Original 1956 Oval convertible
Page: Previous  1, 2, 3 ... 20, 21, 22 ... 34, 35, 36  Next
grailoc
grailoc is offline
PostPosted: Thu May 13, 2021 8:40 am    Post subject: Re: Original 1956 Oval convertible Reply with quote
VW_Jimbo wrote:
Typically, caster shims come into play when the front end ride height changes and the rear is higher than the front. So a “rake” stance. Dropping the front end causes the front tube to move forwards and the lower tube to move rearward. This causes a change in the caster angle. Stock caster degree is 3.33 +- 1.0 degrees. Dropping the car can get you up to 15 degrees of change. To offset this fixed change without cutting and pasting steel, most use caster shims and longer bolts.
great explanation, thanks !!
My 59 low light ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=452128
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
My oldspeed 36hp autotechnik express build: https://www.thesamba.com/vw/forum/viewtopic.php?t=670827
My garage build: http://www.garagejournal.com/forum/showthread.php?t=199438
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu May 13, 2021 9:02 am    Post subject: Re: Original 1956 Oval convertible Reply with quote
You are welcome!
My 70 Bug has a raked stance and uses one shim on the bottom tube. Before the shim, it was like a grocery cart at high speed, going down the road. Now, with the one shim and it back into spec, it flies at 95mph in a straight line!
I knew a car, that I serviced, that had 2 shims. It was a performance designed Bug. They did not have me dial in the suspension. My art was making the carbs sing! So, I know that more than one shim can be utilized if needed. But that is where my knowledge falls off.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
grailoc
grailoc is offline
PostPosted: Mon May 17, 2021 8:24 am    Post subject: Re: Original 1956 Oval convertible Reply with quote
no huge update so far but in progress into the body preparation prior epoxy primer:
I just completed the quarter panel, the outer surface has been fully guide coated to address all of the high and low + guet a perfect smooth and even surface.
1st time I am doing all of this, but learning a lot and trying to keep as less as product as possible.
Now I am progressing on the outer surface of the apron + inside trunk. I will post picture once completed.
without fender
with fender:
grailoc
grailoc is offline
PostPosted: Sun May 23, 2021 5:42 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
body prep of the front clip is now 100% complete:
working now to build a small paint booth:
grailoc
grailoc is offline
PostPosted: Sun May 23, 2021 5:43 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
67rustavenger
67rustavenger is offline
PostPosted: Sun May 23, 2021 7:53 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
The car is looking great!
In the end, all the hard work and learning will pay off with a lovely car.
That will be the envy of any who lay eye's upon it.
Keep it up. I watch for your updates.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
grailoc
grailoc is offline
PostPosted: Thu Jun 10, 2021 7:44 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
yeah thanks for the work, can't wait to be done really,
I thought I was ready for paint but found a little rust issue on the re-inforcement of the frame which I had to address before it get worse.
Here are some pictures of the repair
grailoc
grailoc is offline
PostPosted: Thu Jun 10, 2021 7:46 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
grailoc
grailoc is offline
PostPosted: Thu Jun 10, 2021 7:47 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
end result with that repair including a bit of lead work to get rid of the welding marks:
grailoc
grailoc is offline
PostPosted: Fri Jun 11, 2021 6:50 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
here is a video I made and shows in few minutes how I created a patch panel for the front quarter panel starting with just a 20ga flat piece of metal..
grailoc
grailoc is offline
PostPosted: Fri Jun 11, 2021 7:06 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
After few hours playing with masking tape the other day, I am finally ready for the home made paintboot.
goal here is just to paint where needed the rest will stay untouched.
getting closer and closer !!
Dan22
Dan22 is offline
PostPosted: Fri Jun 11, 2021 9:01 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
Great progress and so much a labor of love.
Question though. What are the dark streaks here and there? Seam sealer, or POR?
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
grailoc
grailoc is offline
PostPosted: Sat Jun 12, 2021 6:01 am    Post subject: Re: Original 1956 Oval convertible Reply with quote
the dark mark is just rust converter I got from my paint supplier.
I could not get rid of these small little surface rust marks so decided to convert them and prevent rust to propagate under the epoxy primer I have next to come.
VW_Jimbo is offline
PostPosted: Sat Jun 12, 2021 11:44 am    Post subject: Re: Original 1956 Oval convertible Reply with quote
Very nice!!! Love your process and documentation of it!
On the spray booth. I have had great success with 2x4s and 3/4 PVC schedule 40 tubing, either glued together or loose. I make these into a rectangular frame, 3’ x 7’. At the base I install at the base that creates 2 legs perpendicular to the flat panel area. I then wire tie clear 4mil plastic to the frame and stand up. To create a wall, I will make a few of these and either spring clamp them together or tape them together. The tape make an impassable paint seam!
You can also use a large tarp as well. I use that for bead blasting. This was with the 2x4 stand I use for the Bug, from the last Bug I did. Works great.
Love the progress!
Jimbo
grailoc
grailoc is offline
PostPosted: Sat Jun 12, 2021 5:34 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
here is the paint boot I just completed:
it is made with basic 1x2 wood and plastic polythene for the walls. I can roll up and down each wall. I used a basic exterior carpet on the floor. The walls are just clipped on my 4 post lift.
grailoc
grailoc is offline
PostPosted: Fri Jun 18, 2021 8:42 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
so today I was able to apply the black epoxy inside the front trunk:
I am just wondering if I should put paint on top of epoxy or just keep it the wait it is as my car is black anyway.
what do Guys think ?
67rustavenger
PostPosted: Sat Jun 19, 2021 1:05 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
Wow, that looks great!
If it were my car. I'd be happy with the results of all that hard work.
But it's your car and you are bordering on a perfectionist. So in the end of things. It's your choice on what the next move will be.
Keep it up. It looks like you are going to be able to drive the car this summer. Cool
Buy Once, Cry Once!
grailoc
grailoc is offline
PostPosted: Wed Jun 23, 2021 9:20 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
Thanks !!
I had a color matching made yesterday with 1 gallon of paint, so yeah I am moving into painting the inside with black so the goal is to get as less as nuance a possible with the rest of the car.
more to come !!
grailoc
grailoc is offline
PostPosted: Thu Jun 24, 2021 4:54 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
the inside of the front trunk is now fully painted. L41 single stage paint on top of an additional layer of epoxy sealer.
going to wait the paint to cure and will switch to the outside.
very happy of my 1st paint ever:
VW_Jimbo is offline
PostPosted: Thu Jun 24, 2021 6:04 pm    Post subject: Re: Original 1956 Oval convertible Reply with quote
Looking really nice!
Did the epoxy have an open time for recoating it? Sometimes they cure so hard that any additional coats past the cure point will not adhere. Sometimes all you need to do is hit it with a red scotch brite pad, sometimes something else.
Looks great!
Jimbo
Page 21 of 36
