Where would be a good place to install a wide and O2 sensor?
Drewbox
Drewbox is offline
PostPosted: Tue Apr 16, 2024 9:09 pm    Post subject: Where would be a good place to install a wide and O2 sensor? Reply with quote
I’m converting my squareback to a modern EFI system. I’m nearly done but I’m having a bit of a difficult time deciding where to install the O2 bung.
Where have other people put it before?
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Apr 17, 2024 11:12 am    Post subject: Re: Where would be a good place to install a wide and O2 sensor? Reply with quote
Stock muffler?
Right here:
This gets a good average of all four cylinders, and is upstream enough to not be biased by any outside air getting drawn in.
Clock it at 2 o'clock (above middle) to keep it dry.
It is also easily substituted for a stock resonator with just a couple of bolts/nuts.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Wed Apr 17, 2024 11:56 am    Post subject: Re: Where would be a good place to install a wide and O2 sensor? Reply with quote
If you're adding one to a header/extractor system, you'll want it at the collector of the header/extractor (where the muffler bolts on) right before the muffler. Again, clock it at about 2 o'clock to keep it dry.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Drewbox
Drewbox is offline
PostPosted: Thu Apr 18, 2024 12:41 am    Post subject: Re: Where would be a good place to install a wide and O2 sensor? Reply with quote
It is a stock muffler with all the heater boxes. Thanks for the quick replies.
Multi69s
Multi69s is offline
PostPosted: Fri Apr 19, 2024 2:26 pm    Post subject: Re: Where would be a good place to install a wide and O2 sensor? Reply with quote
What are you going to do for the FI's air intake? From my understanding, hot intake air is worse for FI then it is for carbs.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Drewbox
Drewbox is offline
PostPosted: Mon Apr 22, 2024 6:29 pm    Post subject: Re: Where would be a good place to install a wide and O2 sensor? Reply with quote
For now I’m just using the stock intake. I have been designing a new intake manifold in Fusion360 and been 3D printing prototype parts, but for now just using the stock intake to get back on the road.
