Buggeee's 1984 Puma GTS
Buggeee
Buggeee is offline
PostPosted: Sat Oct 09, 2021 6:41 am    Post subject: Buggeee's 1984 Puma GTS Reply with quote
Well, it's not like I needed something to do but I find myself scouting ground in another Samba forum nonetheless. My buddy Joey was sitting on this 1984 Puma GTS and decided his kiddos were better worthy of his time (the right decision every time). On a lark, and involving a series of transactions that lend proof to the devine nature of the order of our universe, I said goodbye to the MGB that none of you would care to wash any more than I would, and said hello to my Brazilian crush. Here she is as found.
Waking her from sleep took not much more than a kiss on the cheek and a quick field tuning of the dual carbs. The cloud of smoke eventually cleared, we found usable idle and hit the road together on life's long adventure.
She pulled eagerly at sustained highway speeds but smelled terribly of mouse pee and began to gather high temperatures, and corresponding lower oil pressure, at the half hour mark.
Back home on the farm, we got to know each other better, removed the PO's fender mirrors, and had a bath.
Then we were off to a quick local cruise-in to announce our engagement to the outside world. Back-firing, occasionally sputtering and getting hot at the half hour, she enjoyed her first night on the town in many years (the inspection sticker in the window reads 1991)
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
Buggeee
Buggeee is offline
PostPosted: Sat Oct 09, 2021 5:39 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Well I have found that the shortest path to vetting a new air-cooled arrival is to drop the engine, strip the tins, clean out the debris, torque the heads, adjust the valves, power wash the thick insulating sludge from the case and heads, reassemble with fresh plugs, wires, points, condenser and then set the dwell, timing and tune the carbs. Fresh valve cover gaskets. Adjust the thermostat. Here when cleaning the carbs, I found a plugged jet. Also the intake manifolds here are cast iron, so I painted those. The oil cooler needed some fresh gaskets.
Chasing gremlins for weeks is a waste of time. Just drop it and get to it.
Joey had already cleaned the tank and freshened the fuel filter. Here I added to the regimen with some K&N air filters, and sand blasting all the tin. I found the original Bosch 050 distributor in pieces in a box, cleaned, lubed and assemble it and threw out the imposter 009 clone that had been scattering due to a loose drive gear. The engine starts right up and pulls hard into the 5k redline like a champ. No stumbles, no back firing. Runs cool and oil pressure stays up. A joy to drive. Took it to a quick local cruise and the dudes were like "what in tar nation is that?". I tell them "It's from Brazil... You'll never see another one!". Here is a pictorial.
Oh... And some axle boots while I had easy access. Then the fresh transaxle fluid stays in better.
Buggeee
Buggeee is offline
PostPosted: Sun Oct 10, 2021 4:22 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Drive 'em if you've got 'em Airheads!!!
Buggeee
Buggeee is offline
PostPosted: Mon Oct 11, 2021 6:21 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Heel toe driving was hampered by a way-out-of-adjustment pedal cluster so I adjusted the little plate in front of the brake pedal to bring it line.
I've read this is, essentially, a shortened 411 pan so am not able to source brake cables. Luckily I found these bolt on tops in the car and fished out perfectly good cables from the tunnel. Hooked everything up and the parking brake works great.
Celebrate with an evening therapy session.
GArBa
GArBa is offline
PostPosted: Wed Oct 20, 2021 10:57 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
no, this car is still a type 1 frame, it's a VW Brasilia pan (in itself basically a widened Karmann-Ghia pan, with other minor changes) shortened by IIRC 25cm.
cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v
Buggeee
Buggeee is offline
PostPosted: Sat Oct 23, 2021 6:32 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Thank you for the information , this car is a mystery to me. I really enjoy driving it.
Petfisheric
Petfisheric is offline
PostPosted: Wed Nov 17, 2021 6:11 am    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Nice GTC (81-end of production)the GTS is the earlier steel bumper model (71-80). The air-cooled Puma's started out on Karman-Ghia pans but change to the Brasilia Pan in the mid 70's and both were shortened.
Buggeee
Buggeee is offline
PostPosted: Wed Nov 17, 2021 5:04 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Thank you for the information. These cars are sure funto drive!
Buggeee
Buggeee is offline
PostPosted: Fri Apr 15, 2022 5:12 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
It is good to get outside again!
Sleep well.
Buggeee
Buggeee is offline
PostPosted: Thu May 19, 2022 6:10 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
I haven't had various lights in the rear, ever, so decided to trace down the problem.
Using a 30 dollar scope from Amazon that sends color, lighted, real time video feed to an app on my phone wirelessly, I followed the wiring harness into the body cavity.
In there I found a mouse nest and a bunch of chewed through wires. Using a small cut-off wheel I gained access and repaired the harness.
I used lineman splice (Google it, you'll be glad you did -its an awesome splice), solder, marine shrink wrap (has melting glue) and shoved it all back in. Now I've got all lights in the rear and, as an added bonus, all idiot lights and engine gauges in the dash now work. Gas gauge is another issue.
One day when I'm doing body work, I'll fiberglass the hole shut. For right now I threw a piece of Gorilla Tape over it because I have places to go and people to see.
Ice cream time!!!
NJ John
NJ John is offline
PostPosted: Fri May 20, 2022 5:42 am    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Cool investigation skills. Love the Puma.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Buggeee
Buggeee is offline
PostPosted: Mon May 23, 2022 4:49 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Dude the scope is awesome tech. Every took box should have one. Cool
Drive em if you've got em
Buggeee
Buggeee is offline
PostPosted: Sun Jun 19, 2022 5:34 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Time for some ice cream! Once again the Puma had some car folks scratching their heads. What is that?!
NJ John
NJ John is offline
PostPosted: Mon Jun 20, 2022 5:39 am    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Hey, look at that Alfa parked over there!
Buggeee
Buggeee is offline
PostPosted: Tue Jun 21, 2022 7:32 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Exactly! I should start writing down a list of all the guesses, it's fascinating.
In the meantime... Drive em if you've got em!!!!
oprn
oprn is offline
PostPosted: Fri Jul 15, 2022 11:44 am    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
I love it! Keep on driving, fixing and posting it here!
Buggeee
Buggeee is offline
PostPosted: Mon Jul 18, 2022 12:15 pm    Post subject: Re: Buggeee's 1984 Puma GTS Reply with quote
Well, Jim's Custom VW has the big summer Jubilee in July, so I drove this puma for about 5 hours at 70 mph in one day, round trip, and it hummed along the whole time with steady oil pressure and steady temperature. It was a beautiful day with sunny skies and hot (for Ohio) temperatures.
Here I've stopped for gas at a rest stop on the Turnpike on the way out there in the morning.
Took my spot right under the sign so you can all see where the action is.
Here are a few random pics of the show. There were more than 150 air cooleds there, plus swap meet, food and music.
