CV Joint set up
Gkholcombe
Gkholcombe is offline
PostPosted: Fri Apr 09, 2021 7:52 pm    Post subject: CV Joint set up Reply with quote
I bought new Lobro CV Joints and they have different lines then my old ones. What side faces the axle? And is the pictured one set up correctly? Thanks!
MarkWard
MarkWard is offline
PostPosted: Sat Apr 10, 2021 5:12 am    Post subject: Re: CV Joint set up Reply with quote
Looking at the last picture, it’s assembled so that the upside goes on to the shaft. I’m basing that on the taper face of the grooves where the shaft inserts and the angle machined into the cage.
djkeev
djkeev is offline
PostPosted: Sat Apr 10, 2021 5:51 am    Post subject: Re: CV Joint set up Reply with quote
I've come to accept the cage bevel concept.
Flip it over, the other side should be milled flat across the width.
Dave
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Sat Apr 10, 2021 6:36 am    Post subject: Re: CV Joint set up Reply with quote
good thread on direction of installation:
https://www.thesamba.com/vw/forum/viewtopic.php?t=432312&start=0
-dan
www.thefixitworkshop.com
Gkholcombe
PostPosted: Sat Apr 10, 2021 1:05 pm    Post subject: Re: CV Joint set up Reply with quote
Thanks everyone! The link to the other forum was perfect!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Apr 10, 2021 1:42 pm    Post subject: Re: CV Joint set up Reply with quote
the usual telltale is anything machined will have a "lead in" chamfered into an assembly.
the chamfer would go towards the axle shaft because it has this 'lead in' machined into it. it's purpose is to leave a "ramp" to guide something together for easier assembly
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
