Yellow head bolt sealant??
robcurtis2
robcurtis2 is offline
PostPosted: Mon Sep 05, 2022 9:18 am    Post subject: Yellow head bolt sealant?? Reply with quote
Reinstalling heads on the super fast 1.9L. Is there any other stuff that people recommend for sealant on the head bolts other than the yellow stuff? The stuff I got seems to be a clear oily liquid and not a paste at all. Let me know when you can.
Cheers,
RC
djkeev
djkeev is offline
PostPosted: Mon Sep 05, 2022 9:27 am    Post subject: Re: Yellow head bolt sealant?? Reply with quote
The Great Stuff
Ghia
Vanagon
Beetle
robcurtis2
PostPosted: Mon Sep 05, 2022 9:37 am    Post subject: Re: Yellow head bolt sealant?? Reply with quote
djkeev wrote:
The Great Stuff
What is "the great stuff"??
robcurtis2
PostPosted: Mon Sep 05, 2022 9:39 am    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Can I just use the black sealant that I use for the rubber gasket on the head bolts in place of the yellow sealant? or is that a big no?
djkeev
djkeev is offline
PostPosted: Mon Sep 05, 2022 10:06 am    Post subject: Re: Yellow head bolt sealant?? Reply with quote
My mistake, the right stuff
https://www.amazon.com/permatex-sealant-right-instant-gasket/dp/b072wdy9vd
Ghia
Vanagon
Beetle
robcurtis2
PostPosted: Mon Sep 05, 2022 11:08 am    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Did a little reading and apparently Tencentlife recommends REINZOSIL on the head nuts??
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Mon Sep 05, 2022 12:40 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Yes, I read that a while back too. I was about to dig into his posts to find a quote and past it here, but now its out in the open, and can be searched for if the need for confirmation is required.
robcurtis2
PostPosted: Mon Sep 05, 2022 3:24 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
So when putting back together in steps:
1. Cylinders and pistons go back on. What type of sealant go on the black round gaskets on the bottom of the cylinders?? Maybe a little bit of oil?
2. The green gaskets on the top of the cylinders get a little oil but no sealant correct??
3. The black head gasket gets either the VW black sealant that comes with the gaskets or "the right stuff" on both sides of the gasket?
4. The head bolts get either the yellow VW sealant or more preferably per tencentlife the REINZOSIL sealant?? Im assuming apply the REINZOSIL as you would the yellow stuff with a bead around the mating surface of the head bolt?
I think thats it correct? Let me know when you can
Cheers,
RC
djkeev
djkeev is offline
PostPosted: Mon Sep 05, 2022 4:07 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Here is a screenshot from benplace.......
I pretty much follow his advice except I use Hylomar Blue on the fire rings, cylinder to case, pushrod tubes.
Hylomar is an AMAZING sealant!
https://hylomar.com/en/
Amazon has it.......
Ghia
Vanagon
Beetle
hardway
hardway is offline
PostPosted: Mon Sep 05, 2022 4:09 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
For the O-rings at the cylinder, both green and black I use the slightest amount of Syl-Glide or Dow Corning silicone grease. I use the RTV supplied with the gasket set on the water jacket seal and at the base of the cylinder head acorn nuts.
djkeev
djkeev is offline
PostPosted: Mon Sep 05, 2022 4:15 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
My logic on that unlabeled tube of sealant is........ what the heck is it?!?!
And......
If it is VWs sealer ......... it didn't work well for them back in the 1980's!
I'm going with something newer and hopefully better....... the right stuff.
First thing I do when I open a gasket kit is to throw that yellow tube of mystery goo away. .
Ghia
Vanagon
Beetle
DanHoug
DanHoug is offline
PostPosted: Tue Sep 06, 2022 6:12 am    Post subject: Re: Yellow head bolt sealant?? Reply with quote
i have to get better at throwing things... i've got a bunch of those no-name tubes but i would never use one on the cap nuts, no reason to keep them. i really don't like the way it dries/cures into a hard crust that flakes off. so many better things out there.
-dan
www.thefixitworkshop.com
hardway
hardway is offline
PostPosted: Tue Sep 06, 2022 1:03 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
The waterboxer engines were originally delivered with the rubber water jacket seals installed dry against the cylinder head. The head was painted with a yellow substance. That was the original main failure point. The updated service procedure was to use an RTV at the joint. The RTV prevented the initial intrusion of coolant under the gasket that caused corrosion of the head.
I have never had any issue with the black RTV supplied with the head sets. Obviously chemical sealants can degrade with age in storage. Lots of counterfeit parts are being distributed some being very well disguised. If you really want the highest quality RTV silcone sealants, I would suggest Three Bond and Drei Bond products which are probably the same company. Toyota FIPG (form in place gasket) and Honda Bond are both truly excellent RTV sealers.
The main reason that I replied to the original poster was his mentioning oil on the o-rings. O-rings function best when lubricated but oil can adversely affect many types of rubber. Silicone grease is a safer lube for o-rings.
borninabus Premium Member
Samba R&D Dept.
borninabus is offline
PostPosted: Tue Sep 06, 2022 2:50 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
the "black sealant" in the VR kits is Reinzosil.
Reinzosil is the german engineered "mother of all RTV".
it is awesome stuff!
use it on all WBX sealing surfaces in the proper way Wink
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
robcurtis2
PostPosted: Fri Sep 16, 2022 1:23 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Cheers,
RC
Wondering if anyone could recommend what to use for each of my questions 1 thru 4? For example.....
1. Use (enter type of sealant name/brand)) for on the bottom of the cylinders and on the round black gasket and use this much applied to the ??.....
2. Use (enter type of sealant name/brand) on the little green round gasket at the top of the cylinder.
3. You can use the black rtv sealant that came with the black rubber head gaskets but (enter type of sealant name/brand) will work better.
4. (enter type of sealant name/brand) is better to use on the head acorn bolts in place of the little yellow sealant that came with the gasket kit.
Thank for your help.
Cheers,
RC
djkeev
djkeev is offline
PostPosted: Fri Sep 16, 2022 1:31 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
The Right Stuff
Rubber head gasket, both sides
Head nuts
Hylomar
Green O ring
Black O ring
Fire rings
Permatex 518
Push rod tubes
Grease
Valve Cover Gaskets
Add a smear of Hylomar on just about every gasket and Oring you encounter along the build process
Ghia
Vanagon
Beetle
robcurtis2
PostPosted: Fri Sep 16, 2022 2:03 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Seems like there are a lot of Hylomar products on their website to choose from.
Does anyone have a link for the Hylomar sealant that they use? And the Right Stuff has a few options also so if you could link that also would be helpful.
Thanks
RC
djkeev
djkeev is offline
PostPosted: Fri Sep 16, 2022 2:38 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Thanks
RC
https://www.amazon.com/Valco-Cincinnati-Hylomar-Ga...amp;sr=8-4
Hylomar blue
Get it from Amazon easily
Ghia
Vanagon
Beetle
Captain Pike
Captain Pike is offline
PostPosted: Fri Sep 16, 2022 2:40 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
When installing the heads I was taught to apply the black sealant on both sides of the rubber. Wait 20 mins then install. Torque 1/2 way and wait another 6 hours or so(usually overnight). Then complete the sequence. Idea being prevents "squish" out of the sealant.
Used the yellow goo but this was 25 years ago....
LEARN TO SELF RESCUE
....Bad Sneakers....
robcurtis2
PostPosted: Fri Sep 16, 2022 2:49 pm    Post subject: Re: Yellow head bolt sealant?? Reply with quote
Thanks
RC
Hylomar blue
So this Hylomar? https://www.amazon.com/Hylomar-Universal-Non-Setting-Silicone-Jointing/dp/B07NJHZJQQ
This Right Stuff? https://www.amazon.com/Permatex-25228-Gasket-Maker...amp;sr=1-1
And this Permatex? https://www.amazon.com/Permatex-51813-Anaerobic-Gasket-Maker/dp/B0002UEONM
