Welding & Bending Seal Channel/2 Questions
brookmp
brookmp is offline
PostPosted: Sun Mar 28, 2021 4:32 pm    Post subject: Welding & Bending Seal Channel/2 Questions Reply with quote
Restoring my '74 Standard Beetle. My front hood and rear engine seal channels are shot. We've removed them and purchased new seal channels from Wolfsburg West and hope to weld them in soon.
Question: what is the BEST way to bend these straight pieces of channel into position for welding?
Question: what is the BEST method for welding them in?
I appreciate any and all advice and experience anyone's had with these.
1968 Westfalia Campmobile
1971 Double Cab Pick-up
1974 Standard Beetle
beetlenut
beetlenut is offline
PostPosted: Sun Mar 28, 2021 7:14 pm    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
The original ones were spot welded on about every 3-4 inches. I went with the Mexi seals once I removed the old seal channels, and repaired the rust under them, but I did have to replace the top hood seal channel by the wipers. The replacement metal bends fairly easily. I ended up using panel adhesive with some pop rivets to hold it in place while the adhesive set up. My reasoning was that the panel adhesive would seal that area under the channel and not let corrosion form again.
If you're going to weld them on, get the basic shape bent into them, and then as you weld each plug weld, you can further bend/shape the seal as you go.
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
bomberbob
bomberbob is offline
PostPosted: Mon Mar 29, 2021 4:42 am    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
I did the same exact thing. Cut out all the rusty channel and cleaned it up, and fixed the rust holes that were hiding behind it. Bought mexi seals, and panel glued in the seal on that edge by the wipers. I just used C clamps to hold it where I wanted it till the glue dried. I used 3M 08115. I have actually taken a liking to this glue, and use it whenever possible as an alternative to welding (non-structural items).
1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa
Q-Dog
Q-Dog is offline
PostPosted: Mon Mar 29, 2021 7:04 am    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
Find a curved object with a similar or slightly smaller curve than what you are fitting to. Slowly bend the channel around that object so you don't kink it. Ideally you would bend it around something that has the same profile as what you are bending so you don't smash the channel, but if you go slow you should be OK.
Don't start welding until you have the fit really close or you will put a kink in it somewhere.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
RLFD213
RLFD213 is offline
PostPosted: Mon Mar 29, 2021 7:22 pm    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
I did mine this summer and instead of welding it I used panel adhesive and a lot of vise grips to keep it in place. Just another way of doing things.
vwsplitman
vwsplitman is offline
PostPosted: Wed Mar 31, 2021 5:35 am    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
The best way to bend these pieces to the correct contour without kinking them is with a shrinker/stretcher. Have done many this way. Just have to find someone that will let you borrow one.
marklee
marklee is offline
PostPosted: Fri Apr 02, 2021 11:37 am    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
excellent advice, the panel bond will help stop water getting between them and the body of the car too, preventing corrosion
CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver
brookmp
brookmp is offline
PostPosted: Fri Apr 02, 2021 8:30 pm    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
Thanks for the replies....
What we ended up doing worked pretty good for our situation. We have a donor bug and were able to use its rear apron to form the seal channel into the right position. We used a high heat torch and gently heated up the metal and slowly bent it into place. It's in the correct shape to be welded onto my Bug now.
New question:
We are already planning to use seam sealer in addition to welding the piece to the car body. Would there be any advantage to using a panel adhesive instead or in addition?
Thanks,
Brook
challomoner
challomoner is offline
PostPosted: Sat Apr 03, 2021 2:15 am    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
Panel adhesive cures the rust trap problem as it fills the seam and won't allow water between the two parts.
hsosa1
hsosa1 is offline
PostPosted: Wed Sep 18, 2024 11:19 am    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
Any pictures ? How did the adhesive last it’s been a few years thanks
Just Cruzin Sur Califas VW Car Club est♤1998
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
bomberbob
PostPosted: Mon Sep 23, 2024 7:20 pm    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
I will take a photo or two tomorrow, the only spot I used the channel was along the rear of the frunk, near the windshield wipers. Everywhere else I removed the channel, cleaned it up and used mexi seals. and I like them.
Marion, Iowa
RLFD213
RLFD213 is offline
PostPosted: Tue Sep 24, 2024 2:14 pm    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
Hsosa I don’t have a picture right now, but it’s still all good. No problems at all.
bomberbob
PostPosted: Tue Sep 24, 2024 5:24 pm    Post subject: Re: Welding & Bending Seal Channel/2 Questions Reply with quote
I went out to take a photo, can't see anything with the seal in place andI don't want to remove the seal just for a photo.
Marion, Iowa
