IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Tue Feb 22, 2022 4:02 pm Post subject: Threaded tube that holds oil cooler and oil filter on - info? |
So I am wondering if anyone knows the thread pitch on each end (same?) of this pipe? And further if the pipe is available as a separate part? Thanks in advance.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
sanchius  Samba Member
Posted: Wed Feb 23, 2022 7:05 pm Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
The pipe may be the same on other vehicles using the same cooler design, as the 3/4-16 thread is very common in the filter world. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8405 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Feb 23, 2022 7:35 pm Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
sanchius wrote: |
Protip... Slot the exposed end so you can spin it out to renew the oil cooler seal without undoing the short coolant hoses connecting the oil cooler to the water pump. |
...or tap a Torx-55 bit into the bottom open end, same result...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Yondermtn Samba Member
Joined: November 21, 2007 Posts: 614 Location: Illinois
Posted: Tue May 27, 2025 5:29 pm Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
Where can I get a new one of these pipes?
Is there a part number?
And what’s it called specifically? When I search for oil filter pipe I just get a lot of oil filler pipes.
Thanks, I’m in the middle of changing my cooler gasket and the extractor bit got stuck in the pipe and now I destroyed the threads trying to get it out.  _________________ 1977 Westfalia 2.0FI 4spd
1990 Multivan 2.1 Auto |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12309 Location: Santa Cruz, CA
Posted: Tue May 27, 2025 5:44 pm Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
For a MV or DJ motor- 025115721 |
Posted: Wed May 28, 2025 6:37 am Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
Thank you! _________________ 1977 Westfalia 2.0FI 4spd
Posted: Wed May 28, 2025 7:06 am Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
If you have a wrecking yard near, I would suspect that any VW or Audi of that era which used the same oil cooler would use the same nipple. |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 751 Location: Lancaster PA
Posted: Wed May 28, 2025 8:06 am Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
Isn't it essentially just a piece of NPT plumbing pipe? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10374 Location: Orbiting San Diego
Posted: Thu Jun 05, 2025 5:53 am Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
Thanks for the links. I've placed three orders for this part and all of them have been cancelled. So frustrating. _________________ 1977 Westfalia 2.0FI 4spd
Posted: Thu Jun 05, 2025 9:07 am Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
MayorMcCheese wrote: |
As I understand, yes. Nothing super special.
If I was in this situation I’d be running to the plumbing shop or any good hardware store. Bring the pipe with you & they’ll match it…such is life near the end of the road.
"The WonderVan"
Posted: Fri Jun 06, 2025 6:56 am Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
Found it and ordered it from Van Cafe. I searched many times with the part number using the hyphens and no hyphens and theirs never came up until last night I searched again and there it was. ACE hardware didn't have the pipe and my plumber couldn't make those threads so hopefully Van Cafe comes through and I'll be back on the road soon. _________________ 1977 Westfalia 2.0FI 4spd
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10016 Location: Where?
Posted: Fri Jun 06, 2025 11:27 am Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
NPT threads are tapered. The tube has straight threads. |
Posted: Fri Jun 06, 2025 6:53 pm Post subject: Re: Threaded tube that holds oil cooler and oil filter on - info? |
?Waldo? wrote: |
So noted, thanks. Seem like it would be even easier to source locally (as long as there are still local shops in the world that thread pipe).
<fingers crossed>
"The WonderVan"
