ZEKE65 Samba Member
Joined: December 16, 2018 Posts: 356 Location: Right Coast, Florida
Posted: Tue Jan 11, 2022 10:47 am Post subject: Running a road draft tube for breathing |
I have a factory oil fill with the 18 mm tube that runs to the bottom of the engine. In stock form there was a rubber check on the bottom to allow oil to drip out while the vapors went to the air cleaner. I was wanting to use the 18 mm tube for the main engine breather. I plan on running 5/8" hose from the bottom of the tube to a 30 micron stainless mesh filter housing to prevent particles from entering. I am assuming that the only problem may be oil dripping from the end of the filter. Anyone have experience with doing this? _________________ 1965 VW Sedan, 1968 C10 Step BB, 99 C5 |
QRP Samba Member
Joined: April 27, 2008 Posts: 1974 Location: NORTH HOLLYWOOD,CA
Posted: Tue Jan 11, 2022 12:55 pm Post subject: Re: Running a road draft tube for breathing |
| I just stuff a piece of Scotch-Brite up the tube and call it a day. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5576 Location: Lefty, CA
74 Thing Samba Member
Posted: Tue Jan 11, 2022 7:24 pm Post subject: Re: Running a road draft tube for breathing |
| Just put the rubber vent on the tube with the slit. It is made to let condensation out. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8874 Location: Sunset, Louisiana
Posted: Wed Jan 12, 2022 6:00 am Post subject: Re: Running a road draft tube for breathing |
Without the rubber valve you get more moist cool outside air getting sucked into the engine. Installing the valve cuts down on that milky, gunk that builds up in the oil fill and oil cap during cooler weather. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6151 Location: CONGERS, N.Y.
slayer61 Samba Member
Posted: Wed Jan 12, 2022 9:49 am Post subject: Re: Running a road draft tube for breathing |
I have a couple of motorcycles with a K&N filter on the end of the hose. Mounted low underneath the bike and out of view. Case breathes as needed & no schmutz gets in past the filter _________________
| Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
| 67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes?  |
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo (pending)
Tim's stage II turbo heads (pending)
MSD Box and distributor
Car Craft turbo header |
Igpoe Samba Member
Joined: February 24, 2019 Posts: 854 Location: South Boston, VA
Posted: Thu Jan 13, 2022 4:21 am Post subject: Re: Running a road draft tube for breathing |
I'm running two on my 1835. Nothing comes out of them but a tiny bit of air and about a half ounce of light gray-tinted water every hundred miles or so. Nothing goes up and into my motor. The breather is as clean inside as the day it was mounted (2020). We don't have emissions testing where I live. _________________ '73 super. |
