modok Samba Member
Joined: October 30, 2009 Posts: 27677 Location: Colorado Springs
Posted: Sat Mar 11, 2017 8:37 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
Not sure I yet mentioned this one. This one is really secret, so secret I didn't remember I knew it.
to get more grip on a flathead screwdriver, i put a dab of red locktite on the tip, then dip that in fine abrasive powder, then hit it with the torch lightly to cure the loctite quick.
Just earned me another 40 bucks. Friend asked "how did you know to do that?" I don't know. Maybe my father taught me that one.
probably works on more than just screwdrivers
If I mentioned it before, sorry, but maybe I didn't. I don't remember much
NEW locktite related trick
When using 518 sealant, red threadlocker, or green goop(sleeve retaining compound)
on stainless, aluminum, primer is needed according to instructions. It needs to be on fresh metal to cure but stainless or aluminum the surface is oxide and it won't cure.
I have mentioned before scuffing the surface with scotchbrite or abrasive paper lightly before applying will speed cure and not require primer.
TINY stainless screws ect, you can't sand it.
NEW idea, use fine brass wire brush. The microscopic streaks of copper left on surface will act as primer. I try this, it WORKS. Loctite FOR ALL! |
RolandD Samba Member
Joined: January 15, 2017 Posts: 279 Location: Menomonee Falls, Wis
Posted: Sun Mar 12, 2017 8:04 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
please forgive me if this has been previously mentioned. It will be hard to explain.
On an exhaust stud, for example, start with a thick plate of steel and make a slot for the good stud, and drill and tap 3/4" fine hole for the broken stud. Take a 3/4" fine bolt and drill it on the lathe with the tap drill of the broken stud thread. Bolt the plate firmly up to the head with the good stud. Thread in the 3/4" bolt and drill to dimple the end of the broken stud. Remove the 3/4" bolt and view if you are centered. Adjust accordingly. Dimple again. When centered, drill out the stud and remove the remains like a helicoil insert.
The above works well on C-12 Cat motors.
As for penetrating oils, I have found Penetrol90 by Schaefer to out perform all others.
Crazy Roland |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
modok Samba Member
Posted: Tue Mar 14, 2017 4:41 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
RolandD wrote: |
On an exhaust stud, for example.
Crazy Roland |
Gotcha. I'd call it "A drill guide"
For drilling exhaust studs on a chevy 4.3 or v8 I made this "drill guide". The drill has a u-joint because there was no space to do otherwise.
It worked, three times so far  |
Posted: Tue Mar 14, 2017 7:40 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
Modok - true that, a drill guide. The difference is that it is made from a large bolt, so that you can unthread the bolt/guide to see if you are centered and adjust accordingly, without disturbing the setup.
Crazy Roland |
the2ndcashboy Samba Member
Posted: Tue Mar 14, 2017 9:05 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
We use something similar for several things in aircraft structures work http://www.yardstore.com/drill-block-drill-bar-for-slip-fit-bushings.html
You can get a number of different sizes of drill bushings, and there's even a bombsight insert if you need to get super accurate. _________________
SRP1 wrote: |
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones. |
modok wrote: |
If anything comes out perfect it just means your measuring tools are substandard. |
modok Samba Member
Posted: Wed Mar 15, 2017 12:52 am Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
RolandD wrote: |
Crazy Roland |
True! I only have a 12mm hole to look through(used valve guides), but that was ok, for what I was doing there was not enough room to see anyway. Another one I use has a 1" hole, and many bushings to fit in the hole for different drill sizes, but most of them are quite worn at this point. |
Posted: Wed Mar 15, 2017 7:15 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
True that. Your eyes must be better than mine, I need all the help I can get.
Crazy Roland |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1637 Location: Anderson, SC
Posted: Fri Apr 14, 2017 9:28 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
I need to remove 40 "hammer drive screws" that weren't meant to be removed. I'm restoring a set of old 5 spoke wheels and there are two screws per spoke that need to be removed to separate the center from the barrel. The wheels are steel rim with aluminum centers. The head of the screw is about 5/8 - 3/4" in diameter and the shaft is about 3/8 - 1/2". Supposedly from my research they are super hardened and drilling/grinding won't work.
I found one post about making a large/hot weld blob on top of the head, then welding a wheel bolt to that, then using a 1/2" impact to back them out. I'm thinking that may work but I wanted to ask here first before potentially ruining my wheel centers. I'll be putting the rims into new chrome barrels so any damage to the rim won't matter.
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
modok Samba Member
Posted: Fri Apr 14, 2017 10:28 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
That's basically the same as used to secure ID plates to blocks, and heat shields to the underside of intake manifolds on most americal V8
Usually use a chisel to whack them side to side and that may loosen and lift enough to grab and twit out with vise-grips, but some refuse to move.
A darn handy tool is a slide hammer with a vise-grips on the end. I'd want to just weld a glob on it, clamp the blob while still glowing and pluck!
weld-a-nut sounds good too, you'll need a lot of nuts I guess.
To put them back in, just coat with locktite and put back in. |
modok Samba Member
Posted: Thu May 16, 2019 9:47 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
modok wrote: |
I only get about 50% with weld a nut, but weld a blob is better, probably 75%
it breaks right at the weld, but the blob.....why, the blob has no sharp changes in section  |
Improved blob welding technique has improved probability to over 90% for studs stuck in aluminum.
Weld-a-nut is OBSOLETE , BLOB far superior.
Why?
weld-a-nut has stresspoints, sharp change in section at the back side of the plug weld.
If I build up a blob, and clamp it with vise-grips while still glowing, I have FORGED a nut, and it's stronger. of course it takes some patience to build up a good size blob, have to weld, wait, weld so forth, but it sure saves on nuts.
Weld a blob, forge into nut,
THEN hit it with a hammer twice.
THEN try turning both directions. Get it to wiggle, then you've won.
For sizes larger than 10mm, the grip of the vise-grip on the blog may be not enough. My late friend mike had the idea, just weld the vise grips onto it. it worked
just an update, a few hundred of these jobs later.... just a little smarter
EZ money |
rodeking Samba Member
Joined: October 09, 2017 Posts: 375 Location: FL, Ontario
Posted: Sun May 19, 2019 7:07 am Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
Here's how I do Porsche engines with 'Dilavar" head studs. Dilavar was Porsche's bright idea of a steel alloy that matched the thermal expansion rate of aluminum. They achieved that objective but unfortunately it was very susceptible to corrosion stress cracking over time. Dilavar cannot be drilled with HSS or carbide. This was on a '76 Turbo that had about 12 broken studs, three of them broken flush. I make a SS collar that fits around the stud, fill it with MIG running at 180 and zap it with quick trigger bursts allowing just enough time in between so the puddle doesn't slump. Run it hot to get immediate fusion. Build it up with the MIG, weld on a nut, judiciously heat with with the OA and they come out.
nsracing Samba Member
Posted: Tue Aug 20, 2019 6:18 am Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
They come out from all that welding heat, don't they?
I have a tap desintigrator I remove studs with. It is kind of like EDM but for just removing studs. At some point I will have a proper EDM machine for more specific work. |
modok Samba Member
Posted: Fri Apr 02, 2021 2:50 am Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
TEN YEARS. not much has changed.
8mm and below, I still weld them up and "hot forge' it into a wing nut with vise-grips and that works most of the time.
Larger than 8mm broken bolts/studs it is usually necessary to weld something on the end to get enough grip.
I have a NEWish co-worker who has SOME interest in dabbling in the dark arts.
a few weeks ago I saw he was attempting the weld-a-nut idea.....and it broke off.
I explained that it works poorly because that design of joint results in a brittle stress point and ect ect....
I said sarcastically....
"maybe you should turn the nut 90 degrees and weld it on that way, it might work better"
AND IT DOES
Why the heck is that? yeah good question. I think it's because the root of the weld tends to be brittle.
Employing the weld-a-nut technique....normally, the root of the weld ends up the point of highest stress when you twist it....so it easily cracks off, BUT,
If you build it up a little, then introduce the nut while it's still glowing, and weld it on the wrong way, both sides......then the root of the weld is in the center, NOT a stress point.
And using a nut, which is hollow, tends to be a better thickness match than using a similarly sized solid object.
Seems to be 30-50% stronger on average.
So, NEW amendment.
weld-a-nut now FULLY endorsed, BUT you don't weld it on there the intuitive way, turn it 90 degrees  |
ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 349 Location: Right Coast, Florida
Posted: Fri Apr 02, 2021 6:51 am Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
Back when I worked at a power plant, we used to use ( Duratrode stud pull electrode ). It was a welding rod made special for welding a nut onto broken studs to screw it out. They worked really well as long as you got lit off at the top of the stud / bottom of the nut, filled in the nut. Not sure if they still make it. _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1025 Location: South Florida
Posted: Fri Nov 22, 2024 6:49 pm Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
Gearbox arrived via UPS with broken nose cone stud, which I fix'd, thanks in no small way to this thread. Spent a week using Automatic Transmission Fluid mix'd with Acetone as a penitrant (note pink fluid on broken stud end), tapping with hammer (note chip'd off paint) while in hot Florida sun:
Built a jig to help guide drill concentrically, using tooth pick to make sure not to drill completely thru stud bottom, side view:
Looking down thru jig hole:
Almost got too carried away drilling wider & wider hole, became worried remaining sides would collapse or come out leaving part of stud behind; especially 'cuz the 1 extractor in the cheap set from Harbor Freight even close to a fit, bottom'd out without contacting. Extractor was too hard to hack saw or even dremmel; but brittle enough for me to clamp in vise, smack with sledge, break off its end, and leave me with success:
Cusser Samba Member
Joined: October 02, 2006 Posts: 33102 Location: Hot Arizona
Posted: Sat Nov 23, 2024 7:52 am Post subject: Re: Removing broken studs & the ez-out conspiracy, epic |
MrGoodtunes wrote: |
Gearbox arrived via UPS with broken nose cone stud, which I fix'd, thanks in no small way to this thread. |
Great job !
If this gearbox was purchased from a company I would've contacted them and let them absorb the bill for a machine shop to extract that broken stud, they should've packaged the gearbox better.
I've rarely broken studs or bolts, but have used EZ-outs when the bolt or stud is not rusted in (which could break the EZ-out). I also have a set of left-hand drill bits which I would use for this. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
