Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1790 Location: Mouth of the Columbia
Posted: Wed Jan 27, 2021 2:01 pm Post subject: Help me identify this highroof |
Hi - I need to identify this highroof. I need to remove it to replace the old seal underneath. Ideally I’d like to find someone who has removed/replaced one. I need to know how the floor and bulkheads in it are attached to the roof without tearing the shit out of it. It has the aluminum channel with screws in it on the surround. The rubber? insert that covers the screws is long gone.
This 74 was delivered new in Eugene. Not sure of the top manufacturer. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
Starbucket Samba Member
Posted: Wed Jan 27, 2021 4:12 pm Post subject: Re: Help me identify this highroof |
| It's a Westfalia high top. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53251 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jan 27, 2021 5:17 pm Post subject: Re: Help me identify this highroof |
| Starbucket wrote: |
Now just what makes you say that, please enlighten us.  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mikewire  Samba Member
Joined: March 22, 2010 Posts: 862 Location: San Antonio, TX
Posted: Wed Jan 27, 2021 7:54 pm Post subject: Re: Help me identify this highroof |
More info: It has the sliding sunroof still installed. When I got it it had a Westie interior with the fold up bed, no stove, sink, fridge. Who knows if it’s original.
I have seen tops with a similar profile but they usually have window/s. The plywood floors in the fore and aft areas are fastened to ribs/joists on 16”? centers front to back with brass woodscrews. The ribs sit on the roof, separated by what looks like strips of paper. I just can’t tell how they’re attached to the roof or if they’re attached to the top at the ends. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
Posted: Thu Jan 28, 2021 8:20 am Post subject: Re: Help me identify this highroof |
| busdaddy wrote: |
| Starbucket wrote: |
Just google westfalia high top images and you will see them. His was probably a work van that's why there are no windows. |
Posted: Thu Jan 28, 2021 8:41 am Post subject: Re: Help me identify this highroof |
| Starbucket wrote: |
| busdaddy wrote: |
| Starbucket wrote: |
It's not quite the same, and a Westy would be a pop top. What you would be seeing out there in the image search is most likely the Adventurewagon, which isn't the same conversion as Westfalia. There's a few clones and other aftermarket high tops, and the PO's would be one - nothing wrong with it, very unique and interesting history I bet.
This is an example of early Bay Adventurewagon:
A slightly later version would be our friends from Kombi Life, Ben and Leah's 1973, Boomerang:
_________________ -Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe 221(5) w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue |
Posted: Thu Jan 28, 2021 9:04 am Post subject: Re: Help me identify this highroof |
Exactly, it's the same Google that says any camperized VW regardless of make is a "Westfalia". Westfalia never made a high top for their VW conversions, VW themselves offered a cargo van with a high roof built in their factory, but it looked dramatically different than that one and had nothing to do with Westfalia.
Since the bus is 2 tone with no jalousie windows it's likely a deluxe that had the top and camper equipment added later, it may even have been done by a PO using parts sourced from the junkyard. The top doesn't look familiar, but there were many versions made by many companies, everyone was getting into camper conversions around that time. It may have even come from a fiberglass shop that supplied other makers as a bare shell with no windows that the PO installed himself.
Here's a selection of OTW campers to look through, you might spot something similar: https://www.thesamba.com/vw/forum/viewtopic.php?t=288111 Sadly it's another great thread that's partially spoiled by not using the Samba gallery to post the pics in. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 28, 2021 11:37 am Post subject: Re: Help me identify this highroof |
| busdaddy wrote: |
From the Samba Mermaid the bus
HoboBus Samba Member
Joined: December 29, 2016 Posts: 350 Location: Not Key West, unfortunately.
Posted: Thu Jan 28, 2021 1:57 pm Post subject: Re: Help me identify this highroof |
| Lil Lulu wrote: |
The vinyl strip that goes in the channel should be pretty generic RV stuff.
Go to Amazon, or your local RV dealer. Search "RV vinyl insert screw channel cover trim"
I saw 3/4" wide and 1" wide. A 50 ft roll is like $20 or less.
Your channel should have ribs on the side that hold the trim.
Good luck! _________________ Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus. |
chachi Samba Member
Posted: Thu Jan 28, 2021 2:14 pm Post subject: Re: Help me identify this highroof |
this is the only other one of that particular hightop I have seen, spotted in Cle Elum, Wa. in 2017. sadly, I didn’t take interior shots but this bus was heavily modified anyway.
_________________ '74 transporter panel
'91 vanagon carat NAHT |
Posted: Thu Jan 28, 2021 5:37 pm Post subject: Re: Help me identify this highroof |
Chachi - That’s the only one I’ve seen with that figure molded into the side like that. Looks like it adds stiffness to the side like a bend in metal.I’ll see if I can upload a couple more images. Thanks for the replies. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
Posted: Thu Jan 28, 2021 7:55 pm Post subject: Re: Help me identify this highroof |
| look for a plaque with mfg. decaL/Plaque with mfg.s name somewhere on the van. |
nemobuscaptain Samba Member
Posted: Thu Jan 28, 2021 9:09 pm Post subject: Re: Help me identify this highroof |
Google search does come up with a few high tops that have that side profile body line. Heres one.
Heres a youtube video that looks like it. They call it an Adventurewagen.
Notice the windows are different on these two.
Posted: Fri Jan 29, 2021 8:25 pm Post subject: Re: Help me identify this highroof |
A view of pass side rear highroof bulkhead showing the sunroof below.
The same bulkhead with door closed.
These represent the good part of this story.
The right rear window has no wing component like a camper. That, plus the fact that the installation looks consistent with pretty good construction standards of the day, inclines me think that this was some sort of factory show. Everything looks relatively unfuckedwith. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
Posted: Fri Jan 29, 2021 8:30 pm Post subject: Re: Help me identify this highroof |
| Have you looked around for an I.D. plaque? |
Xevin  Samba Member
Posted: Fri Jan 29, 2021 8:55 pm Post subject: Re: Help me identify this highroof |
Where was it delivered from Germany. Maybe a clue on regional conversion companies in the area. Just a thought. _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
Posted: Sat Jan 30, 2021 3:06 am Post subject: Re: Help me identify this highroof |
Original delivery was Eugene according to M-plate. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
Xevin  Samba Member
Posted: Sat Jan 30, 2021 8:17 am Post subject: Re: Help me identify this highroof |
| Lil Lulu wrote: |
| Original delivery was Eugene according to M-plate. |
Wow!! Eugene, Oregon has its own Export code? What is it? I couldn’t find it here. I thought in your first post you meant it was sold from a dealership in Eugene. My bad.
https://www.thesamba.com/vw/archives/info/exportcodes.php _________________ Keep on Busin'
| Clatter wrote: |
| SGKent wrote: |
