Nifski Samba Member
Posted: Fri Sep 04, 2009 9:15 am Post subject: Early Oval fender Identification |
I am currently restoring a '54 Sedan and have these two bullets, my first intention was to remove the bullets if I could not locate the correct fronts but upon taking the car apart I noticed the differences in the running board flares as well as the headlight buckets, the fender shapes look the same.
Which one is earlier? which one (shape) would be correct for my car other then the bullet. I would rather buy correct fenders if anyone knows of any, but need to get educated on this as plan B .Thanks for any help!
Oval fender differences
Drivers side bucket
Passenger side bucket
Driver side flare
Passenger side flare
joshbuchan Samba Member
Joined: April 12, 2007 Posts: 712 Location: victoria bc canada
Posted: Fri Sep 04, 2009 10:14 am Post subject: |
pass side looks right, the bucket on pre 55 should be smooth like that with no vertical pressings not sure why it would have a bullet... mabey late 55  |
Braukuche Samba Member
Posted: Fri Sep 04, 2009 11:11 am Post subject: |
joshbuchan wrote: |
Check the housing on the non-flared fender. I'll bet its added on and not an original bullet fender.
--Dan |
Nifski Samba Member
Posted: Fri Sep 04, 2009 11:21 am Post subject: |
After taking a close look, the passenger side has had the bullet added, so this means it was an early oval fender, '55 or older with an added bullet, correct? |
slowtwitch Samba Member
Joined: July 03, 2004 Posts: 730 Location: just north of philly
Posted: Fri Sep 04, 2009 12:36 pm Post subject: |
I'm in the proces of saving a pair of early fenders. As has been mentioned , early fenders had a smoother headlight bucket.
Another way to determine if you have early fenders, is to take a measurement across the fender. Take a tape measure, place it centered with the top most mounting hole (5th hole, either from the front or rear) and mearsure to the lip of the fender.
This is a later fender....
This is an early fender...
As you can see, there is about an inch difference.
hope this helps _________________ pete |
janerick3 Samba Member
Posted: Fri Sep 04, 2009 8:29 pm Post subject: |
joshbuchan wrote: |
My og late '56 buckets don't have the vertical pressing either, so the passenger side is probably off a late oval. The bullets are only spot-welded on, so they are relatively easy to remove and replace if the fender was repaired.
The driver's side is probably genuine VW from the '60s, as the horn grill hole is the same location as the pass. side (unlike aftermarket fenders). Look for a welded-up turn signal hole on top. _________________ Thanks,
Jan K. |
Nifski Samba Member
Posted: Sat Sep 05, 2009 11:32 am Post subject: |
Seems like two different responses,can we get a few more opinions?Thanks. |
oval-man Samba Member
Joined: September 27, 2006 Posts: 7 Location: United kingdom
Posted: Wed Sep 09, 2009 5:00 am Post subject: Re: Early Oval fender Identification |
[quote="Nifski"]Oval fender differences
Drivers side bucket
Hi
The drive side one is 100% not a oval wing it's for a 60's car due the headlamp bowl is the wrong shape.
but the other one is for a early oval 53> 55 all you need to find a match.
good luck
Jay _________________ www.restowagenuk.com |
valentinesr Samba Member
Joined: June 30, 2008 Posts: 749 Location: Ontario, California
Posted: Thu Sep 17, 2009 7:27 am Post subject: Re: Early Oval fender Identification |
valentinesr wrote: |
Quote: |
Hi
good luck
Jay |
Uhhh, not to be a smarty pants Jay or anything..but they didnt have bullet fenders until midway through 55 when they started that modification..
I agree on the passenger side is an OG fender, see the bucket contour inside is smooth, along with the flared running board area. The drivers side has the dimpled rectangular indention inside the bucket..so from reading and have had a set of that style..Not original.
Fender Reference Threads:
http://www.thesamba.com/vw/forum/viewtopic.php?t=307483&highlight=fender
http://www.thesamba.com/vw/forum/viewtopic.php?t=295256&highlight=fender |
You are quite right there, when I post this I forgot about you guy with the bullet fenders I was referring to euro fenders with my quote with regards the year date.
I have both a 60's euro fender and an oval euro fender I will post some photo's up later so you can have look at.
