Paulbeard Samba Member
Posted: Tue Apr 30, 2019 5:00 pm Post subject: penetrating oil bake-off…for amusement purposes… |
Can water penetrate and release rusty fasteners?
Amazing what some people believe but it does explain the enduring popularity of MythBusters…
This is part of a series so maybe there is time to get ATF/Acetone or PBlaster in the mix. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10223 Location: Mt Lemmon, AZ
Posted: Tue Apr 30, 2019 5:30 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
It is hard to compare using real world cases - I'll stick with PBlaster based on what I have experienced but I (unlike this test) allow many days or even weeks for it to work and also use some tapping on the part to encourage penetration.
Never been convinced the ATF/Acetone was for real - the magazine article is often cited but may or may not have really happened. |
Merian Samba Member
Posted: Tue Apr 30, 2019 8:40 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
Answer: Yes. In fact, water can cut thru the metal the fasteners are made of too.
See Also: water jet _________________ .... |
Posted: Tue Apr 30, 2019 8:46 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
Merian wrote: |
See Also: water jet |
/sigh
Still water in a bowl is not a water jet. It's not the water anyway, it's the abrasives carried by the water. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Tue Apr 30, 2019 8:48 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10639 Location: Western WA
Posted: Tue Apr 30, 2019 8:50 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
Ahwahnee wrote: |
Same here.
I’ve never seen corroboration.
But that doesn’t mean much.
I’m thinkin’ its a new “old husbands tale”
But its popular enough I think folks would buy it if it came in a spray can with a hose. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Tue Apr 30, 2019 8:54 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
This kind of bake-off might be the perfect place to test it. Why not send it in as a suggestion? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Sodo Samba Member
Posted: Tue Apr 30, 2019 9:06 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
Just watched the bake-off.
Well done.
PB blaster and Liquid wrench work well, but Ive never done a comparison.
When I know a bolts gonna be real ornery I apply penetrating oil over a few days and have often been surprised when they unscrew. _________________
Butcher Samba Member
Joined: December 05, 2015 Posts: 1282 Location: Right Here
Posted: Wed May 01, 2019 7:46 am Post subject: Re: penetrating oil bake-off…for amusement purposes… |
This is the only tool you need. Well you need the money to buy the tool but hands down, this is the only sure fire way of getting bolts loose. I've never seen fluid seep into a rusted part. It seems that it must break free before the oil seeps in. Fortunately I do not live in a rust prone area.
E1 Samba Member
Joined: January 21, 2013 Posts: 8259 Location: Westfalia, Earth
Posted: Wed May 01, 2019 7:56 am Post subject: Re: penetrating oil bake-off…for amusement purposes… |
That thing's pretty cool.
How do you mitigate overheating the part, say on a CV? Put on, check, more heat, check? _________________ 1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
Subtracting weight makes you faster everywhere." — Colin Chapman |
Sodo Samba Member
Posted: Wed May 01, 2019 8:08 am Post subject: Re: penetrating oil bake-off…for amusement purposes… |
Butcher wrote: |
this is the only sure fire way of getting bolts loose. I've never seen fluid seep into a rusted part. It seems that it must break free before the oil seeps in. Fortunately I do not live in a rust prone area. |
Cool tool! (Electrical Induction energy heats only the bolt).
There are conditions where seating of the bolt head forms a perfect seal around the washer ring. As such penetrating oil "may not" pass by to get to the bolt threads. But I’ve been surprised by bolts that won’t turn at all, with imminent danger of rounding off the (corroded/smaller) hex, then after a few days (sometimes just “hours”) they turn “easily” using just penetrating oil. Especially if theres a washer, (or threads) ir any possible passageway.
Butcher you don’t seem to have been born yesterday.
Your post is mostly a joke, right? Or do you mean a Pro mechanic, with a car plugging up a bay, doesn’t have even minutes, much less hours (or days) for penetrating oil to work (like the DIYer can). But agreed it is a cool tool (high heat with no flame). _________________
jlrftype7 Samba Member
Posted: Wed May 01, 2019 5:26 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
I use WD-40.... I don’t like the smell of Liquid Wrench and Really don’t like the smell of PB Blaster.
It’s worse for the burning off of these sprays once you have to resort to getting out the Oxy-Acy torch if the oil failed.
Never tried the wax as D suggested, and Acetone is another smelly chemical I try to avoid.
Here in the Rust Belt, or at least the edge of it..( ), I have wire brushes to shed rust, my Snap-On Crud Thud to also clean parts before applying Penetrating Oil, a HF needle scaler to clean and shock a joint or bolt, or my Air Hammer if needed.
I’ve seen the Inductive Tools demonstrated, they’re neat but out of my price range. And I can’t talk a manager into buying them as a shop tool.
Some days the rust battle goes my way, and some days it doesn’t....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Sodo Samba Member
Posted: Wed May 01, 2019 5:44 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
I have found PB Blaster and Liquid Wrench to outperform WD40 bigtime in getting rusty bolts loose.
At least is SEEMS like "bigtime"..... Every bolt is different. _________________
dobryan Samba Member
Joined: March 24, 2006 Posts: 17147 Location: Brookeville, MD
cmayna Samba Member
Joined: August 18, 2014 Posts: 1173 Location: SF Bay area, CA
Posted: Fri May 03, 2019 8:05 am Post subject: Re: penetrating oil bake-off…for amusement purposes… |
My favorite which is no longer produced is Pentron. Once I run out of it I will probably go back to my backup of AFT and Acetone.
Here's a link to a similar post on another forum:
https://www.cumminsforum.com/forum/98-5-02-non-powertrain/580189-penetrating-oil.html _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
stuzbot Samba Member
Joined: March 30, 2018 Posts: 377 Location: Pining for the Puddles of Yesterday
Posted: Fri May 03, 2019 9:00 am Post subject: Re: penetrating oil bake-off…for amusement purposes… |
Over this side of the pond, I've never found WD40 to be that good. I"ve always had better luck with Plusgas
[And thanks @Butcher for introducing me to another ridiculously expensive tool I'd never heard of before but which I'll now add to the "When I win the lottery...." list] _________________ *****************************
Click to view image
1992 VW LT35 2,4D [SOLD]
1993 VW LT35 2,4D [SOLD]
1992 VW T3 1,6TD Syncro [SOLD]
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6930 Location: Fort Lauderdale, Fl.
Posted: Sat May 04, 2019 4:28 am Post subject: Re: penetrating oil bake-off…for amusement purposes… |
For the test I'm wondering if a bolt and nut for each brand tightened and over-torqued to same torque using a torque wrench to the point of just before they strip and letting it sit a few hours to take a set into each other(bolt & nut).
Then using a torque wrench with the swinging needle on a scale to see what the breaking torque is on one without any penetrating oil and record the breaking torque of that nut.
Then apply each brand to a nut and let it sit/soak in and record the breaking torque of each brand compared to the nut without the penetrating oil.
It would be nice if you had a year to wait and put the nuts & bolts in a salty environment.
Grand Ma allows said a large hammer and a larger vocabulary would fix anything. _________________ This free advice is worth exactly what you paid for it.
Posted: Sat May 04, 2019 5:14 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
No joking. I just have not seen penetrating oil work to break free a fastener. This is just my experience and is not saying it does not work for others.
Once it's broken free, YES, the stuff can get into the threads and YES, the fastener does come out easier. I just do not see that it can penetrate when everything is frozen up. Maybe it's I'm just impatient. In my younger years, time was money.
With the years under my belt, I know when there is a problem. I do not mess around. I try first to make certain it's frozen. Then I apply heat. It used to be a torch, now it's induction. Once the fastener is broken free, I like to use Wurth HHS2000.
If you spray oil on the seized bolt and it does not work, then heat causes the oil to catch fire. Another waste of time. I go for the jugular.
As for the induction trick, I thought is was snake oil until my friend purchased one at his shop and I was able to use it. I'm sold. I purchased one and trust me, I'm cheap. It was that good. |
Posted: Sat May 04, 2019 5:21 pm Post subject: Re: penetrating oil bake-off…for amusement purposes… |
Butcher wrote: |
Once it's broken free, YES, the stuff can get into the threads and YES, the fastener does come out easier. I just do not see that it can penetrate when everything is frozen up. |
That's pretty much my experience as well. I blast the fastener with the lubricant to reduce the friction once the initial rust bond is broken, but I don't expect it to be much help prior to the break. _________________ Casey--
y u rune klassik? |
Merian Samba Member
Heat Good
the key to using a penetrant is to be patient - patient over several days or more & you also should go tap on thing every few hours - it WILL penetrate* and help loosen the fastener
whenever I buy an old vehicle, I get under there and spray all the fasteners, it may sit there for year before I try to break it free... but in 50 years I have only snapped off one small stud and have used heat only a couple of times, and maybe not needed then
* "capillary action" _________________ .... |
