metoooo Samba Member
Posted: Fri Dec 25, 2020 6:03 am Post subject: Engine cuts out under load |
Hi. My 1600cc twin carb engines starts recentelly to cut-off under load at high gears. When i rev it up in standing, it works perfect. I've replaced spark plugs and adjust the ignition, carbs and valves, but the problem stays. Any sujestions how to solve this issue? Could bad fuel pump cuase this issue? |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13948 Location: White Mountains Arizona
Posted: Fri Dec 25, 2020 6:44 am Post subject: Re: Engine cuts out under load |
Try replacing the condenser. I also had an issue like that, swapped out the whole distributor with spare one. Then one component at a time. It was the condenser . _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Fri Dec 25, 2020 8:10 am Post subject: Re: Engine cuts out under load |
gt1953 wrote: |
Try replacing the condenser. I also had an issue like that, swapped out the whole distributor with spare one. Then one component at a time. It was the condenser . |
The condencser only have 2,000 km on it, but i'll replace it anyway. Hope it solve the problem. Thanks |
vwfye Samba Member
Posted: Fri Dec 25, 2020 9:18 am Post subject: Re: Engine cuts out under load |
Condensor not condensing... _________________ 64 No'back Speedster "Pearl"
LME "Little Giant Killer 3"
1974 Ghia "PUK" |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Fri Dec 25, 2020 12:43 pm Post subject: Re: Engine cuts out under load |
Plugged up fuel sock in the gas tank.
All the crud will settle around the fuel sock. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
gt1953 Samba Member
Posted: Fri Dec 25, 2020 2:10 pm Post subject: Re: Engine cuts out under load |
Yup clogged fuel filter would cause it to run out of fuel under load. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23394 Location: Kimball, Mi
Posted: Sat Dec 26, 2020 12:59 pm Post subject: Re: Engine cuts out under load |
A coil going bad will do this too. Especially under load. I've had that happen to me back in 2004 right be going to the Invasion. Took me a couple of days to find it (went thru every system on the engine), because the engine would idle perfectly, but under load would run like crap. In my case it was a German blue coil trying to die (the last thing I checked). Swapped it with a German black coil, and everything was fine again. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 281 Location: Richmond, VA
Posted: Tue Jan 12, 2021 7:28 am Post subject: Re: Engine cuts out under load |
I had the same problem. After reading this thread, I put in a new condenser and it's fixed. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1887 Location: NORTH HOLLYWOOD,CA
Posted: Tue Jan 12, 2021 9:36 am Post subject: Re: Engine cuts out under load |
Also check fuel tank vent, could be clogged.
Easy to check, just drive it with the gas cap off. |
Posted: Tue Jan 12, 2021 9:51 am Post subject: Re: Engine cuts out under load |
It was the condenser... problem solved |
vwfye Samba Member
Posted: Tue Jan 12, 2021 10:12 am Post subject: Re: Engine cuts out under load |
It used to be that condensors either worked, or did not. These days partially failed condensors seem to be the new norm. _________________ 64 No'back Speedster "Pearl"
1974 Ghia "PUK" |
