panard2013 Samba Member
Posted: Mon Oct 24, 2022 3:44 pm Post subject: Painting the dash |
I was wondering if anybody has tried painting the black dash veneer to the body color? |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2761 Location: Santa Cruz, CA
Posted: Tue Oct 25, 2022 7:15 pm Post subject: Re: Painting the dash |
It’s not uncommon to remove the veneer first, then paint the dash face. Just painting over the veneer probably isn’t such a good idea. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Peter D. Samba Member
Joined: February 25, 2004 Posts: 754 Location: Connecticut
Posted: Tue Oct 25, 2022 7:49 pm Post subject: Re: Painting the dash |
If you have a later Ghia with a black plastic dash, it's likely that when you remove it there will be a bunch of slots and holes. You'll have to do some welding, grinding, and smoothing before you paint. Or do a dash swap with an earlier year. _________________ 2019 Golf Alltrack, '65 Ghia Coupe Restoration in Progress |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4157 Location: Georgia
Posted: Wed Oct 26, 2022 6:59 am Post subject: Re: Painting the dash |
You can paint the plastic. Just apply an adhesion promoter first. _________________ Volkswagen!
(Compression 8.7:1) |
ovalboy Samba Member
Joined: May 04, 2004 Posts: 1312 Location: Beautiful Northern Cincinnati
Posted: Wed Oct 26, 2022 9:04 am Post subject: Re: Painting the dash |
'65 dash in my '67 Ghia. No dash pad. Filled the speaker opening and squirted paint on it.
Braukuche Samba Member
Posted: Wed Oct 26, 2022 9:11 am Post subject: Re: Painting the dash |
ovalboy wrote: |
Looks like you also filled the other holes as well that are punched into the face and underside of the late dash. Looks good. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
