trailer hitch
motersickle
motersickle is offline
PostPosted: Mon Jul 02, 2007 1:44 pm    Post subject: trailer hitch Reply with quote
i'vw got a 69 with T-bar style bumpers. I am looking for an trailer hitch that will work with this style bumper. if anyone knows how to build one that does not have to tie into the bumper i would like to know. any comments and or observations will be welcomed.
thanks
ampegboy1
ampegboy1 is offline
PostPosted: Mon Jul 02, 2007 2:09 pm    Post subject: Reply with quote
Hi motersickle,
My Peka/VW towbar is essentially a big A-frame which attaches with U-bolts around the rear torsion tube to do the pulling, then clamps to the frame forks and bolts to the bumper to share the vertical load.
I reckon you could rig up a similar affair with a bracket that attaches to the bumper mounts instead of the bumper itself.
HTH,
Michael
motersickle
PostPosted: Mon Jul 02, 2007 3:19 pm    Post subject: Reply with quote
ampegboy1
is it made out of flat stock or square tubing??
thanks
Vedauwoo
Vedauwoo is offline
PostPosted: Tue Jul 03, 2007 6:41 am    Post subject: Reply with quote
Hmmm, a trailer on an Air Cooled VW......
No Better way to ruin the Transmission!
1974 Beetle
Beetle's Big Brother
Junkwaffle-181
bugninva
bugninva is offline
PostPosted: Tue Jul 03, 2007 6:48 am    Post subject: Reply with quote
hmm...so by that way of thinking, passengers is a big no-no?
(when pulling a trailer with a type one, the brakes are your main concern, not the transaxle, which is fairly robust.)
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
Scott H
Samba Luddite
Scott H is offline
PostPosted: Tue Jul 03, 2007 6:56 am    Post subject: Reply with quote
It hasn't ruined mine.
Scott
oc92 wrote:
I like the soul of an old car to be visible...
NOVA Airhead
NOVA Airhead is offline
PostPosted: Tue Jul 03, 2007 7:01 am    Post subject: Reply with quote
VW says its Ok to tow. 882 pounds for a trailer without brakes - 1,433 with brakes.
Here is the reference in the '74 Owner's Manual:
http://www.thesamba.com/vw/archives/manuals/74beetle/74T1-30.jpg
Ghia Owner Emeritus
ampegboy1
PostPosted: Tue Jul 03, 2007 10:48 am    Post subject: Reply with quote
I can't see why the transmission would care unduly about towing a trailer. Surely a load is a load is a load to the transmission. My dad used to tow his boat trailer all day with his GT Beetles and never once had the transmission complain. I can see why applying the load brutally can upset it, but I tend to shy away from racing launches with a trailer Smile
Anyway, the A-frame of the Peka hitch is made from L-section, with the flat part 'against' the car and the downward part towards the outside. I tried to take a picture, but even my widest lens wasn't man enough! It's more or less identical to the version for the Ghia:
http://www.thesamba.com/vw/archives/manuals/misc.php
The design brings two nice bonus features - since it passes under the sump, it offers some protection from large things like speed bumps. Believe it or not, it also stiffens up the back end a little, resulting in a slight but noticeable improvement in 'chuckability'!
Michael
Vedauwoo
Vedauwoo is offline
PostPosted: Tue Jul 03, 2007 12:23 pm    Post subject: Reply with quote
Folks will say, and probably have towed all sorts of things....but....one thing I have learned when it comes to trailers and weights and such is that most folks have no clue and/or never check the actual weight...they just assume they are ok....many do not even consider the weight of the trailer it self in that 882 lbs. Depending on what you have, you may be ok or you may be overcapacity with the trailer hooked up alone.
1974 Beetle
Junkwaffle-181
motersickle
PostPosted: Tue Jul 03, 2007 2:39 pm    Post subject: Reply with quote
I've got a trailer that is a diamond plate aluminum tool box that is mounted on torsion bar axles. I have pulled it all over the country with my stock HD motorcycle. The tongue weight isn't over 60# so i think it will pull all right. I appreciate everyone's input. I came up with a plan and started putting it together today. I'll let ya'll know hwo it turns out. Once again thanks everyone.
G
GA_Boy
GA_Boy is offline
PostPosted: Tue Jul 03, 2007 4:33 pm    Post subject: Reply with quote
G
I wouldn't worry about the tranny as long as it is properly lubricated, but I would keep the RPM's up on long uphill pulls to keep the heads as cool as possible. If I were going to add any one gauge it would be a CHT gauge.
Marvin
Scott H
Samba Luddite
Scott H is offline
PostPosted: Tue Jul 03, 2007 8:22 pm    Post subject: Reply with quote
G
Have any pictures of the trailer?
Scott
motersickle
PostPosted: Wed Jul 04, 2007 8:23 am    Post subject: Reply with quote
i can email you some pictures of the trailer if you would like. I don't know how to insert them in to this reply or if it can even be done. Send me an address and i would gladly forward some pics.
Scott H
Samba Luddite
Scott H is offline
PostPosted: Wed Jul 04, 2007 7:33 pm    Post subject: Reply with quote
PM sent. Thanks!
Scott
motersickle
PostPosted: Fri May 08, 2015 12:14 pm    Post subject: Reply with quote
only 8 years later but here are the pics
[/img]
"You may all go to hell and I will go to Texas" Davy Crockett
mikeonthebike
mikeonthebike is offline
PostPosted: Fri May 08, 2015 9:56 pm    Post subject: Reply with quote
I'd like to see how you have that mounted underneath.
andrewvwclassic
andrewvwclassic is offline
PostPosted: Fri May 08, 2015 11:10 pm    Post subject: Reply with quote
You da man!
motersickle
PostPosted: Mon May 11, 2015 7:01 am    Post subject: Reply with quote
Next time i have it up in the air i'll take a pic and post it
i promise it will not take me 8 years this time
vwwestyman
vwwestyman is offline
PostPosted: Sun May 24, 2020 5:56 am    Post subject: Re: trailer hitch Reply with quote
...You've got 3 years left!
Ha ha
Dave Cook
1973 Wild Westerner
My Thing
