Battery size for a '67 Bug other than Group 42?
Page: Previous  1, 2, 3  Next
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Tue Oct 16, 2018 12:46 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Hijack...
When using original seats and material... I always add a layer of burlap sack or vinyl (or both) between the springs and coconut fibers (it's not horse hair) .
This helps keep the fibers trapped in the proper area rather than being sliced up by the springs and distributed in the floor and under the seats.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
andk5591
andk5591 is offline
PostPosted: Wed Oct 17, 2018 7:23 am    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Something I do for batteries that dont have the positive terminal cover is make a wrap around cover out of some ABS plastic that I have laying around. It encloses the terminal and is held on with zip ties. Works better than the margarine lids that I see duct taped on some cars LOL
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
zuk
zuk is offline
PostPosted: Tue Aug 20, 2019 4:31 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
The group 96R which fits the mustang and has more cranking amps, is a good alternative if you cant find a 42
AirHead1966
AirHead1966 is offline
PostPosted: Sun Jul 10, 2022 4:52 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
That is what I got today. Costco has Interstate 96R batteries for $99. Same dimensions as Group 42, same location for terminals and 550 CCA.
Cusser
Cusser is offline
PostPosted: Sun Jul 10, 2022 6:48 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Cusser wrote:
Batteries cost a fortune these days. Something like 85% of the batteries sold in USA are made by Johnson Controls.
I use the 42 battery from Autozone.
VERY important to secure the battery to the pan, to preserve lifetime of the battery.
Since this post in 2018, I have adapted my opinion. Due to battery costs.
Alternate battery sizes batteries instead of Group 42: 96R and 47/H5 even have recessed terminals, which is a bonus on our cars (96R includes a cover as well) 24F is said to work but I have no first-hand experience with those.
I now have 26R from Walmart in my 1970, more CCA than the Group 42 too. And less expensive.
Whatever battery you choose: Make sure battery is secured to the pan, and that there is insulation between positive terminal and the rear seat, just so a passenger doesn't press the seat down far enough to short out the battery.
davidw99
davidw99 is offline
PostPosted: Mon Jul 11, 2022 3:06 am    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
I posted earlier in this subject (above) that a group 58 battery would fit. I meant a group 58R battery.
Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed" and recently repainted.
Combi Cat
Combi Cat is offline
PostPosted: Sat Sep 24, 2022 12:55 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
60BeetleBill wrote:
I don't know if it would prevent battery shorting, but to prevent "horse-hair precipitation" I've gone and sprayed rubberized undercoating on the underside of my bugs' back seats. It is to seal in the padding, but you can't do it without coating the metal springs as well.
The hair collecting under the back seat drives me crazy also. To remedy this I've taken an old sheet and hot glue gunned it to the bottom side and trimmed the excess. You can't see it at all when the seat bottom is installed. Works great![/quote]
Good thinking! But is the fabric an additional fire hazard should there be a spark?
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Sep 24, 2022 1:37 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
FYI that is not hair, but instead coconut coir. A spray can of upholstery glue would probably do a better job.
In Stereo, Where Available!
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Tue Oct 18, 2022 9:26 am    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Installed a Diehard 26R-2. Advanced Auto $110, one year free replacement warrantee.
200 A fuse to ground on the left and 40 A fuse on the right.
Cranking current is 100 A. With a self-supporting starter, 16300.
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
DeathRay64
DeathRay64 is offline
PostPosted: Thu Nov 24, 2022 11:41 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
I'm thinking a Group 75 battery might be persuaded to fit without much trouble.
It has side posts only that would avoid most seat spring issues and it is only a 1/8" wider.
I'm sure some folks here must be running these, or even the longer Group 78.
Making VW's and America great again.
Jade
Jade is offline
PostPosted: Mon Jan 15, 2024 3:34 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
I needed a battery for my '66 bus recently and couldn't find anything cheaper than $190, ouch.
I went with a Napa brand BCI no. 35 for $130. The width and depth is the same, but the height is a little more no problem on a bus though.
https://www.napaonline.com/en/p/BAT6535?bvnotifica.../269099294
'66 11 window
VWNate
VWNate is offline
PostPosted: Tue Jan 16, 2024 9:23 am    Post subject: 12 Volt Battery Other Than BCI Group 42? Reply with quote
What a great thread .
I wish they'd make a dedicated 6 volt VW AGM battery, I like to use the stock battery cover and hold down .
For those who have old Beetles with random batteries, the simple solution is a beefy rubber floor mat ~ you pinch it between the lower rear seat cushion and the metal bar that holds the seat cushion in place, it'll never allow the seat springs to touch the battery no matter how fat your passengers are .
Nice to see the numerous different BCI numbers that can be used in a pinch .
-Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc.
JZ8G00
JZ8G00 is offline
PostPosted: Tue Jan 16, 2024 1:50 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Just replaced my 11 year old Group 42 with a Group 96R from WalMart, perfect fit and at $107 very affordable.
1974 Super, Purchased March, 2012, Second Owner
runamoc Premium Member
runamoc is offline
PostPosted: Wed Jan 17, 2024 12:41 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Rule of thumb for the most powerful batteries...size matters
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
1967VWS4LIFE
1967VWS4LIFE is offline
PostPosted: Wed Jan 17, 2024 1:54 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
I use a group 90 (T5) battery for my 67 which originally comes in Ford Fusions, and it works flawlessly. Also got some battery terminal covers from Amazon which takes care of any possible contact with the seat springs. A top post is always better than a side post battery and a 90 group has more CCA than a 96R or a 42.
Restored Sea Blue 67 A/C bug
THINGONER
THINGONER is offline
PostPosted: Mon Dec 02, 2024 7:40 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
https://www.walmart.com/ip/EverStart-Value-Lead-Ac...om=/search
The 26R=reversed terminals which is what we need-almost ordered the regular 26 on accident
VWNate
VWNate is offline
PostPosted: Tue Dec 03, 2024 10:35 am    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Odd, I cam here to see the newest response and the sire says this thread no longer exists....
IIRC there's a BMW car battery that's the right size and even comes with the plastic safety cover.....
-Nate
viiking
viiking is offline
PostPosted: Tue Dec 03, 2024 2:37 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
As a bit of an aside I can remember vividly in the early 70's when my Father bought a replacement battery for his 68 as a VW spare part. He liked keeping it stock. Very Happy
It was a translucent white (cf to the originally fitted black VW) Group 42 battery but came dry. That is, you bought the battery and they gave you a bottle of acid which you then had to dispense accurately into each of the cells. He got a bit of a surprise with that and wasn't sure it would work. I think it was a Bosch.
However the battery required no charge after the addition of the acid and by the following morning was fully charged and ready to go.
Cusser
Cusser is offline
PostPosted: Tue Dec 03, 2024 5:13 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Maybe in Australia, I don't think USA would've permitted adding concentrated sulfuric acid to each cell, here they try to protect us from stuff which is even very unlikely to happen....
viiking
viiking is offline
PostPosted: Tue Dec 03, 2024 5:41 pm    Post subject: Re: Battery size for a '67 Bug other than Group 42? Reply with quote
Yes it's a litigious society we live in.
I'm just waiting for the signs that they might put in trains....
"Danger. Do not jump out of a speeding train. It may be harmful for your health (in California at least)."
Page 2 of 3
