djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
TinyPickle Samba Member
Joined: December 15, 2021 Posts: 190 Location: Slovenia, Europe
Posted: Sun Jun 19, 2022 11:40 pm Post subject: Re: Inner Fender Liners. |
Neat builds, @redrosie and @mstaboo.
I guess fixing it to the lip really helps.
I'll probably wait and see if i have rubbing with current setup (van in pieces, currently doing the welding), with 215/80/ R15 tires, and then decide for liners. Thnx for info! _________________ God of rust, have mercy.
WIP - Offroad Spec Syncro - 1.9 TDI AFN - Build Thread
IG: syncro_brothers |
chrismsnt Samba Member
Joined: March 06, 2018 Posts: 259 Location: Cumming, GA
Posted: Mon Jun 20, 2022 5:14 am Post subject: Re: Inner Fender Liners. |
TinyPickle wrote: |
chrismsnt wrote: |
TinyPickle wrote: |
reviving this century old thread.
Does anybody know/have experience, how much more rubbing with bigger wheels is present, if any? lets say 215/75 R15 on stock syncro.
Cheers, |
Yes they can rub... I state this from experience! LOL Make sure they're fitted with screws or the likes. These are the ones that I have: https://www.brickwerks.co.uk/t3-plastic-wheel-arch-liners.html |
Approximately how much of clearance would you say you lost inside the wheel well? you probably bolted them right?
Is there alot of mud and dirt caught behind them, ever noticed this? |
I wouldn't say "lose clearance" per say... it's when your tires do travel, it always seems to grab on the bottom and such. PITA. I guess they could be flared out on the bottom to sort of round them out a bit. _________________ Chris
1989 T3 Vanagon 16" Syncro
1967 Squareback
https://vwvandiesel.com
Instagram @VW_VanDiesel |
Posted: Mon Jun 20, 2022 6:46 am Post subject: Re: Inner Fender Liners. |
chrismsnt wrote: |
TinyPickle wrote: |
chrismsnt wrote: |
TinyPickle wrote: |
Cheers, |
I wouldn't say "lose clearance" per say... it's when your tires do travel, it always seems to grab on the bottom and such. PITA. I guess they could be flared out on the bottom to sort of round them out a bit. |
My bad, i meant what you wrote, you get rubbing in cases previously you would not.
I guess if you tinker with them enough time, you can get them to work flawlessly. As mentioned before, hot air gun is the way i guess. _________________ God of rust, have mercy.
