Air Conditioning in Any VW!
[email protected]
jam_phan@yahoo.com is offline
PostPosted: Fri Jul 02, 2004 5:21 am    Post subject: Air Conditioning in Any VW! Reply with quote
This seems like it would be a cool thing to have if you really wanted some AC in your bus for those real long trips or something. Very Happy If it actually works.
http://www.compactappliance.com/xq/JSP.detailmain/...roduct.htm
Stephen
"Reach out your hand if your cup be empty,
If your cup be full may it be again..."
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger Classifieds Feedback
DurocShark
Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
DurocShark is offline
PostPosted: Fri Jul 02, 2004 6:08 am    Post subject: Reply with quote
It's just a fan that sets on top of your ice chest.
That's giving me some ideas... I've got a bunch of 12v case fans just collecting dust... Wink
[email protected]
PostPosted: Fri Jul 02, 2004 6:17 am    Post subject: Reply with quote
Yeah I started thinking the same thing. I have a bunch of case fans that would work just as well probably. I'll make the thing for like 15 bucks!
Stephen
westy78
westy78 is offline
PostPosted: Fri Jul 02, 2004 6:56 am    Post subject: Reply with quote
It might work but.... Unlike a normal AC unit that removes the humidity from the air making things more comfortable this method will actually add moisture into the air. Sure it may be cooler but that "sticky" feeling in the air will go up making it *feel* warmer. Cool idea though.
Jasan C.
'78 Westy
VW Campmobile, it goes on vacation with you.
[email protected]
PostPosted: Fri Jul 02, 2004 7:03 am    Post subject: Reply with quote
What about their suggestion of using 2 litre bottles that are frozen to eliminate humidity. I know there will still be condensation on the outside of the bottle but it has to a lot less then pushing the air over just ice. Do you think that will work?
Stephen
bajorek
bajorek is offline
PostPosted: Fri Jul 02, 2004 7:52 am    Post subject: Reply with quote
I don't know why this would work other than in a vERY tight space- smaller than the van. I would thing that unless you were right beside the thing that you wouldn't feel it at all.
[email protected]
PostPosted: Fri Jul 02, 2004 8:11 am    Post subject: Reply with quote
The site says it cools a 7X7X5 foot space very well. So if it actually does do that I would imagine it would cool a bus down. I don't know about the humidity though.
Stephen
incynr8
incynr8 is offline
PostPosted: Fri Jul 02, 2004 8:20 am    Post subject: Reply with quote
My paintball team has a 5 gal cooler we fill with water, and it pumps water to misters infront of a sealed motor (SUPER IMPORTANT PART!!) fan, using 110v in this case. It keeps a whole group of people cool, lowers temps about 20deg F.
The bad? It's water folks, gets stuff misty and wet, and caused condensate buildup in closed areas. We use ours outside....
Eaallred
Eaallred is offline
PostPosted: Fri Jul 02, 2004 10:37 am    Post subject: Reply with quote
Imagine how fast that would melt the ice in your cooler! 1, maybe 2 hours tops!
I'd rather be hot, and have access to a cold drink, than cool for an hour, and then hot and have warm drinks.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
jahshines
jahshines is offline
PostPosted: Fri Jul 02, 2004 11:17 am    Post subject: Reply with quote
You could fill the chest with dry ice packages
OB Bus
OB Bus is offline
PostPosted: Fri Jul 02, 2004 11:53 am    Post subject: Reply with quote
Dry ice = no humidity, but also = a lack of oxygen in a tight space? Mammals cannot live on CO2.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
NovaHippie
NovaHippie is offline
PostPosted: Fri Jul 02, 2004 1:13 pm    Post subject: Reply with quote
open one or two of the vents and lack of oxygen problem is solved. i suppose it would cut down on some of the cooling power, but not too significantly.
nh
"I'm more of the shove-a-pencil-in-the-fuel-line kinda guy."
I'm almost ready... just let me fix my car.
Bottomend
Grease
Bottomend is offline
PostPosted: Fri Jul 02, 2004 2:31 pm    Post subject: Reply with quote
Heres a trick I learned while liveing in Japan. It gets SUPER hot and humid in the summer. RAIN FOREST HUMID! No kidding...
Combine a one gallon bucket/container of ice water with about 1/2 container of rubbing alcohol. (It's probably 8 oz) Dip a small towel in the water mixture, roll it up and then place across the back of neck at the base of the head. I was shown this method of staying cooling during 105*/ 90% humidity heat. in southern Japan. I got so chilled I was shakeing!
If I was driveing across the desert here in USA I would bring this to stay sane.
steponmebbbboom
steponmebbbboom is offline
PostPosted: Fri Jul 02, 2004 8:56 pm    Post subject: Reply with quote
no kidding, i was there once and my balls were LITERALLY SWEATING
Jealous_Zack
Jealous_Zack is offline
PostPosted: Sun Jul 04, 2004 6:36 pm    Post subject: Reply with quote
I remember seeing some 'hang on the passenger window' type evaporative coolers on bugs - just fill 'em with ice water and the faster you drive the better you'll feel. I suppose one could build/buy the same sort of thing for a bus.
Not so jealous anymore.
79 for Cruisin
78 for Parts
westy78
westy78 is offline
PostPosted: Sun Jul 04, 2004 7:13 pm    Post subject: Reply with quote
Yep, swamp coolers. Thermador was one brand. They were a popular accesory back then. I see them come up in the classifieds here every once in a while. Here is a shot of a Thermador on a bug.
Jasan C.
'78 Westy
jrodcat
jrodcat is offline
PostPosted: Wed Jul 07, 2004 8:15 pm    Post subject: Reply with quote
I'm working on a project to put a 110 AC powered window unit that is 7000 BTU's into the back doors window of my bus. It's only 12" in height so it will fit in there. A power converter that turns 12 volts into 115 AC current runs about $200 though. The trick here is to fabricate a panel to accept the unit and still have two small custom built windows on each side of the unit (so you can see out). The obsticle i'm running into is getting someone to weld me an aluminum bracket that mounts to the fabricated panel and the back door. This way you can make the installation as permanent as possible with a fully functional back door. My wife says I've been watching too much MTV Pimp My Ride!!!
jrodcat
steponmebbbboom
PostPosted: Wed Jul 07, 2004 10:07 pm    Post subject: Reply with quote
pimp my ride, or Red Green. Confused
The efficiency losses of the electric motor and DC to AC inverter just don't make any sense.
jrodcat
jrodcat is offline
PostPosted: Thu Jul 08, 2004 3:00 pm    Post subject: Reply with quote
What do you mean? You dont think it will work? Why?
jrodcat
