Herrbern Samba Member
Joined: May 04, 2008 Posts: 351 Location: Luxembourg, Europe
Posted: Thu Sep 12, 2019 11:49 am Post subject: Fuel inlet pipe came out of carb |
Hi,
My brass fuel inlet pipe is not holding in the carb body anymore. I have seen that it is possible to replace it with a threaded fitting.
Which diameter of threaded pipe will fit on a 30 pict carb ?
Thanks,
Bernard |
finster Samba Member
Joined: May 26, 2012 Posts: 10604 Location: not far from the madding crowd
Posted: Thu Sep 12, 2019 12:13 pm Post subject: Re: Fuel inlet pipe came out of carb |
volkzbitz.com does a threaded inlet mod, see lower rh side of this page
https://www.volkzbitz.com/
drop him an email - [email protected] _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36455 Location: Conejo Valley, CA
Posted: Thu Sep 12, 2019 1:10 pm Post subject: Re: Fuel inlet pipe came out of carb |
What I did was a little less work but held well... I rolled the fitting pressed hard between two coarse files, dimpling it. Then I used some form of gas-resistant epoxy and shoved it in. You might want to do your fuel pump fittings while you are at it. And do not add a fuel filter to the hoses there... the weight adds to the force trying to pull it out, unless you support the filter with a clip on the shroud (but better to locate it under the car next to the tranny, and use a metal one with the date/mileage written on it with a Sharpie).
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13960 Location: White Mountains Arizona
Posted: Thu Sep 12, 2019 2:04 pm Post subject: Re: Fuel inlet pipe came out of carb |
As mentioned take that and file a cross hatch pattern on it. As mentioned reinsert with some JB weld. That is what I did. It will work fine. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 365 Location: Green Bay, WI
Posted: Thu Sep 12, 2019 2:10 pm Post subject: Re: Fuel inlet pipe came out of carb |
| Herrbern wrote: |
A 1/4" barb to 1/16" NPT fitting will work. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT
VeeDubability on YouTube |
bluebus86 Banned
Posted: Thu Sep 12, 2019 3:01 pm Post subject: Re: Fuel inlet pipe came out of carb |
See link at end of this post on engine fires and safety wire, several options to fix this, carb needs addressing to for same issue
Bug On! Fire Safe! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
dcheek Samba Member
Posted: Thu Sep 12, 2019 3:28 pm Post subject: Re: Fuel inlet pipe came out of carb |
Had the same problem when the pipe blew out on the carb on the highway doing 60 MPH and sprayed the entire engine with fuel. How it never caught on fire I'll never know.
I called Loctite and told them I needed to "glue" 2 dissimilar metals together that have to withstand heat, vibration and gasoline. They recommend Loctite RC/609. Been on there for 25 years. The bond is so tight you would have to drill it out. This "retaining compound" only works when there is a small clearance between the two parts (not to exceed .005")
Dave _________________ 1961 Bug
1965 Bug
1966 Sunroof Bug
1966 Westy
1976 914 2.0
1989 911 Carrera
1982 Diesel Rabbit Pick Up
1982 Diesel Vanagon
2014 Golf (last year German mfr for NA)
2023 Jetta Gli, Autobahn Black Edition 6 speed |
Posted: Fri Sep 13, 2019 3:33 am Post subject: Re: Fuel inlet pipe came out of carb |
| Thank you very much. |
