J A Red Samba Member
Joined: July 12, 2008 Posts: 86 Location: Peachland, BC, Canada
Posted: Fri Feb 04, 2022 1:12 pm Post subject: Anyone running a CB EFI kit in their splitty? |
Just about ready to order up a Gen4 CB Performance EFI kit and wondering where the best place would be to mount the ECU? It's going in a '59 DC so thinking my options are behind the front seat on the bulkhead, or behind/under the rear seat. Both these locations will require the wire harness to be custom made or lengthened, to reach. Just curious if anyone else has installed one of theses kits in a single ore double cab or is running the ECU up front. _________________ ‘56 type1 Reed Green Oval Deluxe - sold
‘59 type2 Dove Blue Single Cab - sold
Orange Sherbet Meyers Manx
‘59 type2 light green Double Cab |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80664 Location: Sneaking up behind you
Posted: Fri Feb 04, 2022 1:31 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
It's in the engine compartment ahead of the engine.
Sorry but I don't have a better picture.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 857 Location: clearwater,florida
Posted: Fri Feb 04, 2022 1:57 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
This engine looks fantastic in that bus. _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Glenn  Mr. 010
Posted: Fri Feb 04, 2022 2:49 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
| tpinthepack wrote: |
| This engine looks fantastic in that bus. |
It was a "no budget" build. _________________ Glenn
Member #1009
#BlueSquare
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 594 Location: I don't recognize it anymore
Posted: Fri Feb 04, 2022 8:10 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
How much work to install? DIY?
Was thinking of going that route w my 2332 _________________ kaiser kills kids.com |
Glenn  Mr. 010
Posted: Fri Feb 04, 2022 8:21 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
Lots of sensors, lots of wires and lots of reading.
You need a return fuel line, mount a head temp sensor and I strongly suggest getting the crankfire ignition.
I built the engine but did not install it in the Bus. _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Feb 04, 2022 10:38 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
Hey Glenn, thanks for the picture and info. Engine looks great.
Yeah a little more complicated install, but nice that it’s pretty much plug and play. The CB kit is $3100, but with crank trigger, extra long harness and AN fittings and lines I’ll probably be into it for around $3600 before tax, shipping and exchange rate. _________________ ‘56 type1 Reed Green Oval Deluxe - sold
karl h Samba Member
Joined: October 10, 2005 Posts: 657 Location: austria
Posted: Sat Feb 05, 2022 2:07 am Post subject: Re: Anyone running a CB EFI kit in their splitty? |
i am wondering about the position of the lambda sensor in the pic (i use a wideband for monitoring the jetting on my carbed engines). it should be installed neither vertical (it gets too much temperature) or horizontal (carbon or water buildup).... should be about ten degrees up from horizontal. just a thought _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 ragtop on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert |
Posted: Sat Feb 05, 2022 3:32 am Post subject: Re: Anyone running a CB EFI kit in their splitty? |
You know, a little Berg Linkage, Pulley, and Breather would go nicely with that A1 exhaust and CB EFI.
1990 Vanagon DOKA
1972 Super Beetle
Posted: Sat Feb 05, 2022 6:02 am Post subject: Re: Anyone running a CB EFI kit in their splitty? |
Yes a pretty motor for sure, Well done, then I thought, no one sees it. I have an A1/2332 and it's great, install the rear metal - close the lid and it is all gone. I used the Vintage Speed Bell Crank linkage.
OK, next time I pull the motor, think I'll go to the Powder coat shop, but Yes, the cost of that EFI is about 4K when finally done and the high fuel pressure scares me-I think I currently have about 2.5 lbs running to the Italians _________________ kaiser kills kids.com |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7125 Location: Lawrenceville, Ga
Posted: Sat Feb 05, 2022 11:02 am Post subject: Re: Anyone running a CB EFI kit in their splitty? |
| NUTSFORBUSES wrote: |
OK, next time I pull the motor, think I'll go to the Powder coat shop, but Yes, the cost of that EFI is about 4K when finally done and the high fuel pressure scares me-I think I currently have about 2.5 lbs running to the Italians |
i liked cutting the rubber seal at the bottom corner, that way you can take the apron out without any dangling rubber seals. So much cleaner and easier. _________________ regards
Uli
74 Thing Samba Member
Posted: Sat Feb 05, 2022 2:12 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
| Anyone have a timing map to share? |
Posted: Sat Feb 05, 2022 5:08 pm Post subject: Re: Anyone running a CB EFI kit in their splitty? |
i liked cutting the rubber seal at the bottom corner, that way you can take the apron out without any dangling rubber seals. So much cleaner and easier.[/quote]
Good idea, but have more to worry about when stuffing that Swelled-up "Bubble Top Super case" motor into the engine bay with giant carbs on a HF atv stand.
I will slice it next time. Thx mandraks. _________________ kaiser kills kids.com |
