Rebuilt transmission won't shift (at all) - 1969 VW bug
corbin_dunn
corbin_dunn is offline
PostPosted: Tue Oct 21, 2014 7:36 pm    Post subject: Rebuilt transmission won't shift (at all) - 1969 VW bug Reply with quote
Hi,
I have a 1969 bug and I just got a rebuilt transmission from MOFOCO.
Short: shifter won't work or move at all.
I tried to "manually" shift it by using some vice grips on the shaft under the seat. It rocks/rotates slightly side to side, and seems to be in a gear, but won't come forward or backwards no matter how hard I try. In my old tranny I can fairly easily shift it by hand.
I searched the forums; it sounds like this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=573290&start=0
I just don't want to have pull the thing out and check the nosecone unless I have no other options.
How could it have gotten into this situation anyways?
Any ideas on what I can do?
Of course..I'm going to call MOFOCO tomorrow morning...
Thanks!
corbin
andrewvwclassic
andrewvwclassic is offline
PostPosted: Tue Oct 21, 2014 8:35 pm    Post subject: Reply with quote
short answer is take a look down a gun barrel and liken it to your shift rod assembly, there is simply nothing inbetween the nose cone that will cause trouble. the only thing you can do is pull the motor and check the clutch and tranny. if mofoco did the work which I assume they did not because you are just know aware of a problem you would have realized when leaving their shop, let them service it. best advice I can give is chech the shift forks before you install a new one next time and make sure they are fluint in both directions. Good luck
olspeed
Location: In the shadow of Denali, I still don't give a damn how they do it outside
olspeed is offline
PostPosted: Tue Oct 21, 2014 9:15 pm    Post subject: Reply with quote
Most rebuilt transmissions don't come with a nose cone installed so I am wondering if you installed the one on your transmission but either way you should have checked to make sure that it shifted through the gears before it was installed... Right now the only thing you can do is pull it and remove the nose cone to see what you have.
66- Ghia
76-Beetle
Mr.Duncan
Mr.Duncan is offline
PostPosted: Wed Oct 22, 2014 6:16 am    Post subject: Reply with quote
My rebuilt one from The Wright Gearbox had the same issue.
The "dentent springs" that control/hold the actual shift forks were way to strong. I was told it was because of all the new bushings.
Installed in the car I couldn't shift AT ALL.
Factory manual says the force to pull (at the nose cone) for shifting gears is 35-45 lbs.
Mine was 85lbs
Ended up pulling the transaxle, bolting it to the engine on the floor, and then pulling hard till I could get it in 1st gear. Then let the engine run for 15 minutes between 1000-2000 rpm.
Shut it off, and did the same for the other 3 gears.
loosened up my transmission so I could shift, installed it in the car and it works fine now.
Still a pain in my ass.
If you do take the nose cone off, make sure everything is lined up, and the hockey stick is between the shift forks. like in the below photo.
If they sealed it with silicone, clean it off and put a new bead.
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
[email protected]
roy@mofoco.com is offline
PostPosted: Wed Oct 22, 2014 8:32 am    Post subject: Re: Rebuilt transmission won't shift (at all) - 1969 VW bug Reply with quote
corbin_dunn wrote:
Hi,
Thanks!
corbin
Yeah, I am considering sending transmissions without the nosecone and hockeystick installed. All of a sudden, I am having tons of problems and I can't figure it out. I test drive the transmissions in a vehicle and everything is great. We take them out and replace all the hardware with new hardware. Then I have a custom tool that is a T handle that bolts onto the hockeystick. I then manually check to make sure it shifts. I do protect the nosecone in the box when I ship it. I've had 3 people in the last 3 months have this problem where it won't shift. It always ends up that somehow there are two levers pulled out at the same time and it won't allow the hockeystick to rotate between gears.
Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Wed Oct 22, 2014 8:45 am    Post subject: Re: Rebuilt transmission won't shift (at all) - 1969 VW bug Reply with quote
[email protected] wrote:
...It always ends up that somehow there are two levers pulled out at the same time and it won't allow the hockeystick to rotate between gears.
Easy to do if not paying attention close enough. Although it's an easy-to-find problem if you ops check the hockey stick movement after installing the nosecone.. This should not be a problem that is found out after installing the trans in the vehicle.
Robert in Memphis
Engine rebuild thread
[email protected]
PostPosted: Wed Oct 22, 2014 8:50 am    Post subject: Re: Rebuilt transmission won't shift (at all) - 1969 VW bug Reply with quote
scrivyscriv wrote:
[quote="[email protected] ...It always ends up that somehow there are two levers pulled out at the same time and it won't allow the hockeystick to rotate between gears.
Easy to do if not paying attention close enough. Although it's an easy-to-find problem if you ops check the hockey stick movement after installing the nosecone.. This should not be a problem that is found out after installing the trans in the vehicle.[/quote]
Like I said, I can't figure out why it works here and then it doesn't work once it's installed in the customer's vehicle. We are the only place in the country that actually installs the transmissions in a vehicle and test drives them.
www.mofoco.com
Bruce
Bruce is offline
PostPosted: Wed Oct 22, 2014 1:42 pm    Post subject: Reply with quote
This is a BS answer. The detent springs VW made don't magically get stronger.
Most rebuilds from California are made from cores that have 10 million miles on them, so everything is worn out. Standard procedure is to install a bronze bushing in the bores for the forward shift rods. If these bushings are not reamed large enough, it can be difficult to slide the shift rod.
Mr.Duncan
PostPosted: Wed Oct 22, 2014 1:47 pm    Post subject: Reply with quote
I'm stating what the transmission re-builder told me.
10 million miles on a core? Really?
1966 Ghia (sold)
1966 Red Beetle
corbin_dunn
PostPosted: Wed Oct 22, 2014 2:43 pm    Post subject: Re: Rebuilt transmission won't shift (at all) - 1969 VW bug Reply with quote
corbin_dunn wrote:
Hi,
Thanks!
corbin
Thanks Roy! I didn't get a chance to call you guys today (got busy at work).
It sounds like I don't have much of an option: pull the motor/trans and pop off the nose cone and see what is wrong. I'll probably give this a try this weekend.
Anything else you can think of?
Mr Duncan: Those pictures are super helpful! Thank you -- I will take a look at that too.
-corbin
corbin_dunn
PostPosted: Sat Oct 25, 2014 6:22 pm    Post subject: Re: Rebuilt transmission won't shift (at all) - 1969 VW bug Reply with quote
Okay! I pulled the tranny out and took off the nose cone. I didn't quite see how the "hockey stick" was when I took it off. I verified that each gear shifted, pulled them all inline and put put it back together. Seems to be okay now!
I got it back installed and running; did a quick test up my hill and so far so good.
PS: I'm thinking about selling the car if anyone is interested. ~100 miles per charge. > 100 HP.
corbin
