Mike888 Samba Member
Posted: Mon Jun 10, 2024 7:38 pm Post subject: 91 Vanagon cooling fin (pushrod shield) part number? |
I’m looking to replace the part shown. Part number? Source?
zerotofifty Samba Member
Posted: Tue Jun 11, 2024 8:02 pm Post subject: Re: 91 Vanagon cooling fin part number? |
Thank you! Now I know what they are called!
Are there any sellers from Canada? I am in Ontario. |
Trevor P Samba Member
Joined: January 21, 2004 Posts: 898 Location: Saskatoon, SK, Canada
Posted: Tue Jun 11, 2024 9:40 pm Post subject: Re: 91 Vanagon cooling fin part number? |
I have a used set Id likely part with and Im in Saskatoon, or if you want new ones Concept 1 in Calgary has them in stock
https://store.concept1.ca/store/search.asp?keyword=pushrod%20shield* _________________ 53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2745 Location: Philly, mang
Posted: Wed Jun 12, 2024 8:02 am Post subject: Re: 91 Vanagon cooling fin part number? |
i would not buy the VW pushrod protection sheild. GoWesty makes a MUCH nicer product, heavier gauge steel, and it does not require removing the exhaust stud nut to remove. very important if the low pressure oil sender needs replaced.
concept1 sells the GoWesty product. totally worth the money.
https://gowesty.com/products/push-rod-tube-shield-set
_________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
Posted: Mon Jun 17, 2024 7:32 pm Post subject: Re: 91 Vanagon cooling fin part number? |
| Thank you! I will check out Concept 1. |
Posted: Mon Jun 17, 2024 9:28 pm Post subject: Re: 91 Vanagon cooling fin part number? |
| dabaron wrote: |
At $109.14, it is not worth the money. The stock shield gives plenty of protection, and for that amount of money, I will gladly remove an exhaust stud nut. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19062 Location: Retired South Florida
Posted: Tue Jun 18, 2024 5:07 am Post subject: Re: 91 Vanagon cooling fin (pushrod shield) part number? |
Gladly remove an exhaust stud nut till the stud snaps off and actually you may need to slot the one bracket to fit over the stud without removing.
There is a member tencent, his company is intrepid overland or something similar. He had a different design shield. I recall liking its design. The LS one is more critical to be easy to remove for access to the oil pressure switch and wire. |
Posted: Tue Jun 18, 2024 8:00 am Post subject: Re: 91 Vanagon cooling fin (pushrod shield) part number? |
| MarkWard wrote: |
Easy to slot that hole with a hacksaw, and antiseize is very useful on exhaust parts. The aftermarket shield is just too much money.
Heck you can even make a holder like the aftermarket one with a small piece of steel flat bar, two bolts and two nuts and be many many dollars ahead $$$$$$$ _________________ Sorry About That Chief.
Words to live by. |
riceye Samba Member
Joined: March 09, 2006 Posts: 1714 Location: Caledonia, WI
Posted: Tue Jun 18, 2024 9:36 am Post subject: Re: 91 Vanagon cooling fin (pushrod shield) part number? |
I still have my originals, but if I needed to purchase replacements I would strongly consider these.
Intrepid Overland (Vanistan) Push Rod Shields
_________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
