Pulley Engine Tin Removal
b15605
b15605 is offline
PostPosted: Thu Jun 18, 2009 10:09 am    Post subject: Pulley Engine Tin Removal Reply with quote
Can someone tell me how the tin behind the pulley is attached? All I can see is a bolt behind the pulley, but that is it. Can it be done with engine in the car - I think I have something behind the pulley and this seems simpler than trying to pull the pulley off.
Thanks
Gary
Person of Interest
Gary is offline
PostPosted: Thu Jun 18, 2009 10:13 am    Post subject: Reply with quote
Guess what, the pulley has to come off.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jun 18, 2009 10:14 am    Post subject: Reply with quote
there's two M6 screws and yes, the pulley needs to come off.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
72BajaBen
72BajaBen is offline
PostPosted: Thu Jun 18, 2009 10:48 am    Post subject: Reply with quote
While you have the pully off....you should repalce it with a nice shinny new one.
Semper Fidelis
Build thread - https://www.thesamba.com/vw/forum/viewtopic.php?p=9762332
b15605
b15605 is offline
PostPosted: Thu Jun 18, 2009 1:50 pm    Post subject: Reply with quote
So can the pulley be removed in the car, or does the engine have to come out?
Brian D
Brian D is offline
PostPosted: Thu Jun 18, 2009 1:58 pm    Post subject: Reply with quote
You can do it with the engine still in the car. You'll need a large screwdriver and a 30mm socket to remove the nut.
'70 Beetle (the girlfriend's but I'm the wrench)
'72 1302 S (rest in peace)
'90 Chevy C1500
Gary
Person of Interest
Gary is offline
PostPosted: Thu Jun 18, 2009 2:12 pm    Post subject: Reply with quote
Screwdriver?
saucerman
saucerman is offline
Be sure to check the torque table when you re-install. It is only 40 ft pounds or so when it goes on, but please do not take my word for it, check in the manual.
70 Beetle (1776 MoFoCo)
68 Bus (1600DP)
02 Beetle
I have my Bus, my backpack full of food and my AK47...bring on the Zombies!
Brian D
Brian D is offline
PostPosted: Thu Jun 18, 2009 2:19 pm    Post subject: Reply with quote
Icy wrote:
Screwdriver?
To hold the pulley in place so it doesn't move, and to pry it off the crank once the bolt is off.
Of course, none of this applies if a special pulley removing tool is used.
'90 Chevy C1500
Gary
Person of Interest
Gary is offline
PostPosted: Thu Jun 18, 2009 2:22 pm    Post subject: Reply with quote
Brian D wrote:
Icy wrote:
Screwdriver?
Don't do that. It damages the pulley.
saucerman
PostPosted: Thu Jun 18, 2009 2:25 pm    Post subject: Reply with quote
What do you have behind the pulley? Is this the only reason you want to remove the pulley tin?
68 Bus (1600DP)
02 Beetle
b15605
b15605 is offline
PostPosted: Thu Jun 18, 2009 2:58 pm    Post subject: Reply with quote
I know there is a 10mm socket back there that accidentally dropped and I am thinking there may be a screw back there as I have a clacking sound coming from the pulley. At least I can eliminate the screw theory if I can get back there.
b15605
b15605 is offline
PostPosted: Thu Jun 18, 2009 4:02 pm    Post subject: Reply with quote
Nevermind - I am an idiot - I didn't look very carefully under the car last night and it had spit out the socket I thought was back there. Sorry for the trouble on the subject.
I will start a new thread to try to track down my problem.
