58' Ghia Convertible Headlight Upgrade ?
MarkCastle
MarkCastle is offline
PostPosted: Sun Apr 03, 2022 12:46 pm    Post subject: 58' Ghia Convertible Headlight Upgrade ? Reply with quote
I would like to upgrade the headlights of my 58' Ghia Convertible 6V. It was a US delivery but was restored and driven in Belgium for several years. Can someone help me with the best way to get more lighting, yet not limit the ability to go back with the stock lights?
Thank you
but was restored and stayed in Belgium for many years.
Mark Castleberry
600 Russell St, suite 185
Starkville, MS 39759
crocteau
crocteau is offline
PostPosted: Sun Apr 03, 2022 4:05 pm    Post subject: Re: 58' Ghia Convertible Headlight Upgrade ? Reply with quote
Welcome to theSamba! Cool this may be a good place to start (https://www.thesamba.com/vw/forum/viewtopic.php?p=9131170), and if that whets your appetite do a search Wink
dclaxon
dclaxon is offline
PostPosted: Sun Apr 03, 2022 5:11 pm    Post subject: Re: 58' Ghia Convertible Headlight Upgrade ? Reply with quote
I put these in my '70 convertible, and they are definitely brighter than the originals so far, but I have only had it out after dark a couple of times so far. The only thing I don't like about them is the bluish tint, like a lot of the newer lights I see on the road these days, but I can live with it as long as I can see to drive. They are 12 volt, but I'm pretty sure they also have a 6 volt version.
https://vintagecarleds.com/shop/7-inch/vc3500-classic-kit/
When I talked to them, they recommended the classic lens upgrade, because it is more rounded and looks better in cars like ours where the headlight is exposed and becomes part of the shape of the car, and the standard lens is just flat and doesn't look right.
Dave
MarkCastle
PostPosted: Sun Apr 03, 2022 6:33 pm    Post subject: Re: 58' Ghia Convertible Headlight Upgrade ? Reply with quote
Thank you for your prompt responses. I will contact the bulb supplier you referenced. I have found that the 58-59 Ghia's have a different headlight assembly then many others.
Mark Castleberry
Braukuche
Braukuche is offline
PostPosted: Sun Apr 03, 2022 7:25 pm    Post subject: Re: 58' Ghia Convertible Headlight Upgrade ? Reply with quote
They used the same assembly from 55-63.
Your car has European lights, which are closer to modern Headlights vs the old sealed beam type.
That particular assembly takes an particular sort of bulb so check what it is before ordering something else.
Your other option is to go with US spec sealed beams.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
rcooled
rcooled is offline
PostPosted: Sun Apr 03, 2022 7:27 pm    Post subject: Re: 58' Ghia Convertible Headlight Upgrade ? Reply with quote
MarkCastle wrote:
...the best way to get more lighting, yet not limit the ability to go back with the stock lights?
Not sure if your current lights have removable bulbs or not, but if they do, you could try upgrading them for more light output.
If not, consider installing some H4 housings & bulbs, similar to these below ↓
https://www.jbugs.com/product/9311.html?utm_conten...gKvWfD_BwE
https://www.ebay.com/itm/6-Volt-Halogen-Headlight-...0#viTabs_0
The 6V H4 bulbs are only 35/35W, but should still be an improvement over standard headlights.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
kman
kman is offline
PostPosted: Mon Apr 04, 2022 5:03 am    Post subject: Re: 58' Ghia Convertible Headlight Upgrade ? Reply with quote
Dave
I bought the same with the Hella lens upgrade. They are not quite rounded enough for me but still very nice. I will probably buy a set of the classic to put in and use the Hellas in another car where it won't matter.
71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead
