Seb67 Samba Member
Joined: December 02, 2003 Posts: 1012 Location: New England
Posted: Sat Apr 30, 2022 7:55 pm Post subject: Spring plate tool VW 656 |
In the process of installing newly rebuilt trans and I discover my passenger side spring plate had 'jumped off' the notch/ledge. First tried jacking up the spring plate with floor jack but that just lifts the whole car. Looked at the Bentley manual and it said to use "VW 656". Well I don't have one of those but I do have some bits of wood and a clamp!
At first I tried using a ratchet strap but to no avail.
Using a chainsaw (hah!), I cut a small notch in a piece of scrap 2x4 for the spring plate to ride in. Then used a wood working clamp and a pair of channel locks to tighten the spring plate back into place per the Bentley photo. I was nervous but it worked. Hope this is helpful for someone out there in the same boat. Good luck!
_________________ 1964 Type 1 |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6162 Location: 37.5N 77.1W
Posted: Sun May 01, 2022 6:05 am Post subject: Re: Spring plate tool VW 656 |
Surprised the spring plate didn't split the wood block. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
RWK Samba Member
Posted: Sun May 01, 2022 6:17 am Post subject: Re: Spring plate tool VW 656 |
Good solution, I have used a chain attached to shock tower and to a floor jack to compress plate many times, then a clamp to push plate onto stop while bolting cover on, in the case of resetting your springs. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Seb67 Samba Member
Posted: Sun May 01, 2022 8:18 am Post subject: Re: Spring plate tool VW 656 |
runamoc wrote: |
Surprised the spring plate didn't split the wood block. |
Me too. I think the 2nd piece of wood under it did the trick. It is some kind of tropical/hard wood. Thank you! _________________ 1964 Type 1 |
Dusty1 Samba Member
Posted: Sun May 01, 2022 9:20 am Post subject: Re: Spring plate tool VW 656 |
Chain and a floor jack.
I generally pre- load mine one notch and / or use oversize Sway-a-Way torsion bars.
I wouldn't trust a Jorgensen clamp, not even one of my nice German Grosse Stabil clamps or kick- ass Piher welding clamps. Seems to be a great way to get a clamp in the teeth when the car spits it off.  |
Seb67 Samba Member
Posted: Sun May 01, 2022 9:44 am Post subject: Re: Spring plate tool VW 656 |
Does anyone have a photo of the chain and floor jack method? _________________ 1964 Type 1 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Sun May 01, 2022 9:59 am Post subject: Re: Spring plate tool VW 656 |
Seb67 wrote: |
Does anyone have a photo of the chain and floor jack method? |
No, I used the chain/floor jack method to raise my squareback once, but I will buy or make a clamp next time! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Stinky123 Samba Member
Joined: January 31, 2022 Posts: 232 Location: Grand Junction, CO
Posted: Sun May 01, 2022 10:13 am Post subject: Re: Spring plate tool VW 656 |
I woulda made one. But, I don't have one of those clamps.
A trip to the hardware store....BTW Lowes, HOme Depot, Sutherlands, and etc are not Hardware stores. Hardware stores sell BBs, ammo, fishing gear, worms, and etc.
Some all-thread, some nuts, and washers, scrap metal that I already have, and about 5 minutes worth of welding.
As a side-note....when I walk in the to HW store, there will be 3 guys there (w/a gal or 2 thrown in). They will have red vests on (easy to find, try to find a vest at the above), they will act like they are happy to help me and say, something like, do you need any help finding anything SIR.
But, you had that on hand, and it looks good. I pay tribute to your inginuity and design....well done.
ON a rail, I use a come-along and grab on to the frame. Last time I did it, the rail had thick T-bars and it was a beastie to pull the plates up. |
slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
Posted: Sun May 01, 2022 10:26 am Post subject: Re: Spring plate tool VW 656 |
Thanks for the ideas as I am working out my strategy for the same job on my '65. Sorta scared of flying parts...
I think if your chainsaw cut was perpendicular instead of parallel to your woodblock's grain, the possibility of the wood splitting might be less?
Would also like a few more photos from those who have gone before with this necessary maintenance.
My plan so far will be a two-ton floor jack, a chain, now a block of wood, a crowbar, really thick welding gloves and a safety eye shield.
To OP:please post a few photos of your progress. _________________ '65 T1 Sedan
'87 T3 Syncro |
VWFIXER Banned
Joined: January 21, 2011 Posts: 411 Location: Hawaii- Rarotonga
Posted: Sun May 01, 2022 10:39 am Post subject: Re: Spring plate tool VW 656 |
Maybe just assemble the entire project and let gravity do the work, maybe leave the axle to spring plate bolts a little loose until you drop it down on the tire. Beats risking appendages. _________________ ( ) Cheap
( ) Fast
( ) Reliable
Choose 2
Over a million air cooled miles driven and 15,000+ cars serviced. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8850 Location: Sunset, Louisiana
Posted: Sun May 01, 2022 12:00 pm Post subject: Re: Spring plate tool VW 656 |
I made this one, the fine threaded rod stripped on the last spring plate. I'll buy the correct tool next time.
PS wished I had never used those urethane bushings
viiking Samba Member
Joined: May 10, 2013 Posts: 3181 Location: Sydney Australia
Posted: Sun May 01, 2022 3:52 pm Post subject: Re: Spring plate tool VW 656 |
runamoc wrote: |
^^ Yes I also used a threaded rod of the appropriate robustness and made sure it was well clamped to all attachment points. A chain would be helpful once the spring plate had been compressed to hold it there safely while you work.
I also endorse the comment about using the woodworking clamp (F clamp?). Many of the cheaper ones have brittle cast iron bodies that can just fail with a big crack. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Sun May 01, 2022 5:24 pm Post subject: Re: Spring plate tool VW 656 |
EMPI sells them _________________ If you`re going to do something, do it right. |
Seb67 Samba Member
Posted: Sun May 01, 2022 6:37 pm Post subject: Re: Spring plate tool VW 656 |
Q-Dog wrote: |
Seb67 wrote: |
Thanks - I think I see how that works. The chain goes under the jack (not shown in the photo).
Looked for this tool in EMPI but couldn't find it.
https://empius.com/product-category/tools-equipment/
I may replace my spring plate bushings at some point so will be revisiting this.
Found this on another thread here. Someone actually made one to spec from the 'local manufacture' build sheets. The tool doesn't seem that big:
mibinder Samba Member
Joined: April 08, 2008 Posts: 17 Location: Ludington MI
Posted: Mon May 02, 2022 3:49 am Post subject: Re: Spring plate tool VW 656 |
Tool is available from a variety of vendors.
SoCal Imports. $40 Part #: 000116
CIP1 $50
Aircooled.net $45
$40 + shipping but no chains, floor jacks, clamps, blocks, time spent fabricating rather than actual wrenching.
Just a thought... |
rcroane  Samba Member
Joined: January 03, 2013 Posts: 2018 Location: Springfield, Virginia
Posted: Mon May 02, 2022 5:04 am Post subject: Re: Spring plate tool VW 656 |
Cip1 sells the spring plate tool.....
https://www2.cip1.com/acc-c10-7047/ _________________ '65 Sunroof Bug |
