BonesBIR Samba Member
Posted: Wed Jun 09, 2021 9:19 pm Post subject: Fastback in Hippyville |
It has been a couple decades since I owned an Air-Cooled VW, then this '68 fell in my lap. It was hot-rodded out years ago and other than being parked for 15 or so years, it is fairly complete.
Initial plan is to clean it up, get it running then look into setting it up as a streetable period rally car.
More to follow
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22729 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jun 10, 2021 12:00 am Post subject: Re: Fastback in Hippyville |
First order of business should be to get that Weber BBQ- I mean "carburetor"- off there and use it to hone your shot put abilities. Go with Solex duals or even go back to fuel injection as God intended.
Springtucky here. Actually Thurston. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jun 10, 2021 12:54 am Post subject: Re: Fastback in Hippyville |
Tram wrote: |
First order of business should be to get that Weber BBQ- I mean "carburetor"- off there and use it to hone your shot put abilities. Go with Solex duals or even go back to fuel injection as God intended. |
Well if one is bad, two should be even worse. I have a pair of 44's on the shelf. This car is a long way from stock, and will never be a concourse winner. And that is OK |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Fri Jun 11, 2021 10:48 am Post subject: Re: Fastback in Hippyville |
I have a complete dual Solex engine w/big black air cleaner & more Type 3 parts near Harrisburg.
Your engine deck/lid is all missing? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Fri Jun 11, 2021 11:03 am Post subject: Re: Fastback in Hippyville |
Mike Fisher wrote: |
Your engine deck/lid is all missing? |
Not missing. The previous owner modified the engine deck to accommodate putting in type 1 tins, carbs on stacks, etc.
With the car came all the spares, bench stock and a bunch of other parts for other cars, so I am good there. I have an ad posted for the stuff I know I am not going to need. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Sun Jun 13, 2021 8:24 am Post subject: Re: Fastback in Hippyville |
I'm diggin that front end though. Sadly, that progressive is a great carb, just not on a type3. I agree that EFI is much more gooder. Can't wait to see what you do with it. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
Posted: Sun Jun 13, 2021 2:55 pm Post subject: Re: Fastback in Hippyville |
Sqrbckguy38 wrote: |
I'm diggin that front end though. Sadly, that progressive is a great carb, just not on a type3. I agree that EFI is much more gooder. Can't wait to see what you do with it. |
I am curious, why do you say "not on a type 3"?
My cousin, another gearhead, built a custom EFI setup on a carb model 78 Datsun 280z. It was an amazing project to watch take shape, but is was a ridiculous undertaking. While I agree that anything is possible, one has to ask if the juice is worth really the squeeze? Personally, I am comfortable with carbs. making dual mikunis sing on a British Twin is all in a day work, so I see this as no different. |
Posted: Sun Jun 13, 2021 3:21 pm Post subject: Re: Fastback in Hippyville |
BonesBIR wrote: |
I am curious, why do you say "not on a type 3"? |
Probably because it doesn't fit without either removing or putting a hole in the engine cover. In a type 3.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Sun Jun 13, 2021 4:02 pm Post subject: Re: Fastback in Hippyville |
Max Welton wrote: |
BonesBIR wrote: |
Max |
I see. Well the engine bay has already been modified to accommodate Type 1 engine tins and manifolds. I agree that it would be dumb to do this to a surviving stock car, but since the damage is done I see no harm in dropping the DelOrtos in. |
Posted: Sun Jun 13, 2021 6:00 pm Post subject: Re: Fastback in Hippyville |
The Dells would be great, but yes, the progressive just fitting underneath is an issue. Even if it were modified, I'd try to revert it is all. The progressive is a decent carb, I have one on Opal my 67, and it's great. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
67 Beetle, Opal |
Posted: Sun Jun 13, 2021 7:50 pm Post subject: Re: Fastback in Hippyville |
The Dells would be great, but yes, the progressive just fitting underneath is an issue. Even if it were modified, I'd try to revert it is all. The progressive is a decent carb, I have one on Opal my 67, and it's great. |
That's good to know. Thanks for the info.
I have done exactly one full restoration in my life and finishing it took all the fun out of that machine for me. It was too nice to ride at that point. I don't knock the resto community, it is just not my thing. I mostly work on vintage racing machines now because race rigs are just so much more fun and I am not afraid of getting it dirty. There are plenty of concourse ready type 3's out there, the world does not need one more. Now a rally prepped Fastback that will be the coolest thing on the dunes since Chad's surplus Pinzgauer, I can be that guy. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4923 Location: Southern AB
Posted: Mon Jun 14, 2021 9:04 am Post subject: Re: Fastback in Hippyville |
that's not type 1 tin, or cooling you have there.
Since it's been hacked already you have lots of room for a proper set of dual carbs, or some turbo tubing. The progressive will never run properly without manifold heat, it was just a poor excuse for an EFI replacement back in the olden days.
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Mon Jun 14, 2021 10:38 am Post subject: Re: Fastback in Hippyville |
Hacked engine compartment & fiberglass front end looks like a drag car in the making.
Gonna be breathing exhaust fumes in the cabin? _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Jun 14, 2021 11:30 am Post subject: Re: Fastback in Hippyville |
Gonna be breathing exhaust fumes in the cabin? |
Not by the time I get through with it. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22438 Location: Kimball, Mi
Posted: Mon Jun 14, 2021 12:59 pm Post subject: Re: Fastback in Hippyville |
W1K1 wrote: |
Not to mention that those Weber progressive carbs were crap on the Vega's and Pinto's they were originally made for. They're basically a 1 barrel carb, with a linkage to open a "secondary" throttle blade. Dual single throat Weber ICTs are a much better choice. Even dual Dells or Weber's are better choices than the progressive.
At this point, it looks like you can do almost anything you want to do as far as the load floor goes. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jun 14, 2021 1:40 pm Post subject: Re: Fastback in Hippyville |
[quote="Bobnotch"]
W1K1 wrote: |
that's not type 1 tin, or cooling you have there. |
You are right, Type 3 tins have been reinstalled. At some point previously it had been set up with type 1 tins. These pics are as I got the car, so this is the starting point I am working from. Unless there is a legitimate reason (better cooling, ease of access, better performance, etc.) I will likely leave the tins as is and do have intention to run a dual carb setup. (see below)
[quote="Bobnotch"]
W1K1 wrote: |
At this point, it looks like you can do almost anything you want to do as far as the load floor goes. |
Something like these then?
Posted: Mon Jun 14, 2021 2:28 pm Post subject: Re: Fastback in Hippyville |
[quote="BonesBIR"][quote="Bobnotch"]
W1K1 wrote: |
Bobnotch wrote: |
W1K1 wrote: |
Yup. Ideally you'd like to find some short intake manifolds to mount them to. That way the carbs don't eat into the space above your load floor.
Going off your photos, it looks like you're missing the type 3 generator (has a hole in the side of it for cooling air to enter it). It mounts on the saddle on the left side of the engine. Now depending on whether or not you want heat, you can either replace the silver tubes coming off the big shroud ends, or you can cap the ends with beer can bottoms and a hose clamp. This keeps the cooling air going to the engine for it to cool. If you decide you want heat, just replace those accordion tubes so air will flow thru the heat exchangers (it also helps pull heat from the heads), and sends the heat inside the car thru tubes from the heat exchangers to the body. kind of like this. https://www.thesamba.com/vw/archives/manuals/type3...t_Heat.pdf
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jun 14, 2021 3:16 pm Post subject: Re: Fastback in Hippyville |
Bobnotch wrote: |
I hope this helps. |
Huge help. thanks |
W1K1 Samba Member
