vwuguy  Samba Member
Joined: November 01, 2005 Posts: 1070 Location: southwestern ontario, on and netherlands and bc
Posted: Fri Jan 29, 2021 4:52 pm Post subject: How to install new mirrors on your baywindow bus 1968-1979 |
please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy |
richparker Samba Member
Joined: November 24, 2011 Posts: 7822 Location: Durango, CO
Posted: Fri Jan 29, 2021 6:06 pm Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
Erb, everybody knows you have to angle those mirrors in order to fit in with the cool kids around here…🙄 _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab |
Joined: January 01, 2007 Posts: 17995 Location: sticksville, ct.
Posted: Fri Jan 29, 2021 7:35 pm Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
pulls tape off (takes paint with it )
puts new mirror on without gasket
oh, my head.... _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
Angus II Samba Member
Joined: June 01, 2016 Posts: 724 Location: Mammoth Lakes Ca. 93546
Hello,
An 9/16 wrench on a"made in China" part? Humm?. OK....
And, Do you really have a (PPE) Covid face mask on?
You're alone, outside. In the wind....
You've got to be fucking kidding me.
Well, at least. You didn't take the doors off the bus to install the mirrors. I've got to give you a plus for that, this time..... |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1785 Location: Newmarket, ON
rsbadura Samba Member
Joined: November 30, 2009 Posts: 778 Location: Berlin, Germany
Posted: Sat Jan 30, 2021 12:52 am Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
failed
I do not see the plastic washer VW #311857543 below the mirror to protect the door paint:
see 082-00 part 12: http://www.michaelknappmann.de/bulli/michaelk/vw_bus_d/fiche/t208200.html
Before mounting it, a little bit of grease or cavity protection putting inside the door hole would be a good idea.
It's strange how people today require a video for every simple task not only in this case... it looks like I'm getting old
| Globespotter wrote: |
| My mirrors are loose on the arm. How do I tighten them? |
I guess these are only reproductions - and not original VW?
(originals have a VW sign and part number at the nut to the door side - only visible if unmounted).
Only as an idea (never had this issue):
have you tried to put an extra washers (soft metal, nylon, plastic) below the nut to get some more friction drag?
In the original there is a metal spring inside to get this friction drag. _________________ Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools collection |
Mberglo Samba Member
Joined: January 13, 2020 Posts: 387 Location: Huntsville, AL
Posted: Sat Jan 30, 2021 7:10 am Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
| Ten minute video to screw a mirror onto a door? |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 788 Location: Milwaukee
Posted: Sat Jan 30, 2021 9:11 am Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
| Mberglo wrote: |
To be fair, he did both sides. _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
Posted: Sat Jan 30, 2021 10:29 am Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
Hello,
If what rsbadura said wasn't the problem. And, we are both getting old Stephen...
If the mirror won't stay in place on the arm and you have too readjust it to see(mirror loose on arm) as I understood the issue. You will have to remove the glass from the housing and tighten the nut too increase the pressure.
Here are some pictures of whats behind the glass
You need to tighten up the ball and socket joint/connection. Ignore the drivers side note on the mirror housing(they will fit any side) it was to written in reference too the arms which are directional. |
Posted: Sat Jan 30, 2021 9:09 pm Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
| Angus II wrote: |
Hello,
Thanks Angus - yes that's the problem. I wonder if pulling and turning the mirror could possibly tighten the nut without removing the glass? They are re-pops but in good shape. It just annoys my how loose they are. Not sure how easy or wise it would be to try to remove and replace the glass. _________________ 1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382 |
Posted: Sun Jan 31, 2021 11:37 am Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
Hello,
You may give that a try.
But, I should have posted more pictures....
The stud that makes up the connection is squared off at the base keeping the cupped part of the ball and socket from moving.
It's not hard to cut the outer edge of the mirrors seal/gasket. And to reinstall mirror use vinyl caulking compound not silicone(it's easier to clean up). And, if you do happen to break the glass, a glass shop can cut a piece to fit. It only cost me $4 each to have new glass cut too size.
Good luck with the project.
I'd rather fix an OEM part than buy aftermarket parts....that's just the way I am. |
Posted: Sun Jan 31, 2021 2:13 pm Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
| skills@eurocarsplus wrote: |
oh, my head.... |
Where can I find these gaskets? My old mirrors didn't have them. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10808 Location: the past
Posted: Sun Jan 31, 2021 2:25 pm Post subject: Re: How to install new mirrors on your baywindow bus 1968-1979 |
| got it. Thanks. |
