Best way to remove door hinge screws
Semper_Dad
Semper_Dad is offline
PostPosted: Wed Sep 08, 2010 4:59 pm    Post subject: Best way to remove door hinge screws Reply with quote
These just had to go
Ok, So I found a pair of brass door hinges with mirror mounts and I need to remove and replace the existing hinges.
Try as as I might, I can't get the screws to even budge. Placed the screwdriver on the screw and gave it a few raps with a hammer in an effort to lossen things up. Still no movement. I don't want to bung up the screwhead too much.
Ideas?
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
hank0306
hank0306 is offline
PostPosted: Wed Sep 08, 2010 5:17 pm    Post subject: Reply with quote
I can't remember if it is a #4 phillips, like the hood; if it is, I bet it comes off the same way. Go buy a #4 phillips bit for your ratchet, whack the phillips bit with a mallat then ratchet the screw off. I doubt you could produce enough force or torque with just a screw driver. There is another thread somewhere on the 181 samba thread that identifies the correct screwdriver head size....
vws-microcars4jim
vws-microcars4jim is offline
PostPosted: Wed Sep 08, 2010 5:30 pm    Post subject: Re: Best way to remove door hinge screws Reply with quote
hehe
My #3 Snap-On phillips screwdriver fits nicely, however those body screws can be stuck pretty good. I would use an impact driver to get it turning, just a screwdriver with a wrench on it may "bung it up."
If you don't have an impact driver an auto parts store might rent/lend you one.
Jim
77kafer
77kafer is offline
PostPosted: Wed Sep 08, 2010 5:46 pm    Post subject: Reply with quote
They look like they are already a little bunged up. Sad
What I used years ago was one of these. http://cgi.ebay.com/Professional-3-8-Impact-Driver...43a16f0d34
Works great for doing stuff like that.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
sixty9fasty
sixty9fasty is offline
PostPosted: Wed Sep 08, 2010 5:52 pm    Post subject: Reply with quote
hmmmm, mine came off just fine with a large screw driver.... soaked them a bit with penetrating oil first..
Semper_Dad
PostPosted: Wed Sep 08, 2010 5:54 pm    Post subject: Reply with quote
They're really not all that bad,....yet. Original color was yellow and now it has a crappy black one. Thanks for the idea. Looks like I need to take a trip to Sears tomorrow.
Bugs4Life
Bugs4Life is offline
PostPosted: Wed Sep 08, 2010 9:17 pm    Post subject: Reply with quote
Here is a link using a screw extractor, It's what I have done in past.
http://www.wikihow.com/Remove-a-Stripped-Screw
72 181 Ambulance
62 Ghia
Semper_Dad
PostPosted: Wed Sep 08, 2010 10:49 pm    Post subject: Reply with quote
Yeh, I've used a easyout before. (Ironically it was on a Mk 48 Torpedo hanging halfway out of a torpedo tube). Needless to say it still brings on a little PTSD Laughing
Chris in Santa Cruz, CA
Chris in Santa Cruz, CA is offline
PostPosted: Thu Sep 09, 2010 3:20 pm    Post subject: Reply with quote
http://www.ryobitools.com/catalog/18v_oneplus/drills_drivers/P230
This tool is the best thing I have purchased in a long time and is useful for driving deck screws as well as auto stuff. It works well for things like this.
current:Bugatti Type 35 kit car (74 beetle), 1972 Thing
previous: 1965 1500 Variant S (first car), 1976 Westfalia, 1978 Bus, 1982 Vanagon
Semper_Dad
PostPosted: Thu Sep 09, 2010 3:49 pm    Post subject: Reply with quote
I tried my Millwaukee 14V but it just didn't have enough umph.
However,......
BFH + KD 1140 + #4 Bit
= Success
kubelmann
kubelmann is offline
PostPosted: Thu Sep 09, 2010 4:00 pm    Post subject: Reply with quote
This is mostly a review of others posts but I offer it as a list.
1. I start with my #4 phillips socket on a ratchet handle.
2. If it does not come out, I attach the #4 to my battery powered impact gun.
3. If this does not work I apply PB blaster and wait. Then I try tool one and two again.
4. If still no luck a second application of PB blaster is applied and a longer wait is given. Finally I use my manual impact driver and that has gotten out every stuck hinge bolt I have attempted to remove.
I use the manual impact driver as a last resort because you can risk body damage when you strike the impact driver with the mini sledge hammer.
77kafer
77kafer is offline
PostPosted: Thu Sep 09, 2010 6:27 pm    Post subject: Reply with quote
= Success
Good job. Very Happy Keep in mind that a 2 lb. ball peen hammer would have worked also instead of the mini sledge.
kubelmann
PostPosted: Thu Sep 09, 2010 6:49 pm    Post subject: Reply with quote
My mini sledge weighs 24 oz. and looks like the pic you posted.... I guess I might have used the wrong word for the tool.
Semper_Dad
PostPosted: Thu Sep 09, 2010 8:35 pm    Post subject: Reply with quote
I was biting my lip on each whack. Didn't put full force into it.
I pretty much followed your level of force with the exception of the PB Blaster.
In my case the car had been repainted with the hinges still on and effectively "sealed" the screw into the countersink of the hinge. PB blaster or any other penetrate would have never made it in.
I took a sharp awl and scribed around the screwhead to break the shell. I also scored around the hinge with a razor blade so when I pulled it off the hinge there would be less chance the paint would peel off around hinge area. It worked.
kubelmann
PostPosted: Thu Sep 09, 2010 8:43 pm    Post subject: Reply with quote
totally understand the "no PB" zone I know exactly what you mean about the hand held impact tool. I have seen others do damage with it. As a result I use it very gently and sparingly on our precious vintage bath tubs.
[email protected]
mpb181@aol.com is offline
PostPosted: Sat Sep 11, 2010 11:34 am    Post subject: Reply with quote
I would recommend using only a #4 philips tip on those
When you remove the screw whack that impact tool on forward first, this will free it up and then back it out.
I would use some pb blaster also.
Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173
Ferretkona
Ferretkona is offline
PostPosted: Sun Sep 12, 2010 12:11 pm    Post subject: Reply with quote
I used a #4 in my cordless impact and they backed out nice and clean. I had tried my 10V Bosch but it was not enough, I used a Hitachi 18V and it backed out. Have to keep the bit in tight so you do not mess up the screw.
74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6
