Syncro Jael Samba Member
Posted: Wed Jun 17, 2020 9:58 am Post subject: Brake Fluid - Power Bleeder Line Burst - OUCH |
It was a sad moment this week.
Replacing the Brake Fluid in the van using my Power Bleeder. I have used a power bleeder for years and years. Filled it with new DOT4 Brake fluid. Made the connection to the fluid reservoir. Pumped the bleeder to 10psi. Then went down under the right rear of the van and started bleeding brake fluid. I noticed that the flow slowed down to a near stop.
Went back up to see the pressure in the tank.
The line had burst and sprayed the entire front interior of the van and dash with brake fluid. It almost completely emptied the Power Bleeder that was half full. About a quart.
It shot a stream across my Recaro Drivers seat then through the center of the van back across the rear bench. The drivers side of the van took the brunt of the blast.
I hurried and pulled the rubber floor mats and started wiping the dash, seats, VOW center console, and wet vacuumed the rear cushions and carpets. The brake fluid was pooled on the Recaro's. The finish on the leather is not going to ever be the same.
Then I noticed that my dash vents, aftermarket gauges, lower center vent, and everything else "Plastic" was falling apart and cracking. The drivers side air vent fell apart. I started to remove everything and brake fluid was dripping down through the wiring and was everywhere!!! My gauge pod in the ashtray started to crumble as did all the plastic parts on the dash. All of the plastic knobs, covers, vent control cover, bulb holders, everything plastic.
Needless to say, I am posting this so that others will be more aware of this catastrophic event that could happen. Make sure your Power Bleeder hose is new and cover the line with a towel or something to keep it more contained if this should ever occur.
DAMMIT! These plastic parts are very difficult to find and replace.  _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17385 Location: Brookeville, MD
Posted: Wed Jun 17, 2020 10:16 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
| dobryan wrote: |
(I know it is after the fact, but I do not use the Motive tank for brake fluid itself. I just use it to pressurize the master cylinder reservoir and keep an eye on the level and top it up as needed.) |
This is a great afterthought. I too should approached bleeding this way.
It always costs me to learn simple things.
jlrftype7 Samba Member
Posted: Wed Jun 17, 2020 10:23 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
We feel your pain, and wish you a speedy recovery on that now damaged Interior.  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
hardway Samba Member
Joined: January 03, 2012 Posts: 511 Location: Fidalgo Island
Posted: Wed Jun 17, 2020 12:46 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
Brake fluid is water soluble. Copious mounts of flowing water is the best mitigation strategy after a spill. As long as it keeps foaming there is brake fluid still present. Get it out of the fabrics and carpet and insulating pads to save the paint.
That sucks. |
Posted: Wed Jun 17, 2020 12:52 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
I’m trying to take apart the instrument cluster. It’s crumbling before my eyes _________________ 1987 Syncro Westfalia Hightop - NAHT
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10320 Location: Mt Lemmon, AZ
Posted: Wed Jun 17, 2020 1:00 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
So very sorry to hear this - what a nightmare.
It's all replaceable and hopefully among the many on the Samba the plastic bits can be located.
I can appreciate what a stressful time this is for you. |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2748 Location: Philly, mang
Posted: Wed Jun 17, 2020 6:34 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
i feel for you, mine failed at the cap and it emptied the jug into the dash and all over the fuse panel, and down onto the cardboard i had put down.
what a nightmare.
i'm going to be using mine again soon, time to hook it up to the spare mc/tank i have. _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Wed Jun 17, 2020 7:12 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
Shisen.
Feel for you 100%.
I unfortunately through experience learned to wrap an oil absorber around piping connections inside the interior when working on hydraulic systems.
Experience is a hard teacher, it gives the test before the lesson. _________________ This free advice is worth exactly what you paid for it.
jimf909 Samba Member
Posted: Wed Jun 17, 2020 7:29 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
Yikes. I felt like I was reading about a forest fire raging through an 1800s logging town. Here's hoping you're able to repair the losses. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7333 Location: Honolulu,Hawaii and France
Posted: Wed Jun 17, 2020 9:47 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
Damn bro! That blows
That always why was I never used them in the van and made a tire valve adapter to the reservoir cap for pumping slowly. It’s time consuming but our reservoirs are getting brittle too.... _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1745 Location: Budapest Hungary, Europe
Posted: Wed Jun 17, 2020 10:03 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
I was always afraid of pressurizing the tank. The clutch hose looked a weak point but the tank popping out from the master would be the disaster I was afraid of.
So we always used the 2 person pump-hold-bleed method. Recently I bought a cheap chinese compressor attachment which made it easier. Still do it two person as better to watch the fluid level continously, but can be done alone. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
hans j Samba Member
Joined: May 06, 2006 Posts: 2746 Location: Salt Lake City UT
Posted: Wed Jun 17, 2020 11:09 pm Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
Yup it happens, and it really sucks when it does. Happened to me using our other shops bleeder a couple weeks ago, except it sprayed brake fluid all over my diag cart with about 30k in electronics in it. I only really just lost my laptop, but it could have been much worse! I spent about 7 hours cleaning everything up.
Best thing is to replace the hose every couple of years. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Thu Jun 18, 2020 12:39 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
To flush the brake fluid I have never had to do anything more than open one front and one rear bleeder at a time and let gravity do the work. It takes a bit of time to flush the lines this way, but if you do it simultaneously with changing your oil or doing other service work, the time is not wasted.
I would like to find a new "shield" to protect the instrument cluster from brake fluid drips as mine is cracking around where it fits of the fill for the reservoir.
As other suggested brake fluid will dissolve in water, so a hose with a spray nozzle is about the fastest cleanup you can do. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12438 Location: Santa Cruz, CA
Posted: Thu Jun 18, 2020 12:44 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
| dobryan wrote: |
Yup |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Thu Jun 18, 2020 8:09 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
Also, I know this seems self-serving, but that's what we pay all that insurance for. Believe it or not, owner mistakes and the damage are covered. To replace all those bits would be a couple thousand dollars, and it's under comprehensive, not a traffic crash that could increase your rates. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10157 Location: Where?
Posted: Thu Jun 18, 2020 9:49 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
| I've used a power bleeder also and put the fluid into the bleeder. I have had a leak when using the bleeder under the hood of a different vehicle. It made a mess but not nearly as disastrous as what you describe. I appreciate the warning and will consider it when bleeding the brakes on Vanagons. |
tjet Samba Member
Posted: Thu Jun 18, 2020 10:39 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
| Was it a Motive bleeder? |
Westaru Samba Member
Posted: Thu Jun 18, 2020 10:50 am Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH |
| Syncro Jael wrote: |
DAMMIT! These plastic parts are very difficult to find and replace.  |
Ron,
Fellow Utahn here, and I had the EXACT thing happen to me last fall with my Motive power bleeer. I was bleeding the brakes, and I lost pressure at the caliper and heard dripping. Got up to see the cab, and saw brake fluid EVERYWHERE, even dripping from the headliner. I don't think it is overstating to say this was a catastrophic experience.
From my experience, here is what I had to do:
Steam clean the entire interior of the van. I did it once myself but couldn't get rid of the smell of brake fluid. Then paid to have it done professionally.
Removed dash and wiped down everything, wire looms, etc. Used Deoxit on all grounds and connections.
Stereo shorted and went up in flames upon powering it up. Had to replace.
Had a few shorts (brake fluid is conductive) that took forever to short out. I had to completely disassemble the light and other switches around the cluster, clean them with deoxit, and then reassemble to get them sorted.
Plastic - clean as much as possible. Had to get color matched paint for the lower heater cover and the gauge cover as both were stained badly (superior paint in murray did a fantastic job of this, perfectly matched in spray cans).
Finally, I'm STILL looking for a replacement gauge cluster - my gauges were fine, but the lenses and plastic around them is etched and looks awful. I've been looking for 9 months now and still haven't found a replacement.
FWIW, I reached out to Motive, and they gave me a line of 'the instructions to the power bleeder say to replace the line regularly." They offered to replace the bleeder, but I was so pissed that I couldn't even respond to their email. No sorry, nothing other than I should have followed instructions that weren't included with my bleeder. FWIW, my instructions do NOT say anything about this, so they must have recently added it for liability reasons.
Best of luck to you, it is a pretty awful cleanup. There is a good interior detailer in Bluffdale that uses steam to clean and did a great job with my interior. I was out around $500 and a few days of work, and I hope I can find another cluster at some point - I don't even care about pricing at this point if I can just find one. _________________ 1984 Vanagon Westfalia EJ22 |
