after F.I. 2.0 1977 engine remove/instal wont run
walterdartt
walterdartt is offline
PostPosted: Mon Aug 11, 2014 2:39 pm    Post subject: after F.I. 2.0 1977 engine remove/instal wont run Reply with quote
spark to plugs, gas to combustion chamber. i unplugged the cylinder head sensor and ran ruff, so i tuned up best i could with engine not running. then nothing untill i plugged sensor back in and then it will only run if i give it just the right amount of gas, and dies under a load or gas flow changes. after a few tries it wont even fire. unless i unplug (or plug in) the sensor then it will try to start one to three time, then it wont. I dont know much about F.I. system any advice would be much help. Thank you for your time Walter Dartt.
P.S. the sensor was not plugged in befor i removed engine and it ran just fine. I think
kkjellquist
kkjellquist is offline
PostPosted: Mon Aug 11, 2014 3:08 pm    Post subject: Reply with quote
Is it timed properly? 7.5ish BTDC
1977 Sage Green Deluxe Campmobile - "Turtel"
(1978 2L FI, Pertronix, Hydraulic Lifters)
Turtel - http://www.thesamba.com/vw/forum/viewtopic.php?t=561195
Pisgah Bus Rally - New Year's Day
http://pisgahbusrally.blogspot.com/
SGKent Premium Member
SGKent is offline
PostPosted: Mon Aug 11, 2014 3:12 pm    Post subject: Reply with quote
the PO probably tweaked things to make it run rather than fix it right. I don't think there is going to be a quick fix here. We can collectively get you thru it. How good a mechanic are you in general?
These are good places to start reading. Homework is required if you want to get thru it.
http://www.thesamba.com/vw/archives/manuals/afc_fi...Manual.pdf
http://www.thesamba.com/vw/forum/viewtopic.php?t=482560&highlight=fuel+injection
walterdartt
PostPosted: Mon Aug 11, 2014 4:25 pm    Post subject: im self tought but im capable not much electical expereance Reply with quote
its timed i did it buy moveing the engine by hand and useing a time light with ignition on.
Wildthings
Wildthings is offline
PostPosted: Mon Aug 11, 2014 6:29 pm    Post subject: Reply with quote
Sounds like you are either too rich or too lean or maybe both, lean while starting and too rich once it hits a few times.. A vacuum leak would cause a lean problem while being too rich could be caused by a faulty TSII sensor or wiring for the same. Do you have all FI your grounds hooked up? Does the fuel pump run when you open the door in the AFM while the ignition is on?
walterdartt
PostPosted: Tue Aug 12, 2014 11:59 am    Post subject: Reply with quote
all ground connected. just starts right up sounds awsome untill i drop the key into running position. the dies promply. im looking at how to start testing some of the FI components. also i replaced 2 of the sensor plugs that were broken posible i got the wires switche up does any one know if that would cause this and how to test that?
walterdartt
PostPosted: Tue Aug 12, 2014 12:07 pm    Post subject: Reply with quote
I also replaced the ts2 sensor
walterdartt
PostPosted: Tue Aug 12, 2014 12:26 pm    Post subject: Reply with quote
fuel pump seems to fun when i open afm door i hear a click and a constant noise when held open
Manfreds78bay
Manfreds78bay is offline
PostPosted: Tue Aug 12, 2014 12:28 pm    Post subject: Reply with quote
So it keeps running when you hold it in the start position and stops when the key is in the run position at the ignition switch?
Sounds like an electrical problem.
1. Try to remote start it from the starter if you have one. If it does start you might have an ignition switch issue.
2. Make sure the double relay is correctly plugged in to the FI wiring harness
3. Inspect the FI wiring harness for bad wires that might be grounding. Is the FI wire plugged into the ignition coil? You should have one white wire (they are actually all white) that plugs into the coil. I can't remember if it's the positive or negative side. Check bentley.
4. Make sure all your vacuum hoses are property connected. http://ratwell.com/technical/VacuumHoses.html
1985 VANAGON GL Digijet
There is no spoon.
Randy in Maine
Randy in Maine is offline
PostPosted: Tue Aug 12, 2014 12:31 pm    Post subject: Reply with quote
Here is how you troubleshoot the double relay...
http://www.itinerant-air-cooled.com/viewtopic.php?f=50&t=5459
SGKent is offline
PostPosted: Tue Aug 12, 2014 12:48 pm    Post subject: Reply with quote
as indicated by the above Samba members - the ignition switch may be bad or you have an AFM / double relay issue. Here is why.
When the key is turned to start, the fuel pump gets its power from the starter circuit. When you turn the key to run, the fuel pump gets its power from the fuel injection system. There are points in the AFM that make contact when the door is opened. The electricity goes out through the plug in the back of the AFM to the double relay, which turns the fuel pump on. So, the problem can be the ignition switch (common failure), the points in the AFM (common failure), the plug left off or coming off the AFM (common failure), or the double relay (common failure).
walterdartt
PostPosted: Tue Aug 12, 2014 1:03 pm    Post subject: Reply with quote
it will run if i give it gas.
Manfreds78bay
PostPosted: Tue Aug 12, 2014 1:21 pm    Post subject: Reply with quote
Does it run rough when you give it gas? Does it continue running once warmed up?
Could be a vacuum leak that has developed.
Make sure the throttle cable is hooked up properly.
Have you tried increasing the idle speed?
There is no spoon.
SGKent is offline
PostPosted: Tue Aug 12, 2014 1:40 pm    Post subject: Reply with quote
I would check the fuel pressure and see what it says. You may be gravity feeding in the run position and need more throttle to keep it going.
walterdartt
PostPosted: Wed Aug 13, 2014 4:08 pm    Post subject: Reply with quote
Can any one tell me where the fuel pressure adjust nut is?
busdaddy
busdaddy is offline
PostPosted: Wed Aug 13, 2014 4:50 pm    Post subject: Reply with quote
The what?, best you read those manuals SGKent linked Wink
Слава Україні!
Wildthings
Tain't one, if you fuel pressure isn't correct you most likely need a new fuel pressure regulator.
walterdartt
PostPosted: Wed Aug 13, 2014 5:11 pm    Post subject: Reply with quote
Ive been reading and wrenching for weeks this is my familys only vehicle if someone could help derect me to where i adjust the fuel pressure you would releive alot of stess for a oerson in need. ive been trying to figure it out.
walterdartt
PostPosted: Wed Aug 13, 2014 5:12 pm    Post subject: Reply with quote
OK thank you thats what i thought.
walterdartt
PostPosted: Wed Aug 13, 2014 5:15 pm    Post subject: Reply with quote
pressure is good and im at a wall i dont know what to test next.
P.S. Thank you all kindly for your time and input it has been much apreciated.
