send me a new one also covered under warrantee. Now I have my $133. service invested after the $$ for this new heater in 2017 and yet have no solution.
I called A.O.Smith and the technician had me test (I sent photos and video) ventilation as well as see the vent pipes installed. They said it was venting properly. They also said the gas pressure tested. They also said the switch is not bad because it does trip and reset which means it is doing what it is supposed to. The TCO switch trips to prevent unburned gas from being released into the house.
This video was very helpful to learn more, the next one shows how to test that switch which I will do after school (I'm a teacher) although I've never seen OL (open loop) on my digital multimeter which should be interesting. I'm exhausted. BTW the company I bought it from said "the technician said get the switch. I am frustrated and will relay what the technician at A.O.Smith told me and test the switch. I feel like ripping the heater out with my bare hands and boil my water LOL. More to come.
Great explanation "how they work":
How to test the TCO:
Maui Roadsters
| Lind wrote: |
