Jason0115 Samba Member
Joined: April 11, 2021 Posts: 113 Location: New Jersey
Posted: Thu Aug 25, 2022 9:19 pm Post subject: Re: Distributor 022 905 205S restoration questions |
How do you install the tiny circlip that is under the felt puck under the rotor? Mine was also sitting on top of two little washers loose, giving my distributor way to much vertical freeplay. Thanks |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13551 Location: West Coast, USA
Posted: Fri Aug 26, 2022 6:35 am Post subject: Re: Distributor 022 905 205S restoration questions |
I use a metal tube just a tad larger than the distributor clip shaft. A dab of grease holds the clip in place while a bop if a rubber mallet usually seats the clip nicely.
Large sheet magnets available at craft stores are handy as a work mat for small jobs like those clips and steering box bearings.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79846 Location: Sneaking up behind you
Posted: Fri Aug 26, 2022 6:38 am Post subject: Re: Distributor 022 905 205S restoration questions |
1/4 drive M6 deep socket _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7516 Location: Houston, Texas
Jason0115 wrote: |
Some people use a socket that is the right size to fit over the inner shaft and inside the outer one. I use a few small tools to snap it on. It's not easy when it's your first time. Do a few hundred and they just seem to snap on. _________________ www.vwnos.com [email protected]
Posted: Fri Aug 26, 2022 7:53 am Post subject: Re: Distributor 022 905 205S restoration questions |
Glenn wrote: |
1/4 drive M6 deep socket |
This worked like a charm, I hit the top of the socket with a hammer and the clip is in. Thanks |
Glenn  Mr. 010
Posted: Fri Aug 26, 2022 8:00 am Post subject: Re: Distributor 022 905 205S restoration questions |
Jason0115 wrote: |
Glenn wrote: |
Member #1009
#BlueSquare
