Lobro vs Meyle CV Joints
Page: 1, 2, 3, 4  Next
Syncro Jael
Syncro Jael is offline
PostPosted: Sat Jan 04, 2014 9:26 am    Post subject: Lobro vs Meyle CV Joints Reply with quote
I ordered Lobro replacement joints for my Syncro.
When they came the boxes were Meyle and had Germany on them, but also had a small stamp on the boxes (Made in China).
Interesting all the bags inside had Germany stamped on them.
As you can see the Meyle product is manufactured quite differently.
There is no ring on the outside of the joint.
The rubber boots were not straight and the rubber was really thick.
The machining was not clean, a lot of knicks and marks everywhere.
Lobro joints were tighter, cleaner and the rubber was what I am used to seeing.
Worth the drive? Worth another $100?
Or is it worth redoing this project sooner.
Side by side box comparison of these joints.
Lobro Joint
Meyle Joint
insyncro
Banned
insyncro is offline
PostPosted: Sat Jan 04, 2014 9:30 am    Post subject: Reply with quote
If I ordered and paid for Lobro, I would want Lobro delivered.
Thats me.
?Waldo?
?Waldo? is offline
PostPosted: Sat Jan 04, 2014 9:35 am    Post subject: Reply with quote
Meyle brand parts have dramatically declined in quality in the last decade. I haven't yet seen or heard of the same decline in quality with Lobro. If I ordered Lobro there's no chance I'd accept Meyle (or EMPI...) in it's place.
insyncro
Banned
insyncro is offline
PostPosted: Sat Jan 04, 2014 9:37 am    Post subject: Reply with quote
EMPI Shocked
For the love of God....NO Laughing
lloydy
lloydy is offline
PostPosted: Sat Jan 04, 2014 9:43 am    Post subject: Reply with quote
This one of the joys of owning a 16", can still get genuine joints £100 exchange from a main dealer
16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.”
insyncro
Banned
insyncro is offline
PostPosted: Sat Jan 04, 2014 9:57 am    Post subject: Reply with quote
944 and 930 joints for my vans.
Christopher Schimke
PostPosted: Sat Jan 04, 2014 10:10 am    Post subject: Reply with quote
When it comes to Meyle, just say "No bro!" Seriously, the Meyle's are turds compared the Lobros.
luVWagn
luVWagn is offline
PostPosted: Sat Jan 04, 2014 1:37 pm    Post subject: Reply with quote
One problem I have (being mechanically declined) when trying to dig up 944 CVs is clarity on whether they're the right spline count. tdwesty mentioned in a PM to just skip the Turbo related CVs, but then i'll find an ad like this:
http://www.ebay.com/itm/Porsche-924-944-Axle-Shaft...mp;vxp=mtr
This thing says brand new Loebro (same as Lobro I assume, or a knock-off?), but lists fitment for both NA and Turbo 944s Question
'91 Double Door Transporter
Christopher Schimke
PostPosted: Sat Jan 04, 2014 2:01 pm    Post subject: Reply with quote
Both the Vanagon and the 944 have 33 spline axles and will interchange.
The n/a 944 and the Turbo 944 used the same CV joints.
I would not purchase CVs from an ebay vendor unless you FULLY trust them. I don't know if "Leobro" is a misspelling or counterfeit.
In addition, do not purchase the complete Lobro 944 axle kit. I learned the hard way that the CV joints that are included in the Lobro axle kit are not the same as the CV joints that you can individually. The CVs that come with the axle kit are just like the stock Vanagon CVs.
luVWagn
luVWagn is offline
PostPosted: Sat Jan 04, 2014 2:09 pm    Post subject: Reply with quote
This is where it gets murky, as some 944 CVs seem to be of 25-spline variety? http://www.paragon-products.com/CV-Joint-Kit-p/pp951.332.901.00.htm
Thanks for the tip on buying the axles and CVs separately.
If anyone (yourself, insyncro, tdwesty, etc.) have a line on reputable 944 Lobro CV joints, and 944 33 spline axles, that would be most excellent information.
What I'd like to do is replace both my rear axles and CVs on a 2WD manual-transmission Westy, due to ride height and increased angle - while maintaining my current ones as spares in the van (well greased and packed).
Cheers,
Brian.
bluebus86
Banned
bluebus86 is offline
PostPosted: Sat Jan 04, 2014 2:28 pm    Post subject: Reply with quote
I have never be happy with the pre-built CV half axles, Chinese crap is what I find, poor surface finishes, pitted raceways, extremely loose fit, unknown grease type(s) (yes they used two different colored grease, one joint had a mix of both black and white grease, others where either all black or all white grease)
Had this happen with Vanagon joints and 914 joints. Now I am smarter for it, and only use Lobro individual CV joints as replacement, with Swepco CV grease. All Lobros I have seen have nice finish, good clearances, no loose joints.
also beware some half axle kits don't use real VW axle shafts, I have seen some that use a different axle that will not accept stock CV joints, (different splines) that would be a royal pain if you later need to replace the CV on that aftermarket half shaft and cant figure what CV will fit!
Return what you bought, it ain't what you ordered, make sure the seller pays freight both ways. Then order a real Lobro joint and build up your original axles
Unless you do off roading, drive with torn CV boots or such there should not be any need to carry a spare CV, I replaced my original CVs after 178K miles, even thought they still had life left in them. just do periodic maintance, inspect for torn boots and tightness and repack them every now and then. Real Lobro's are highly reliable
Christopher Schimke
PostPosted: Sat Jan 04, 2014 2:31 pm    Post subject: Reply with quote
Sorry, my explanation wasn't very clear. While I am not a Porsche expert, it appears that all 944s (and 924s) up to 1986 use 33 spline axles. 1987 shows a mix of 25 spline and 33 spline and 1988 - up show 25 spline only.
I'm probably not the cheapest source, but if you want to send me an email (not PM), I can definitely supply these CVs to you.
insyncro
Banned
insyncro is offline
PostPosted: Sat Jan 04, 2014 2:32 pm    Post subject: Reply with quote
also beware some half axle kits don't use real VW axle shafts, I have seen some that use a different axle that will not accept stock CV joints, (different splines) that would be a royal paint if you later need to replace the CV on that aftermarket half shaft and cant figure what CV will fit!
Return what you bought, it ain't what you ordered, make sure the seller pays freight both ways. Then order a real Lobro joint and build up you original axles
Building your own halfshafts is the way to go Wink
tarandusVDub
tarandusVDub is offline
PostPosted: Sat Jan 04, 2014 3:37 pm    Post subject: Reply with quote
Do you folks who have worked with CVs a lot have an opinion on this option offered by GoWesty?
http://www.gowesty.com/ec_view_details.php?id=4484&category_id=&category_parent_id=
It seems to address the issues brought up here, but its the "mostly German" caveat that has me concerned...what parts are, and what parts aren't, German? I will ask them directly, but am interested in feedback from the group as to whether these are quality, or are to be avoided like the Meyles and EMPIs...
Also, what is the benefit to enlarging the races...?
1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD.
bluebus86
Banned
PostPosted: Sat Jan 04, 2014 3:47 pm    Post subject: Reply with quote
for the money I'd stick with new Lobros if at all possible, rebuilding your own half shafts. the Gowesty product is interesting, they regrind the old CV's and install bigger balls. I do hope they make sure the reground surface is hardened ok. them discolor marks on the CV are (bluish/brownish color) is from the flame heat treatment done . This is a surface treatment, that may be removed if too much is ground away.
for the money, (shipping of your core, and then reshipping the repaired stuff) I still would be better off with new Lobros I think.
http://www.van-cafe.com/home/van/page_632_791/cv-joint-fits-all-rear-and-syncro-inner.html
van café has Lobros for $60 each no core charge, one way shipping.
tarandusVDub
PostPosted: Sat Jan 04, 2014 3:56 pm    Post subject: Reply with quote
Thanks bluebus ~ I started down the Van Café Lobro route, then found the re-built German (mostly) axle and decided to try that approach first to see how they work. I'll hang on to the Lobro just in case though...
So what is the advantage of bigger balls? (you tee'd that one up nicely).
Brickwerks
Brickwerks is offline
PostPosted: Sat Jan 04, 2014 4:15 pm    Post subject: Reply with quote
"Meyle Germany" just means the company is German, it doesn't mean "Made In Germany"
Meyle don't make anything [to my knowledge], they are a Re-boxer who simple buy parts and put them in their own box.
They source worldwide, China, India, Turkey etc.
Some of it is really good, some of it isn't but the same can be said of a lot of similar companies, Febi, Topran [Hans Pries], Vemo/Vaico
The knack is to know what's good and what isn't and the only way to do that is to buy it and try it and report back.
Febi stuff is generally good, it's the better, more reliable end.
The amount of Meyle stuff we sell has dwindled, there's quality reasons and some political reasons too but we don't sell as much as we used to.
whynotvw wrote:
I see you wanna start some shit. whats your fuckin probelm? your selling your measly shitty products. bloody brit
View user's profile Send private message Visit poster's website Facebook Twitter Classifieds Feedback
Syncro Jael
PostPosted: Mon Jan 06, 2014 2:58 pm    Post subject: Reply with quote
These Lobro's are different than the ones I took off.
Notice the recessed inside to the outer ring.
This goes towards the flange.
bluebus86
Banned
PostPosted: Mon Jan 06, 2014 5:59 pm    Post subject: Reply with quote
some CV 's have a step, this step is to have the paper gasket applied over the step, on CV with no step, do NOT use the paper gasket. If no gasket, then I do like to add a very thin bead of sealant to the flat flange for sealing, but only a small amount, don't goop it on. I do like to use sealant on one side of the paper gasket if I have a stepped CV joint that requires the paper gasket
Syncro Jael
PostPosted: Mon Jan 06, 2014 6:06 pm    Post subject: Reply with quote
That is interesting that the Meyle joints came with that paper gasket and the Lobro joints did not.
What is the "step" supposed to accomplish?
I figured it was more area to hold cv grease.
Well mine got installed without a gasket.
I guess time will tell.
Page 1 of 4
