vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5874 Location: Wamego, Kansas, USA
Posted: Tue Aug 06, 2019 8:33 am Post subject: Squeaky Rear Heater Bearing |
Hello all-
I'm using a rear heater in my '78 Bus TDI Conversion.
At low or medium speeds, there is a squeaking noise that is pretty annoying, that goes away when turned to high.
I think it is a bearing. Is there a way to lube it or replace it? Recommendations on doing such?
All my searching just turns up threads for deleting rear heaters. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24456 Location: NYC/Upstate/ROW
Posted: Tue Aug 06, 2019 8:51 am Post subject: Re: Squeaky Rear Heater Bearing |
You probably want a spray Lithium grease on a stick and hit the motor bearing, not too much. I don't know what you do with the other $10 of grease in the can left over _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
jlrftype7 Samba Member
Posted: Tue Aug 06, 2019 9:06 am Post subject: Re: Squeaky Rear Heater Bearing |
If the bearing will accept oil, I use the Plastic Bottles with the Telescoping Spout on them that have Thin Turbine type oil. hardware stores still carry them if the store gets any trade from HVAC or other type people since the thin spout/end gets into tight spaces without as much disassembly on a blower or motor that can use oil on its bronze or other similar bearing.
I'll try and post a picture of the oiler....One like this. I've used them on my Ceiling Mounted A/C blower motor, and my rear heater blower. As well as Household fans since again the thin nozzle gets around shrouds or other obstructions
https://www.amazon.com/ZOOM-SPOUT-OILER-MACHINE-U-...&psc=1 _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
β84 Tin Top - Hilga....Auto |
jkidd152 Samba Member
Joined: June 09, 2009 Posts: 408 Location: Portland, OR
Posted: Sun Dec 01, 2019 12:57 pm Post subject: Re: Squeaky Rear Heater Bearing |
Can someone direct me to where exactly to lubricate this thing? Runs fine but it squeals at all speeds.
Thanks! _________________ '85 Syncro Westy  |
Posted: Sun Dec 01, 2019 2:21 pm Post subject: Re: Squeaky Rear Heater Bearing |
| jkidd152 wrote: |
Thanks! |
. The outer bearing is right there on the end, easy to lube.
The inner one is hiding behind the squirrel cage, but is doable with the thin spout tube oiler as Iβve previously posted.
Turbine type oil is what you want, not a spray grease.
Zoom Oiler or other, even 3 in 1 oil will work.
Work some oil into the bearings, spin the cage to move it around.
Donβt over oil the inner bearing, it will throw oil around from the airflow of the cage and you might smell it for a bit once the motor is running as youβre using it. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sun Dec 01, 2019 8:14 pm Post subject: Re: Squeaky Rear Heater Bearing |
Thanks! I hit the outer bearing and also directed some lube through the fan behind the visible surface. Looking very carefully, you can see a shaft in there. Itβs quiet now! Success!
Unrelated: What are the letters for on the fan? _________________ '85 Syncro Westy  |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 944 Location: Calgary, Canada
Posted: Mon Dec 02, 2019 10:00 am Post subject: Re: Squeaky Rear Heater Bearing |
Do you mean the letters cast into the plastic of the squirrel cage? I see "B" and "C" in your lower photo.
I understand they are used by the factory to balance the fan after assembly. Like a tire balancer - spin the fan; check for imbalance which will be show up at a particular letter; attach a little metal clip (like a tire weight). _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Mon Dec 02, 2019 10:03 am Post subject: Re: Squeaky Rear Heater Bearing |
| spitsnrovers wrote: |
I understand they are used by the factory to balance the fan after assembly. Like a tire balancer - spin the fan; check for imbalance which will be show up at a particular letter; attach a little metal clip (like a tire weight). |
Seems like a reasonable answer.... I always wondered about those Letters too....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Dec 02, 2019 1:56 pm Post subject: Re: Squeaky Rear Heater Bearing |
The letter appear to be stationery when hit with a strobe light.This allowed a worker to properly place any necessary weight(s). All this was before full automation. _________________ Schau in das Buch |
Posted: Sun Feb 16, 2020 9:14 am Post subject: Re: Squeaky Rear Heater Bearing |
A few weeks ago, before a trip to Colorado, I dropped the heater and attempted, again, to quiet the squeak. I know I used some silicone lube and I think another lube to try to get in there and quiet it down.
I also noticed that if I tweaked the meal housing a little, it seemed to help, so I gave that a shot.
It was quiet running sitting on the ground, so I put it all back together.
Well, the squeakiness quickly returned on that trip!
I am going back this coming weekend, so I'd love any other ideas on how to quiet this thing that any of you might have.
Also, now the squeak is present on high speed, too! _________________ Dave Cook
1973 Wild Westerner
My Thing |
jimf909 Samba Member
Posted: Sun Feb 16, 2020 10:19 am Post subject: Re: Squeaky Rear Heater Bearing |
Lots of good info in these threads (along with some annoying rants from Terry Kay) but if you listen to TK it just may be time to replace the fan if you can't get it to be quiet with some lube. Some lube in the right place has quieted many of these fans.
Lubricating a heater fan...
The Mullendore (as in Karl) port thread...
https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
Posted: Mon Feb 17, 2020 8:22 am Post subject: Re: Squeaky Rear Heater Bearing |
Ugh. Well yesterday I dropped it again and added some 3 in 1 oil. With the heater still sitting on the ground and running on low, it was nice and quiet.
But I left it running as I mounted the splash pan back up, and the ding-dang thing was starting to squeak, though (so far) quieter than before.
I'm not optimistic that it'll stay quiet for any length of time, but I guess we'll see. May start looking for a good used rear heater unit. (Squeak free!) _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Feb 17, 2020 8:33 am Post subject: Re: Squeaky Rear Heater Bearing |
| vwwestyman wrote: |
I'm not optimistic that it'll stay quiet for any length of time, but I guess we'll see. May start looking for a good used rear heater unit. (Squeak free!) |
Are you sure the blower cage isn't rubbing on the shroud some where once you start reassembling it?. If it's quiet with no sheetmetal around it, then it should stay quiet once installed.
Again no silicone oil/spray, you want thin Turbine type oil, also known as machine oil. A Zoom plastic oil bottle with its long nozzle will last you almost a lifetime of oiling bearings, and the oil in the bottles is the right stuff for the job. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Feb 17, 2020 8:43 am Post subject: Re: Squeaky Rear Heater Bearing |
Can you please recommend a specific oil? I googled turbine oil and machine oil and got lots of variety in results.
I used 3 in 1 yesterday because I thought I'd seen that recommended in one of the linked threads.
Is Tri-Flow a good bet? I saw that mentioned in one of the recent heater bearing lube threads.
You may be right, perhaps it was actually a different squeak I was hearing on installation. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Feb 17, 2020 11:52 am Post subject: Re: Squeaky Rear Heater Bearing |
| vwwestyman wrote: |
You may be right, perhaps it was actually a different squeak I was hearing on installation. |
3 in 1 isn't that bad, I think its base oil stock is different than Turbine/Machine oil if I remember right. You should be fine with the 3in1. Many hardware stores, and Amazon, will carry the Zoom brand or similar oilers. I posted here on Samba, maybe on another thread and posted a link. I can do that again if needed, but the 3 in 1 probably is all you need. I googled it it's supposedly SAE 20 special blend of oils.
So it sounds like it's still the same stuff we grew up with. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Feb 17, 2020 12:01 pm Post subject: Re: Squeaky Rear Heater Bearing |
| jlrftype7 wrote: |
| vwwestyman wrote: |
So it sounds like it's still the same stuff we grew up with. |
I see that the zoom turbine oil is supposed to be sold at ACE Hardware, so I could pick some of that up this evening I suppose.
OR would TriFlow be a better oil to pick up? Also available at ACE.
I'm going on a trip this next weekend hence the motivation to have a quiet heater!
If that doesn't work, perhaps I can just deal with it the rest of this winter and then take it apart and attempt to install a new bushing when the weather warms up and I can go without the heater for a while. Something like mentioned at the end of the page here:
https://audiokarma.org/forums/index.php?threads/wh...gs.790244/ _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Mon Feb 17, 2020 2:44 pm Post subject: Re: Squeaky Rear Heater Bearing |
| vwwestyman wrote: |
| jlrftype7 wrote: |
| vwwestyman wrote: |
https://audiokarma.org/forums/index.php?threads/wh...gs.790244/ |
You can buy the Zoom oil at Ace if you want, I think, as I noted before, you're fine with the 3 in 1 oil. Your choice, since you have a noise of some type even after oiling- Maybe post a short video of the noise here so we can all listen and take a guess at what's happening.
I have no experience with the Triflow, others here on Samba mention it often though. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
