semaphore grounding out
codyodie
codyodie is offline
PostPosted: Wed Jul 21, 2004 11:34 am    Post subject: semaphore grounding out Reply with quote
I've got a '58 European Beetle, that the electrical works fine, but every once in a while, especially when it's near 100 degrees outside, my passenger side semaphore "grounds" out somehow, and causes my brake & turn signals to not work at all. All the other lights work just fine. BTW, it is painted all black, but the color shouldn't have much to do with it, but it only happens after sitting out in the sun for a while... Any help on this will be greatly appreciated.
Thanks, Odie Dunfield
Volksman66
Volksman66 is offline
PostPosted: Wed Jul 21, 2004 10:11 pm    Post subject: Reply with quote
You know what is weird...the same problem here. Have have no clue what the hell the problem is.
NOTAHONDA
Vegas Don
NOTAHONDA is offline
PostPosted: Mon Dec 19, 2016 1:31 pm    Post subject: Re: semaphore grounding out Reply with quote
Digging up this old thread. I am having the same issue with my semaphores. Any imput would be appreciated
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Mon Dec 19, 2016 8:17 pm    Post subject: Re: semaphore grounding out Reply with quote
... try these, instead
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
Wayne S. Johnson
Wayne S. Johnson is offline
PostPosted: Mon Dec 19, 2016 9:31 pm    Post subject: Re: semaphore grounding out Reply with quote
It sounds like the wire varnish is compromised, copper wire expands in the heat and contacts the frame. Rewinding the coils will solve the problem.
HYBRID STARTER 6/12 https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231
