mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5002 Location: Nor Cal 707
Posted: Sun Feb 02, 2020 9:15 am Post subject: Re: Lowering with T-1 spindels. |
Terry Gaudet wrote: |
Oh, and one more question. What is the overall width difference between the stock barndoor beam and a beetle k&l beam? I am also going to consider modifying an early beetle beam to fit barndoor chassis so I can use beetle spindles to mount my 356 brakes. |
I run 356 spindles and brakes on this with a stock BD beam. No need to swap to a beetle beam.
Posted: Sun Feb 02, 2020 9:18 am Post subject: Re: Lowering with T-1 spindels. |
Thanks for posting the picture Mr. Warehouse. It helps me see the mods.
So these will fit on 55-63 bus front beam arms? |
They will work on early arms.
I have spindles ready to bolt on if you need/want a set that are done.
I have 356 and T1 beetle. Whichever suits your needs. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2365 Location: Graz, Austria, Europe
Posted: Sun Feb 02, 2020 11:02 am Post subject: Re: Lowering with T-1 spindels. |
djfordmanjack wrote: |
that is a terrific looking early truck ! loving the bias ply on white steelies over aluminium drums. perfect stance too! |
Thanks. I have a set of slotted 356 16's as well. I may run them instead. I'm still in the "mocking up" stages. |
Posted: Sun Feb 02, 2020 11:28 am Post subject: Re: Lowering with T-1 spindels. |
These days it is very rare for people to run bias ply on steelies under a somewhat lowered bus ( I know yours is already severly lowered considering the tall tires). the pie-crust of bias ply tires just kills me all the time. I personally just don't like the looks of the average modern low cross section radial tires at all. Really refreshing to see your set up. imho the factory steelies work just great over the Porsche drums and without hubcaps. all serious business. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Sun Feb 02, 2020 11:55 am Post subject: Re: Lowering with T-1 spindels. |
These days it is very rare for people to run bias ply on steelies under a somewhat lowered bus ( I know yours is already severly lowered considering the tall tires). the pie-crust of bias ply tires just kills me all the time. I personally just don't like the looks of the average modern low cross section radial tires at all. Really refreshing to see your set up. imho the factory steelies work just great over the Porsche drums and without hubcaps. all serious business. |
I'm going the "Vintage Speed" route with a Porsche internal 1500cc 36hp based dual P-11 engine for power so, I wanted to keep the tire with the correct look as well. It took quite a while to find Firestone's that matched the rear in a "low profile" |
Posted: Sun Feb 02, 2020 12:27 pm Post subject: Re: Lowering with T-1 spindels. |
They are probably 4.50/4.75 -16 Also use them on hotrods and going to put on my Barndoor project. it is not easy to cope with the tall tires on a lowered bus. |
Correct.
Last edited by mr. warehouse on Sun Feb 02, 2020 5:00 pm; edited 2 times in total |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71525 Location: Phoenix 602
Posted: Sun Feb 02, 2020 4:40 pm Post subject: Re: Lowering with T-1 spindels. |
mr. warehouse wrote: |
Correct.
I tried to post a photo but the Samba software didn't like toe URL |
Post a link without making it an image link with [img] _________________ How to Post Photos
bally Samba Member
Joined: April 29, 2006 Posts: 1195 Location: Melbourne, Australia
Posted: Mon Dec 21, 2020 1:46 am Post subject: Re: Lowering with T-1 spindels. |
Greg. Are those stock 15" rims with stock tyres? I like the look! I'm wondering if I can run stock 16s with stock tyres on a barndoor lowered with type 1 spindles and tubs? Has anyone done this? I'd live to see some pictures if they have please.
Cheers. Dave |
Posted: Mon Dec 21, 2020 8:25 am Post subject: Re: Lowering with T-1 spindels. |
bally wrote: |
Cheers. Dave |
They are stock 16's with stock tires in the rear and smaller tires in the front.
I've switched it up a bit since that photo. It's now running a hybrid dropped spinde setup with 16x5.5's and low profile radials.
I was waiting on tires when I took this photo
Fronts on, still tweaking the rear.
My point being, if you're looking for stock tires. I have the stock rears and smaller front that were on this single cab earlier. I may even have 4x stock sized tires available. |
bally Samba Member
Posted: Mon Dec 21, 2020 6:54 pm Post subject: Re: Lowering with T-1 spindels. |
Thanks Greg, it looks great on those stock 16s and bias plus. I'm aiming for using coker's new bias look radials. I assume you used the smaller front Tyres to avoid rubbing? The Coker Tyres are about 17mm (3/4") taller than your fronts soba mild tub should sort that out.
Cheers. Dave |
Posted: Mon Dec 21, 2020 10:36 pm Post subject: Re: Lowering with T-1 spindels. |
bally wrote: |
Cheers. Dave |
Correct, smaller front tires to avoid rubbing. My new set up is 6" of bolt-on drop at the spindles. Still a factory VW barndoor beam. I will be doing a minimal tub as well to clear the low profile 16" tires. |
Posted: Wed Feb 16, 2022 7:07 pm Post subject: Re: Lowering with T-1 spindels. |
Last photos before tucking it away in storage and ultimately selling...
Dropped T1 spindles with a 4" narrowed/adjustable "stock" barndoor beam.
The new owner has since finished it off and has been cruising it with no issues. Plenty of photos and videos can be found on IG |
johnny d Samba Member
Joined: March 22, 2004 Posts: 2204 Location: where it all came from. ;)
Posted: Thu Feb 17, 2022 12:46 am Post subject: Re: Lowering with T-1 spindels. |
sits pretty awesome Greg! _________________ GermanRestoKommando
Der Barndoor Führers - Slamm Society
VWKernzentrale since 2007 |
bally Samba Member
Posted: Fri Oct 21, 2022 10:12 pm Post subject: Re: Lowering with T-1 spindels. |
What discs are people using with type 1 spindle conversions? Type 1 discs?
Many thanks,
Dave |
Posted: Sat Oct 22, 2022 8:32 pm Post subject: Re: Lowering with T-1 spindels. |
bally wrote: |
Many thanks,
Dave |
Correct.
There are plenty of off-the-shelf 5x205 kits that work.
For 5x130 I use my own kit, as seen here.
bally Samba Member
Posted: Sun Oct 23, 2022 3:31 am Post subject: Re: Lowering with T-1 spindels. |
bally wrote: |
Many thanks,
Dave |
Correct.
Thanks Greg. I’m after 5x205  |
