Buggeee Samba Member
Joined: December 22, 2016 Posts: 4938 Location: Stuck in Ohio
vamram  Samba Member
Posted: Wed Apr 06, 2022 11:44 am Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
Good gosh almighty Buggee, you are a machine! I'd say "inspirational" but "scary" comes to mind! Hope Eastwood is giving you some great promotional discounts for the product placement!  _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Posted: Wed Apr 06, 2022 12:25 pm Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
vamram wrote: |
Good gosh almighty Buggee, you are a machine! I'd say "inspirational" but "scary" comes to mind! Hope Eastwood is giving you some great promotional discounts for the product placement!  |
Hey V! I've been hiding out with these big dogs in the Splitty Bus forum, you should see what they do over here!
I got that Eastwood thing years ago when one of my minions thought he was getting into welding and fabrication and it's been sitting in the corner ever since. I suddenly realized it could be used for something.
I'll be back on the Super Duper as soon as it's warm enough to start painting again. Really good to have you stop by. _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
Posted: Sat Apr 09, 2022 5:34 pm Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
All of this, just to mount a battery! Somewhere in my mind, before commiting to this process, I actually considered setting a piece of plywood in there just to get the summer started early.
I blasted the Autocraft battery tray clean of the shipping primer, and welded it in. I had a hard time welding upside down under there but did not burn through the corner. I'll take that as a win.
It's ugly, it's all metal... And it's mine. (p.s. those those little specks of light in the picture are not pinholes, they are reflections from the flash.)
silkvw Samba Member
Posted: Sun Apr 10, 2022 7:23 pm Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
You do nice work! And have a great attitude about your project.
Keep it up! _________________ '64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight= |
Posted: Fri Apr 15, 2022 11:17 am Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
Just a little progress. The tail light is cut out using the chrome ring as a stencil. Duraglass has been sanded down and a skim of Rage applied. Its an exercise in self restraint to not refinish this entire corner panel, but this is not the time for elective surgery. Birds are chirping.
I'm using 3M Panel Bond as the seam sealer in the joint of the battery tray to rear corner. Since the spot welds supporting the battery communicate directly to the exterior skin, I want to spread the load as evenly as can be possible. My imagination has that heavy battery working on the exterior skin over every bump and getting dimples or something.
Mr Margaret Scratcher Samba Member
Joined: February 10, 2013 Posts: 309 Location: Cambridge UK
Posted: Sat Apr 16, 2022 8:35 am Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
Buggeee wrote: |
I'm starting in on the battery tray so I can have a battery.
Be gentle, this is advanced level for me. I have been studying....
I'm also diving headfirst into the battery tray as my first real attempt at a repair here: https://www.thesamba.com/vw/forum/viewtopic.php?t=723551&start=40 - if mine turns out as good as yours has so far Ill be happy!
Buggeee wrote: |
I found this fiberglass treat.
This looks very similar to the story on my rear corner too... |
Posted: Sun Apr 17, 2022 1:56 am Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
Buggeee wrote: |
Mr Margaret Scratcher wrote: |
I'm also diving headfirst into the battery tray as my first real attempt at a repair . |
We'll keep chipping away at it from both sides of the pond!!!  |
Yep yep! |
LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5598 Location: 1st Coast
Posted: Sun Apr 17, 2022 4:24 am Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
Super nice job Buggeee, what tool did you uses to cut that curve out so nicely? You are a master artist and I love your work.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1802 Location: Fortuna Calif.
Posted: Tue Apr 19, 2022 7:54 am Post subject: Re: Buggeee's 1966 Sportsmobile Camper by Travel Equipment Corp |
Awesome workmanship, if wonder if your bus realizes just how lucky it is you are now the owner. Carry on, I will be following.  |
