Elliptical resistance
bigdog1962
bigdog1962 is offline
PostPosted: Fri Jan 07, 2022 6:15 pm    Post subject: Elliptical resistance Reply with quote
I have had this Schwinn elliptical for about 5 years so it's out of warranty. The problem I'm having is with the resistance. When you turn it on, it resets to the lowest setting like it's supposed to. Then you start start in the manual mode and everything works as it should. But when you start to add resistance, the motor works and it keeps cycling to all the way on then all the way off, continuously. You can turn it off and it goes back to the lowest setting. I've tried googling and about the only thing I know to do is replace the motor - or I may just take it to the dump.
I've tried turning it on and off multiple times.
I've tried unplugging it multiple times.
The motor works and varies the resistance but won't stop cycling.
I am using the manual mode, as I have always done so it's not a program problem.
The motor does not have an on/off switch.
Does anybody have any other thoughts?
Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!!
bigdog1962
PostPosted: Fri Jan 07, 2022 6:45 pm    Post subject: Re: Eliptical resistance Reply with quote
I should probably clarify further, I'm thinking if I have to replace something, it would be the motor control board.
finster
finster is offline
PostPosted: Sat Jan 08, 2022 3:43 am    Post subject: Re: Elliptical resistance Reply with quote
is it possible to bypass the motor control board and rig up an on/off switch to the motor instead?
bigdog1962
PostPosted: Sat Jan 08, 2022 5:59 am    Post subject: Re: Elliptical resistance Reply with quote
I don’t want to lose the variability of the resistance.
finster
finster is offline
PostPosted: Sat Jan 08, 2022 7:13 am    Post subject: Re: Elliptical resistance Reply with quote
I assumed you could do that by blipping the motor.
bigdog1962
PostPosted: Sat Jan 08, 2022 12:12 pm    Post subject: Re: Elliptical resistance Reply with quote
Further research. They don’t make that motor control board anymore, of course. To the dump it goes.
busdaddy
busdaddy is offline
PostPosted: Sat Jan 08, 2022 4:57 pm    Post subject: Re: Elliptical resistance Reply with quote
Maybe I'm missing something here, why does an exercise device need a motor?, isn't it all about soaking up energy produced by you?, why does it need a boost?
I'm not razzing anyone, just curious since IMO a power assist is a bit like cheating. Can't you just unplug it?
Слава Україні!
Letterman7
Letterman7 is offline
PostPosted: Sat Jan 08, 2022 6:10 pm    Post subject: Re: Elliptical resistance Reply with quote
It's not power assist - it's inductive resistance to make it harder to turn the wheel. Of course, in the OP's case, I'd be tempted to simply hook the magnetic band to a rheostat to see if the resistance can be adjusted that way.
bigdog1962
PostPosted: Sun Jan 09, 2022 6:00 pm    Post subject: Re: Elliptical resistance Reply with quote
The motor moved the bank of magnets closer (to make it harder to pedal) or further away (to make it easier to pedal).
The elliptical is gone. I have been running a lot lately- I bought a Forerunner 55 and have been following a training plan which is incorporated into the watch.
PostPosted: Sun Jan 09, 2022 9:48 pm    Post subject: Re: Elliptical resistance Reply with quote
bigdog1962 wrote:
I have been running a lot lately - I bought a Forerunner 55 and have been following a training plan which is incorporated into the watch.
Curious - Couch to 5K or something similar or ?
bigdog1962
PostPosted: Mon Jan 10, 2022 5:48 am    Post subject: Re: Elliptical resistance Reply with quote
Not really couch as I do Crossfit. But decided to start putting longer distance in - more than I get in Crossfit. My first one is a 10k end of February here in my hometown. Got another 10k in March and one in April. Trying to decide if I want to do a half in November. I've done several marathons and halfs in my past. It's just training during the summer months down south here is brutal with the heat and humidity.
Are you a runner?
djkeev
djkeev is offline
PostPosted: Mon Jan 10, 2022 5:53 am    Post subject: Re: Elliptical resistance Reply with quote
Ah....... remember the good old days?
We would get on our bike and go for a ride around the neighborhood?
Or go outside, take a walk, say "hi" to people we encountered along the way, got to meet our neighbors......
Ghia
Vanagon
Beetle
Abscate
Abscate is offline
PostPosted: Mon Jan 10, 2022 6:09 am    Post subject: Re: Elliptical resistance Reply with quote
Sorry I missed this. If you sent me the board they can often be repaired by oldschiolers like me who had to read Horowitz and Hill in the 1970s (maybe 1980 early)
Chickensoup
Chickensoup is offline
PostPosted: Mon Jan 10, 2022 7:10 am    Post subject: Re: Elliptical resistance Reply with quote
any fuses? In the mean time, there are plenty of free weight exercises.
'65 Tourist Delivery Build
'66 RIP
bigdog1962
PostPosted: Mon Jan 10, 2022 9:25 am    Post subject: Re: Elliptical resistance Reply with quote
No fuses - the motor worked but just kept cycling.
I no longer have the elliptical.
I run and do crossfit so I'm good.
