Westy Table vertical slider modification (How-to)
Page: Previous  1, 2, 3, 4, 5
Sodo
Sodo is offline
PostPosted: Sun Nov 20, 2022 11:01 am    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
I need a better solution, mine (on p1) works “ok”, but is just barely strong enough.
The simplicity of the magnet as a holder still appeals to me.
I might try larger magnets (3/8 diameter).
But if that doesn’t work maybe try something like jimf909.
Regarding those neodymium magnets screwed to the wall.
They don’t break at the screw hole?
Neodymium is brittle as glass.
....KTMs, GasGas, SPOT mtb
kamzcab86
kamzcab86 is offline
PostPosted: Sun Nov 20, 2022 2:11 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
You can buy predrilled versions: https://amfmagnets.com/products/neodymium-ring-12-5mm-x-3mm-x-6mm-sth-c-sunk-face
https://totalelement.com/products/1-2-x-1-2-x-1-4-...52-10-pack
Best idea for table swing, IMHO:
plummerdesign wrote:
The elevating table is neat, especially to access the bins below. My fix was not for bin access, but for keeping the table in place when not using it. Simple solution using a child latch...cheap and works like a charm. No more swinging table!
~Kamz Anxious
2016 Golf GTI S
jimf909
jimf909 is offline
PostPosted: Sun Nov 20, 2022 8:16 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
This magnet (see prev. page) has worked swimmingly since 2019 for me, nothing has broken after hundreds(?) of cycles. I believe I tried the round magnets and didn't get enough stick-to-it-ive-ness with them. I don't believe the table has ever released from this magnet in my high-speed slalom runs on the skid pad. Wink Very Happy
p.s. I wish the straps I screwed to the table looked better but I haven't noticed them in years...until looking at that post.
Oy! I paid $8.76 for it back in 2019.
https://www.amazon.com/gp/product/B013L36SXA/ref=p...15e690da65
- Jim
Butcher wrote:
Guilty as charged.
Jan Steinman
Jan Steinman is offline
PostPosted: Mon Nov 21, 2022 10:26 pm    Post subject: Reply with quote
PDXWesty wrote:
With the table up, you can get in the bins but you can't use the table or get in the closet. I like to get in the closet.
I'm glad it works for someone!
I despise the closet so much that we took it out! Rather, we cut a huge hole in the inside of the closet insert, and put more shelves in there. We were going to put sliding doors on it, but after using it, we like it open.
I guess if you have clothes that hang, you need a closet. When we're camping, clothes that require hanging are banned.
vanis13
vanis13 is offline
PostPosted: Mon Nov 21, 2022 10:36 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
I LOVE the raised table and if I put the small table there I can open the closet
Beast McGee
Beast McGee is offline
PostPosted: Fri Jan 06, 2023 5:23 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
So I've got the Van Cafe rear table extender kit here, and first step is to remove the table leg...which apparently has a flange at the bottom in my 1982! Do I need to get out the sawzall or maybe hack saw and take that off so I can install this baby? Anyone have experience with this issue? It's after their hours and I'd love to finish this project so I can put my van back together to travel tomorrow Cool
Sodo
Sodo is offline
PostPosted: Sat Jan 07, 2023 6:31 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
Beast McGee wrote:
So I've got the Van Cafe rear table extender kit here....
The Westy table leg simply slides vertically out of the hole.
Do you have a Westfalia?
You should probably float us a pic of the problem before going after it with the SawZall.
fxr
fxr is offline
PostPosted: Sat Jan 07, 2023 7:35 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
I seem to remember a rivet that had to be filed off. But it was a long time ago...
Jim Crowther
Vespa GTS 300
latelogan
latelogan is offline
PostPosted: Thu Jun 12, 2025 10:31 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
This is an oldie, but new to me!
I ran out got the 24" length of 3/4" BIP and 2 1/2" electrical conduit lock nuts and had this done in about an hour! (cut off about 1.5" for total length of ~22.5")
I added an LDPE washer at the bottom to make it turn smoother (instead of metal on metal) when its all the way down.
And then I cut a collar of the same LDPE and stuck it in the end of the table leg pipe as a spacer. (don't know if it will move in the long run, but it seems pretty stable so far
Thanks to all the posters for this one! I wouldn't have realised how much I needed this mod without seeing it!
Amazing. My wife cant stop smiling about this one! ($10 bucks!!!)
Makes me wonder what other goodies are in the depths...
Maybe we should have a best mod thread!
1991 Westy stock 2.1 auto transmission
1978 Westy (Sold)
1971 Westy (Sold)
Alaskaberrys Premium Member
Alaskaberrys is offline
PostPosted: Thu Jun 12, 2025 10:51 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
Great reading here as to that: https://www.thesamba.com/vw/forum/viewtopic.php?t=171071&highlight=favorite+mod
And I agree, that table mod is fantastic. One of our favorites.
Sodo
Sodo is offline
PostPosted: Fri Jun 13, 2025 4:14 pm    Post subject: Re: Westy Table vertical slider modification (How-to) Reply with quote
You could drizzle these out as-needed....
Westy Table ratchet-handle clamp
Westy Table support knee bend
Page 5 of 5
