Defect on CV part?
Muftobration
Muftobration is offline
PostPosted: Wed Apr 21, 2021 7:46 pm    Post subject: Defect on CV part? Reply with quote
I am in the middle of a Bostig conversion and decided to replace my CV boots and repack the joints. Here's the driver side taken apart:
After I got all the grease cleaned off, I noticed a small defect on one of the parts. These are the two best pictures I could manage without a macro lens:
Is this anything to be worried about? I did not notice any issues or noise while driving. It does seem to be within the contact patch where the ball has polished the part. These are Empi CVs that have been on the van since I bought it two years ago.
1985 Westfalia full camper - Bostig v2.0 with several updates
Syncronoid
Syncronoid is offline
PostPosted: Wed Apr 21, 2021 8:01 pm    Post subject: Re: Defect on CV part? Reply with quote
Pitting. Impending doom. Replace!
'90 Syncro Westy w/GW2.5L
djkeev
djkeev is offline
PostPosted: Wed Apr 21, 2021 11:41 pm    Post subject: Re: Defect on CV part? Reply with quote
Pfffft!
Normal wear.
Replace if you are the type to worry but grease them well and run them.
They will last many 10’s of 1,000’s of miles with proper service.
If you are worried, replace them.
If you do replace them, let me know. I'll pay for shipping instead of throwing them away.
I,d run those in a heartbeat!
Dave
Ghia
Vanagon
Beetle
Tbob
Tbob is offline
PostPosted: Thu Apr 22, 2021 4:06 am    Post subject: Re: Defect on CV part? Reply with quote
I am with Dave, Run 'em. I have been doing that for decades. It began out of necessity, and after moving to an area (the Lower Midwest) with no Volkswagen activity whatsoever, and no ready parts sources that didn't depend on shipping, became normal operating procedure. Never a failure. I would run that with no worries.
As an aside, although I had no failures, and considered the cv joints a robust part on an otherwise non robust vehicle, there may be more vibration transmitted with the worn cv joints I run than with new ones. I have never been able to tell.
1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps
MarkWard
MarkWard is offline
PostPosted: Thu Apr 22, 2021 4:44 am    Post subject: Re: Defect on CV part? Reply with quote
Run it especially if they are original vw parts.
Muftobration
PostPosted: Thu Apr 22, 2021 7:15 am    Post subject: Re: Defect on CV part? Reply with quote
Thank you all for the seasoned perspectives. I will put on the new boot and pack this with plenty of grease!
MarkWard
MarkWard is offline
PostPosted: Thu Apr 22, 2021 7:18 am    Post subject: Re: Defect on CV part? Reply with quote
As I assemble the joint, I coat all working surfaces with grease first. Once it is assembled, I then work the grease from the backside to the front working the joint through its full range. This ensures every thing is coated.
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Thu Apr 22, 2021 7:35 am    Post subject: Re: Defect on CV part? Reply with quote
This would be a wise occasion to 'flip' that joint when reinstalling, to ensure that the pitted area is no longer the primary contact area under normal running.
Just determine which way that joint will rotate and in which direction the drive force will be applied, to avoid the damaged area.
As already mentioned, the pitting is minor in this case, esp. if an OEM CV joint, and there are many more miles left in it!
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
Wildthings
Wildthings is offline
PostPosted: Thu Apr 22, 2021 8:01 am    Post subject: Re: Defect on CV part? Reply with quote
Assuming this is not on an automatic, then just swap the axles side to side when you reinstall them so that the balls run on a clean surface. By doing so you should at the very least get the same number of additional miles out of the joint as the joint already has on it.
Muftobration
PostPosted: Thu Apr 22, 2021 8:27 am    Post subject: Re: Defect on CV part? Reply with quote
This is great advice. I had heard the advice of flipping the part, but I didn't know whether that was actually possible, since it is not symmetrical front to back along the axle. You can see one side has a raised lip and the other side is flat.
My second thought was to install the axle on the same side of the van, but flipped around so the CV that was on the tranny would be on the wheel and vice versa. However, that actually wouldn't change the load surfaces; it would just change the face from driving the load to being driven.
Wildthings suggestion is perfect for my case. I have both CVs off, so I can just put this one back on the passenger side instead of the driver side.
Italjohn
Italjohn is offline
PostPosted: Thu Apr 22, 2021 8:58 am    Post subject: Re: Defect on CV part? Reply with quote
Remember to clock them during assembly
Follow me on facebook: https://www.facebook.com/norwayvanagon
My youtube channel: https://www.youtube.com/c/Italjohn
Instagram: https://www.instagram.com/italjohn/
View user's profile Send private message Visit poster's website Facebook Instagram Classifieds Feedback
Muftobration
PostPosted: Thu Apr 22, 2021 9:06 am    Post subject: Re: Defect on CV part? Reply with quote
Excellent video. Thank you. When I put new boots and repacked the passenger side axle last year, I made sure to orient the parts within a CV correctly, but I did not pay attention to how the CVs were rotated relative to one another. "Clocking" is new to me! I'll ensure they're correct this time.
?Waldo?
?Waldo? is offline
PostPosted: Thu Apr 22, 2021 3:47 pm    Post subject: Re: Defect on CV part? Reply with quote
It is necessary to clock U-Joints because they do not turn at a constant velocity and the proper clocking (and angles) allows the differing velocity to be cancelled. Unlike U-joints, CV joints operate at a constant velocity (thus the name). From what I have read, clocking them will not reduce vibration and will not increase the articulation of the joint. What positive effect do you expect from clocking them?
Also, on the CV joint rebuilding video, when it is said,"this side toward the gearbox, this side toward the wheel", that is misleading. The CV joints should be assembled so that they are symmetrical on the axle and the axle could be installed either direction without issue. It would be much more appropriate to state "this side toward the center of the axle, this side toward the outside (toward the wheel or gearbox)".
