maco70 Samba Member
Joined: March 16, 2011 Posts: 500 Location: Montréal, Québec
Posted: Sat Jun 16, 2012 7:17 pm Post subject: original Vanagon bra with word "VANAGON" on it |
On the original bra from VW, the word VANAGON was writting on the upper left side of the bra.
I would like to make done locally a sticker with the correct font and width and height of the letters.
Can somebody help me on this, with a photo and / or some dimensions of the font ?
Thanks in advance _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Sat Jun 16, 2012 11:38 pm Post subject: |
A sticker is easy to ship/mail - why would you limit people from responding to the thread unless they are local (Montreal)?
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
maco70 Samba Member
Posted: Sun Jun 17, 2012 3:46 am Post subject: |
you misunderstood, or i wrote uncorrectly, or both.
I don't think this kind of sticker / decal already exist. If it is the case, i would like to purchase it.
But i believe it doesn't exist and i would like to get the measurement of the word VANAGON on the original Bra, and then i would make it done locally. _________________ Martin from Montréal
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8519 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jun 17, 2012 5:40 am Post subject: |
Here's mine - just not sure how "original' it is:
FWIW, I'm sceptical that a sticker will last on the hot/cold/flexible/brittle vinyl bra...sounds like a recipie for adhesive failure.
Check into a local embroidery shop - a modern computer controlled machine uses the same
graphics info as a sticker shop, gives better results and it'll last the life of the bra...
Definitely more "original" as well.
[/$.02] _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Sun Jun 17, 2012 10:24 am Post subject: |
SOT but do you find that bras damage the paint? I assume you use them for protection of the nose ~ do they provide more protection than harm in the long run? They look nice, especially with the embroidery, and i have lots of rock chips on my nose... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Posted: Sun Jun 17, 2012 11:41 am Post subject: |
This is only our fith summer with the van, but here's my take:
I usually leave the bra off while the van's being used for around town & short excursions/overnights
(doesn't get a lot of miles & not much traffic throwing rocks, etc.) but I've always put it on for our long roadtrips.
Seems like leaving it on all the time would risk some abrasion through wax & paint (I have noticed
some dulling due to dirt along the edges when I take it off after said roadtrips, but cleans up
with polishing compound); but off all the time risks more dings & paint chips like you're seeing.
The only time I wish I'd definitely had it on was this summer when I hit a good-sized bird
a glancing blow across the nose; now I've got a baseball-sized divot right above the upper
grille - might have been prevented with the bra in place.
"The WonderVan"
Posted: Sun Jun 17, 2012 11:45 am Post subject: |
That sounds like wise bra usage. I also have some hail damage to that same panel between the windshield and the grille...may wait until paint job and then use a bra as you do. Thanks _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
kamzcab86 Samba Moderator
Posted: Sun Jun 17, 2012 11:48 am Post subject: |
The embroidery on the above bra is nothing more than an outline of the Vanagon badge on the hatch. Take a good, clear, large photo of your badge and head over to your local embroidery shop with the bra. Unless someone already has a line drawing of the badge they could post up, as that would be even better for the shop.
| tarandusVDub wrote: |
| SOT but do you find that bras damage the paint? I assume you use them for protection of the nose ~ do they provide more protection than harm in the long run? They look nice, especially with the embroidery, and i have lots of rock chips on my nose... |
http://www.thesamba.com/vw/forum/viewtopic.php?t=492479
http://www.thesamba.com/vw/forum/viewtopic.php?t=469992
http://www.thesamba.com/vw/forum/viewtopic.php?t=443044
http://www.thesamba.com/vw/forum/viewtopic.php?t=186140
Edit:
| dhaavers wrote: |
(doesn't get a lot of miles & not much traffic throwing rocks, etc.) but I've always put it on for our long roadtrips. |
Ditto. Always make sure the bra is clean; always make sure the paint is clean. Remove it when not on road trips; remove it when in rainy weather. Used properly, bras do more good than harm... as all three of my VWs will attest to. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Sun Jun 17, 2012 12:01 pm Post subject: |
Ah, I see the topic has been extremely well 'covered'...thanks _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
Navy_Flyer Samba Member
Joined: January 08, 2012 Posts: 474 Location: Staunton, VA
Posted: Mon Sep 10, 2012 11:41 am Post subject: |
Does use of a bra increase operating temps? Just wondering if the slightly reduced airflow across the radiator has any ill effect. Thinking of adding a bra to mine, solely because of the ugly dents/scratches on the front that a bra would disguise. Easier than a dent removal/refinish, for now. But I am concerned about possibility of running hotter. _________________ 1987 Westfalia, Automatic. EJ25 VANARU Conversion |
Posted: Mon Sep 10, 2012 1:13 pm Post subject: |
| Navy_Flyer wrote: |
| Does use of a bra increase operating temps? Just wondering if the slightly reduced airflow across the radiator has any ill effect. Thinking of adding a bra to mine, solely because of the ugly dents/scratches on the front that a bra would disguise. Easier than a dent removal/refinish, for now. But I am concerned about possibility of running hotter. |
The bra has zero affect on my van's cooling; the gauge reads the same with or without the bra. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Mon Sep 10, 2012 4:00 pm Post subject: |
| kamzcab86 wrote: |
| Navy_Flyer wrote: |
The bra has zero affect on my van's cooling; the gauge reads the same with or without the bra. |
Mine too, but I've cut away some of the insect screening. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Thu Sep 19, 2013 3:30 pm Post subject: |
Anyone know of a bra that works with the SA grille? _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Thu Sep 19, 2013 4:30 pm Post subject: bra |
| Anyone know of a bra that works with the SA grille? |
They all do, all you need is a pair of scissors.
 _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Posted: Thu Sep 19, 2013 5:29 pm Post subject: Re: bra |
| joseph928 wrote: |
| They all do, all you need is a pair of scissors. |
Yep. Just buy one of these
(or the single-round version) and cut the excess screen off. For a more professional job, sew some felt to the raw edges of the freshly cut screen.
Or, just go with the single-round version and do nothing to it:
I've not come across a S. African grille-specific bra. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Fri Sep 20, 2013 7:39 am Post subject: |
OK, nice. I didn't realize that whole section was screen. Thanks _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
