velvetgreen Samba Member
vwuguy  Samba Member
Joined: November 01, 2005 Posts: 1061 Location: southwestern ontario, on and netherlands and bc
Posted: Sun Feb 21, 2021 8:46 pm Post subject: Re: 50s bus for fun |
Looks fancy must be steel.. better than nothing that was there before still needs paint bodywork ect.. lawn art.. _________________
please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy |
vwuguy  Samba Member
Posted: Mon Feb 22, 2021 4:36 pm Post subject: Re: 50s bus for fun |
today spent the day getting all the leaves and crap out of the front storage tool box and nose..
Then put a couple cross braces in where the non-existant floor was i guess they may qualify as the floor.
added a brace to the lower front and previouosly i cut the lower bulkhead to gain access to where I am gonna do some frame repairs..
bought new crossmember for here
the lack of floor it was so rusted i lifted the mat and it all deterioted rt there into dust.. yay floor dust.. and the shifter it fell off by hand with some grinder convincing..
its a neat piece of lawn art[/img] _________________
vwuguy  Samba Member
Posted: Wed Feb 24, 2021 8:18 am Post subject: Re: 50s bus for fun |
yesterday installed early accessory gauge installed. I think its a stewart werner
found it in a spare parts box..
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10803 Location: the past
Posted: Wed Feb 24, 2021 9:54 am Post subject: Re: 50s bus for fun |
your "welding" is atrocious and unsafe. |
vwuguy  Samba Member
Posted: Wed Feb 24, 2021 10:57 am Post subject: Re: 50s bus for fun |
yeah need more practice..if you or one of your friends wanna show me how to weld better that would be appreciated..hazetguy. . any suggestions on how to improve it _________________
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Wed Feb 24, 2021 11:44 am Post subject: Re: 50s bus for fun |
I know this is going to sound harsh and I love your enthusiasm so I don't want to extinguish it. My purpose here is simply a reality check based on years of experience.
What you want to do requires far greater skills and experience than what you have, or a kind local mentor to teach you as you go. It requires a semi-heated shop with a clean solid floor, and at least some heat. You will need proper welding equipment, and that means no flux core. Additionally you will need many tens of thousands of dollars. Without those, you will not finish and worse, you probably will do a bunch of damage to the bus that somebody else will have to undo.
Can you put this project somewhere out of the weather until you have the knowledge, funds, facilities and experience to be successful? |
vwuguy  Samba Member
Posted: Wed Feb 24, 2021 12:27 pm Post subject: Re: 50s bus for fun |
well thanks..proof it can be done https://www.youtube.com/watch?v=z_aoJDpkjmM&t=461s
and if thats not movie magic I am about to prove it can be done _________________
Posted: Wed Feb 24, 2021 2:35 pm Post subject: Re: 50s bus for fun |
step 1: clean the metal you want to weld. trim back to solid metal. not rusty, painted, tissue paper thin gunk you want to try to weld thicker metal to.
step 1.5: practice welding (welder settings, spped of moving the torch, etc) on similar thickness metals to the thicknesses you want to actually weld - metal that is not part of the bus. this means using the metal thickness and appropriate wire speed chart on the welder to get approximate starting settings and adjust from there. the finished product is not the place to be practicing.
step 2: make sure your ground is on a solid, shiny metal area, close to the area you want to weld.
here are a couple videos i found on the tube of you, with a very simple 'basic mig welding techniques' search. i'm sure you can find plenty more by doing your own searching.
https://www.youtube.com/watch?v=UdFZPvDyrZ4
https://www.youtube.com/watch?v=Xod-ByrxHg4
you might also find this video helpful.....
https://www.youtube.com/watch?v=RLMTnXjaptw
also, if available, taking a welding class at a local community college would help a lot. |
vwuguy  Samba Member
Posted: Wed Feb 24, 2021 3:58 pm Post subject: Re: 50s bus for fun |
todays progress
definately took my time and tried some of those tips seem to be getting a bit better at this.. thanks really appreciate that
just tacked on some small frame pieces so i can take it off the jack stand holding it up and move it. it took a lot more time.. worth it though
RambosRide Samba Member
Joined: August 26, 2020 Posts: 38 Location: Pacific Northwest
Posted: Wed Feb 24, 2021 6:47 pm Post subject: Re: 50s bus for fun |
vwuguy wrote: |
yeah need more practice..if you or one of your friends wanna show me how to weld better that would be appreciated..hazetguy. . any suggestions on how to improve it |
I don't know if I missed it...but what are you welding with - I'm assuming a 110v mig welder?
Machine make and model?
Flux or Gas Shielded?
Machine settings : voltage, wire speed and if gas shielded Regulator settings?
Welding wire size and make? |
vwuguy  Samba Member
Posted: Thu Feb 25, 2021 3:57 pm Post subject: Re: 50s bus for fun |
todays progress
apparently this is how you use a magnetic clamp is that correct?
had it perfectly flat but it didn't look rt so added some extra weld on there to give it that patina look..
oh yeah that completes replacing the rt frame getting closer to a solid storage shed..
other things i did were major cleaning of the engine bay but that is borring stuff I hope you have a grateful night! cheers see yeah tmo.. _________________
vwuguy  Samba Member
Posted: Thu Feb 25, 2021 4:08 pm Post subject: Re: 50s bus for fun |
RambosRide
i'm just welding 1/8" 3mm 1040 steel with flux core don't need anything serious for it
got it on low amp and feeding about 1/16 /sec
do you got a video you made on youtube on that stuff>?
velvetgreen it was steel just painted it hows your ride? _________________
vwuguy  Samba Member
Posted: Fri Feb 26, 2021 4:06 pm Post subject: Re: 50s bus for fun |
todays progress cut out frame crossmember
vwuguy  Samba Member
Posted: Sat Feb 27, 2021 4:52 pm Post subject: Re: 50s bus for fun |
todays progress just finished cutting the center crossmember out. strarted on this left frame part. got the template made up just trying a piece to see if it will work.
vwuguy  Samba Member
Posted: Sun Feb 28, 2021 6:18 pm Post subject: Re: 50s bus for fun |
todays progress ain't pretty but better than that giant gaping no frame it had before ..
do you got any pics of your front frame repairs? post em up! _________________
vwuguy  Samba Member
Posted: Mon Mar 01, 2021 6:14 pm Post subject: Re: 50s bus for fun |
todays progress welded in these inner pieces for the crossmember gonna tackle the front rust at a later date once i can move the bus and put it on jacks..
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 844 Location: Oregon
Posted: Mon Mar 01, 2021 6:46 pm Post subject: Re: 50s bus for fun |
This is the most entertaining thing on the entire internet right now
 _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
sled Samba Member
Posted: Mon Mar 01, 2021 7:22 pm Post subject: Re: 50s bus for fun |
and an absolute disaster. This bus should never be driven on public roads. _________________ drive your split. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3939 Location: 1 hr north of Santa Barbara
