changing the fan belt
FAT KUDA
FAT KUDA is offline
PostPosted: Thu Aug 18, 2005 4:38 pm    Post subject: changing the fan belt Reply with quote
is there a special tool for type 3's to change the belt ? im up for any suggestions ive looked Shocked for some sort of wrench w/ an off set and skinnt enough so i can get another wrench in there, im about to Twisted Evil grind and tweek a wrench to do the trick, any sugg....come with 'em Laughing
Russ Wolfe
Russ Wolfe is offline
PostPosted: Thu Aug 18, 2005 4:47 pm    Post subject: Reply with quote
Early t-3 wheel bearing wrench works.
http://classicvw.org/gallery/special_tools/wrench
But then again, I usually just pull the generator and slip the belt off and on.
Remove the clamp strap, tilt the generator, slip the belt off.
Gary: OK. Ima poop.
PostPosted: Thu Aug 18, 2005 4:49 pm    Post subject: Reply with quote
I've used 2 crescent wrenches many times but it's difficult.
Looks like they expected you to have a 21 and 27 mm open end wrench to do the job:
http://www.thesamba.com/vw/archives/manuals/66owners/36.jpg
FAT KUDA
FAT KUDA is offline
PostPosted: Thu Aug 18, 2005 4:50 pm    Post subject: Reply with quote
u know i was so pissed off that i didnt even think of that. Embarassed riite on. hey is there a site that has type 3 cheome engine tins. its funny i love this square, finding out more how to work on it, but also finding parts aren't so easy to come acrss as a type 1...
PostPosted: Thu Aug 18, 2005 5:17 pm    Post subject: Reply with quote
I don't think you can buy "new" Type 3 chrome tin but that's a good thing because all new chrome tin is junk. If you want chrome tin, chrome some original German engine tin so it's good quality.
Of course it will cost more that way.
Russ Wolfe
PostPosted: Thu Aug 18, 2005 5:33 pm    Post subject: Reply with quote
24mm and 21mm
Gary: OK. Ima poop.
Russ Wolfe
PostPosted: Thu Aug 18, 2005 5:37 pm    Post subject: Reply with quote
Someon on the vwtype3.org mail list, a few years ago had an engine that had chrome tin when he got it. The engine ran hot. He experimented, and found that with the non glossy OG black paint ran the coolest. The chrome tin seems to reflect the heat back in on to the engine.
Gary: OK. Ima poop.
Bobnotch
Bobnotch is offline
PostPosted: Thu Aug 18, 2005 5:46 pm    Post subject: Re: changing the fan belt Reply with quote
I built one like in the Muir book about 10 years ago. Mine is made out of 10 gage stainless steel, and works great. Twisted Evil Prior to building one like Muir shows, I used an older model oil filter wrench to grab the outer edge of the pulley. Rolling Eyes It worked ok, but the Muir wrench works better. Very Happy
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Russ Wolfe
PostPosted: Thu Aug 18, 2005 6:09 pm    Post subject: Reply with quote
Just a note on T-3 generator pulleys, if you pull the generator out, you wont drop the shims down into the fan housing. BTDT
Sad
Gary: OK. Ima poop.
rustyfastback
rustyfastback is offline
PostPosted: Thu Aug 18, 2005 7:43 pm    Post subject: Reply with quote
I use a 24mm crows foot wrench & 3/8" drive rachet to hold the center hub & a 13/16" wrench on the hex nut. I had to purchase the 24mm crows foot from snap-on tools, kinda pricy but works great. By the way does anyone have a source for the thin type wrenches use to adjust & tighten the front spindle nuts on pre '65 type 3's.
Russ Wolfe
PostPosted: Thu Aug 18, 2005 8:32 pm    Post subject: Reply with quote
I have 2 sets, but I am not selling.
24mm, one offset, the other straight.
Check for Hazet, or Stawhille <sp>. They made the originals.
Gary: OK. Ima poop.
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Thu Aug 18, 2005 8:38 pm    Post subject: Reply with quote
Sad
Everytime I go to change the belt I always get out my telescopic flexible magnet tool, because I will eventually need it.
OGST
Samba Member #4862
Zarana-X
Samba Dreadnok
Zarana-X is offline
PostPosted: Fri Aug 19, 2005 7:05 am    Post subject: Reply with quote
I've found it much easier to unbolt the gen strap and pull it forward to change the belt. You have more room if you need to adjust the shims, too. The telescoping magnetic wand is still good to have around Mad .
"In order to create, you have to destroy."
Rome
Rome is offline
PostPosted: Fri Aug 19, 2005 11:18 am    Post subject: Reply with quote
"I use a 24mm crows foot wrench & 3/8" drive rachet to hold the center hub & a 13/16" wrench on the hex nut. I had to purchase the 24mm crows foot from snap-on tools, kinda pricy but works great."
Same here, although I have a genuine VW/Hazet metric box-end wrench in 21mm size rather than the 13/16" for the nut.
Surprising that VW did not include some suitable tools, even if they were "basic" and stamped out of a flat piece of steel, in the on-board toolkit. My guess is that on the T3 the engine continues to run and cool properly, in contrast to the Beetle/T1 where if the belt breaks, you lose the engine cooling fan too. So with the high production numbers of the T3, lack of such tools would save a pretty penny/Deutschmark each year.
Bobnotch, I'll dig out my "Idiot" manual to see what tool the wise Mr. Muir conjured up.
Russ Wolfe
PostPosted: Fri Aug 19, 2005 1:38 pm    Post subject: Reply with quote
Ahhh, but they did.
http://classicvw.org/gallery/partsbook/kscan_0004
Item 11 in this scan.
Gary: OK. Ima poop.
PostPosted: Fri Aug 19, 2005 2:52 pm    Post subject: Reply with quote
My '63 Squareback with that wrench in the toookit.
I think they stopped giving it automatically in 1963 though.
P-Dub
P-Dub is offline
PostPosted: Fri Aug 19, 2005 4:15 pm    Post subject: Reply with quote
Here is the type 3 generator pulley tool I made in desperation one evening when I first got my squareback. I worked so well, I haven't bothered replacing it with the correct tool.
Gary
Person of Interest
Gary is offline
PostPosted: Fri Aug 19, 2005 4:24 pm    Post subject: Reply with quote
My dad worked on VWs when they first came to this country. He used to take box end wrenches and heat them with his torch and bend as needed. Perhaps you could try that and make your own special tools. I have a box end wrench with a 10mm socket he braized into place that is used to remove the fan shround from a T1.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
Russ Wolfe
PostPosted: Fri Aug 19, 2005 5:09 pm    Post subject: Reply with quote
From behind the intake manifold. Wonder how many T1's ran for years with that bolt missing.
Gary: OK. Ima poop.
PostPosted: Fri Aug 19, 2005 6:02 pm    Post subject: Reply with quote
I'm wondering what bolt that is?
