Early Euro "Bullet" Fuse: Old (OE) vs New
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Nov 22, 2021 12:42 pm    Post subject: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
Hi all.
For the wiper/washer/rear defog fuse, '81 Westfalia.
Wipers, washer motor work but I haven't checked the rear defog circuit so....
IF years of normal use caused this fuse to fail....
Is the newer style fuse with different wider fuse material more robust re: long term wear/tear?
Thanks,
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
djkeev
djkeev is offline
PostPosted: Mon Nov 22, 2021 2:23 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
Copper vs Aluminum.
Copper is higher quality and carries the load better using less.
Dave
Ghia
Vanagon
Beetle
Ahwahnee
Ahwahnee is offline
PostPosted: Mon Nov 22, 2021 3:46 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
I suppose either will work fine - but for things electrical I'd generally take copper over aluminum.
djkeev
djkeev is offline
PostPosted: Mon Nov 22, 2021 3:48 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
Said the 50’s era homeowners watching their aluminum wired house burn down…..
Ghia
Vanagon
Beetle
danfromsyr
danfromsyr is offline
PostPosted: Mon Nov 22, 2021 3:53 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
what doesn't work well on the new fuses is that they have a plastic body
and if you have a resistance heat demand, that won't blow the fuse. but will melt the plastic and then fail..
well maybe that's a good thing.. Confused
the OEM were ceramic bodied.
Abscate wrote:
Vanagon Nut
PostPosted: Mon Nov 22, 2021 5:56 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
Interesting points guys; hadn't thought of the body material difference.
As a side bar, I tested current draw via the fuse terminals.
Approximate values with VOM on 10 Amp scale:
rear defog: 0.07 Amps (seems low. IIRC, only one or two defog wires are working)
wipers, low speed: 3.5 - 5.x Amps
wipers with washer pump: about the same.
Fuse likely failed due to normal wear and tear but I'm not discounting an issue with rear defog given what looks like a low Amp draw.
Neil.
(VW Gas I4)
VE7TBN
valvecovergasket
valvecovergasket is offline
PostPosted: Mon Nov 22, 2021 5:59 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
One of the first maintenance things on old Mercedes is tossing the aluminum fuses
https://mercedessource.com/problems/electrical/oe-aluminum-fuse-failure
DanHoug
DanHoug is offline
PostPosted: Mon Nov 22, 2021 6:18 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
those are cursed fuses. yeah i woke up numeruous W126 circuits by buffing those stupid things but use in ANY vehicle is folly. the clamping pressure on the fuse ends is not enough to exclude oxygen so the connection corrodes between the wimpy blade with a hole and the fuse point. copper or aluminum, they both suck. sure, they work fine when new... add 35 years then put on your hair shirt.
one of the few uses for a Dremel, put a brass brush in it and polish the vehicle blades for the conehead fuses. then hit each fuse on the wire wheel. you can buy like a 100 pack of off-shore plastic bodied aluminum or worse fuses for cheap but the smart money cruises eBay for NOS ceramic fuses.
-dan
www.thefixitworkshop.com
Vanagon Nut
PostPosted: Mon Nov 22, 2021 6:19 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
Oh my. Galvanic reaction at its' "best"!
(VW Gas I4)
VE7TBN
erste
erste is offline
PostPosted: Mon Nov 22, 2021 9:47 pm    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
I got Flosser ceramic bullet fuses from this seller on amazon:
https://www.amazon.com/Bullet-Ceramic-Torpedo-Flosser-Germany/dp/B00KO9F1PG/ref=lp_9237165011_1_2
Haven’t installed them yet, but the ones I got are ceramic and look to be copper.
DanHoug
DanHoug is offline
PostPosted: Tue Nov 23, 2021 6:30 am    Post subject: Re: Early Euro "Bullet" Fuse: Old (OE) vs New Reply with quote
take a neodymium magnet to the metal fuse ends and see if there is anything ferrous. cheap fuses MAY be copper plating over steel. sorta like 'copper' exhaust nuts.
-dan
