1970 Ghia Driver's Side Front Turn Signal Blinks Strangely
dungeoncrawl
dungeoncrawl is offline
PostPosted: Mon Sep 06, 2021 8:45 pm    Post subject: 1970 Ghia Driver's Side Front Turn Signal Blinks Strangely Reply with quote
The right, front turn signal alternates between "Lit" to "Lit but Brighter" and seems "normal". The left alternates from "Off" to "Strangely Lit" when blinking. It seems to struggle to get to "medium" brightness when going toward "Strangely" lit.
Someone suggested that I "check the ground" but I'm not sure where to begin. Any ideas? Also, I replaced the bulb and it does the same thing.
sputnick60
sputnick60 is offline
PostPosted: Mon Sep 06, 2021 9:24 pm    Post subject: Re: 1970 Ghia Driver's Side Front Turn Signal Blinks Strangely Reply with quote
The ground is the return path for the circuit. Usually in early VWs the ground is provided via attachment screws between the car’s body and the device. In your situation the flasher housing isn’t electrically bonded to the car to make a steady contact.
So, fiddle with the screws and sockets till you get it a steady connection working, or as a hack, add a separate wire between the housing and the car body.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
dungeoncrawl
PostPosted: Tue Sep 07, 2021 5:43 pm    Post subject: Re: 1970 Ghia Driver's Side Front Turn Signal Blinks Strangely Reply with quote
Nicholas
Can you give me some guidance on that? Wouldn't the closest ground screw be the one in the trunk to the left of the windshield spray bottle? I've loosened and tightened that one and none of the other lights in the area seem to have a problem. Now, the light bulb WAS stuck in the socket and took us some time loosening it up by tapping it with a screw driver and hammer. But unside the socket it 'looks' clean. Doesn't appear to be any shorts with cables directly connected to the turn signal housing.
kman
kman is offline
PostPosted: Wed Sep 08, 2021 4:10 am    Post subject: Re: 1970 Ghia Driver's Side Front Turn Signal Blinks Strangely Reply with quote
All my crazy #1 fuse and turn signal problems were solved by some electrical tape under the turn signal assembly in the steering column. It was shorting out in the housing.
71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead
mxl556
mxl556 is offline
PostPosted: Wed Sep 08, 2021 12:51 pm    Post subject: Re: 1970 Ghia Driver's Side Front Turn Signal Blinks Strangely Reply with quote
Something else to consider... I had all kind of crazy turn signal and parking light problems that looked like a bad ground (dim lights, fast blinking). I was checking the grounds and replacing/cleaning bulb holders but could not find any problems. One day turn signal switch quit working and the replacement fixed all of the issues.
Max
