hanapaa Samba Member
Posted: Fri Mar 02, 2007 11:18 am Post subject: deep 6 (901) question. |
I have a pair of deep 6's part# 901.361.012.06 and it does NOT have hearts. My question is if that's cottect?
Or is the deep 6 with part# 901.361.012.00 ONLY supposed to have hearts? I did a search but there wasn't enough specific information.
MAHALO |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10794 Location: San Diego, CA
Posted: Fri Mar 02, 2007 4:02 pm Post subject: |
| I have two pairs just like that. They are suppose to have the hearts but i think back in the days people grinded the hearts down, doesn't mean they are not real but they cant hold the same value as ones with the hearts.......... |
Posted: Fri Mar 02, 2007 5:55 pm Post subject: |
Thanks alot Rich I had a feeling it would of been one of you GFK guys to answer that.
I have one more question on that rim...
I put it on my 57 oval today and the inside tire wall was rubbing the shock tower (were the body bolts to the shock tower) is it because I have a short axle trans and you guys have a long axle trans? |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2826 Location: Centennial, CO
Posted: Fri Mar 02, 2007 6:09 pm Post subject: |
| There are indeed deep 6's w/o hearts. Not all of them were ground down. I have pics of a 912 on my phone that had all originals w/o hearts. |
Posted: Fri Mar 02, 2007 9:18 pm Post subject: |
| hanapaa wrote: |
I'm runing short axle on the split but i had to put 1 inch spacers so it wouldn't rub on the shock bolt. I have deep 6's with 205/70 in the rear and they dont rub at all. |
Posted: Fri Mar 02, 2007 9:20 pm Post subject: |
| scottvw wrote: |
Thats news to me i never had seen an og deep 6 with a 901 number with no hearts, I'm calling bullshit on that my friend  |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17694 Location: Left coast, Canada
Posted: Sat Mar 03, 2007 2:07 am Post subject: |
I've seen plenty of them. The very last deep 6s were like that. Check the date stamps and post. They will all be close to each other. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Skim Rants Master
Joined: April 15, 2001 Posts: 17098 Location: GFK 33 Year Vet
Posted: Sat Mar 03, 2007 2:20 am Post subject: |
The pair on the back of my split have no hearts. I got fucked on that one because I sent my rims out and when John delivered them he brought like 5 sets over, everybody grabbed their sets and I was left with 2 without the hearts. I got there late and got early owned. _________________ GFK
1953 Kabriolet
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
joe comfort Samba Member
Joined: March 18, 2005 Posts: 409 Location: Lake Havasu, AZ.
Posted: Sat Mar 03, 2007 9:09 am Post subject: |
| There are 4 right now on e*ay with NR and 2 of them have no hearts, info from seller due to bad pics. |
Posted: Sat Mar 03, 2007 1:05 pm Post subject: |
Why is it in the other thread http://www.thesamba.com/vw/forum/viewtopic.php?t=67203 they list all 901... part numbers from 4.5's - 7r's but not 901...06 they only mention 6" 901...00 and 901...03?
I got some pics of the numbers on back (not the greatest).
on the top it has the 901...06 part number, bottom left it has AS1 08, fox head and on the right it has 26710.
Is the AS 1 08 the date ?
Posted: Sat Mar 03, 2007 5:45 pm Post subject: |
| Rich's 50 wrote: |
| hanapaa wrote: |
were can I get 1 inch spacers? |
Posted: Sat Mar 03, 2007 6:24 pm Post subject: |
| hanapaa wrote: |
| Rich's 50 wrote: |
| hanapaa wrote: |
Pep boys or any tire shops.........If you cant find them let me know and i will send you some..... |
Bruce Samba Member
Posted: Sun Mar 04, 2007 2:49 am Post subject: |
| hanapaa wrote: |
| Is the AS 1 08 the date? |
No. That is the alloy designation. The alloy numbers on all Fuchs are an internal code that don't conform to any industry standard.
The closest alloy is 6082.
The date code is stamped in between the lug holes, closer to the centercap hole, eg. 1069 for Oct 1969. _________________
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5002 Location: Nor Cal 707
Posted: Sun Mar 04, 2007 2:57 am Post subject: |
| Rich's 50 wrote: |
| hanapaa wrote: |
| Rich's 50 wrote: |
| hanapaa wrote: |
Wide 5 to Porsche adapters will do the same trick. |
Posted: Sun Mar 04, 2007 7:14 pm Post subject: |
| I found the dates and it says 1270, dec. 70 |
vdubinit Samba Member
Joined: July 11, 2005 Posts: 1870 Location: central coast
Posted: Sun Mar 04, 2007 10:22 pm Post subject: |
| Rich's 50 wrote: |
| hanapaa wrote: |
Can you run foxcraft skirts with that set up without any rubbing issues? _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Sun Mar 04, 2007 10:31 pm Post subject: |
| No it rubs on the skirts, i'm running 205/70/15 in the back |
Posted: Sun Mar 04, 2007 10:41 pm Post subject: |
| Rich's 50 wrote: |
thanks for the heads up  _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Sun Mar 04, 2007 10:51 pm Post subject: |
I just got another set of deep's and these have the date stamp of 7 69
(july '69) and yes it does have the hearts. I guess somewere between july '69 and december '70 they changed.
Also I noticed that the outside lip is different. The ones with the hearts have a rounder lip just like the 4.5, the ones with out the hearts have a more square edge (lip) like the late 6". |
Posted: Mon Mar 05, 2007 8:21 am Post subject: |
| hanapaa wrote: |
Really, do you mind taking some photos of those areas because all of mine look the same....... |
